Question about Symphonic SC1302 Combo
How do I change the tv channel without a remote? I have cable and need to put the tv on channel 3, but do not see how to do this. We lost the remote
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 30 Answers
Look u cant chane directly to channel 3,,,there is a solution,,jst do it mannually from the buttons available on the t.v
Posted on Aug 30, 2010
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
I need to know how to change my tv to channel 3 without the remote.
look along the side right or left and there is a row of buttons . they do all the functions a remote will
Mar 06, 2015 | Samsung Televison & Video
I don't have a remote control for my RCA TV and it's on channel 2. It needs to be on channel 3 so that It's compatible with my cable box. How do I change the channel without a remote to channel 3. It
U should have a menu button on your tv.If so try to find the channel setup option if you find this you should b able to manually go through your channels to add & delete the channels you want.If not you will have to go out a buy a universal remote.Make sure that it is compatibl to your tv.They should be a list on the back of the remotes pack stating all the brands that the remote is compatible with.I think you should be able to get one for unde 5 dollars.in the pack it should have an instruction manual.some tvs u can set up very easily & some you might have to keep putting in different codes until it works.Hole this could be some help to you.Good luck.
Apr 19, 2013 | Televison & Video
How do you get your tv to channel 3 without remote
It Depends on the model but most tv's have a manual button on them that allow you to change channels. If that still doesn't work you may need to do a channel search and then change it to channel three. I will need to know the make/model of your TV to help further.
Apr 07, 2013 | Coby TF-TV3217 32 in. LCD TV
I lost my remote and can't put my tv on channel 3 so I can watch cable tv
If there is no menu button on your TV's front panel, you can't select this option without its remote control.
Aug 26, 2012 | One For All URC4220 Remote Control
I pressed the menu button on my remote and went to channels then I went to antenna scan and lost all my channels how do I rectify this problem?
just go to menu and choose turbo/maunal search or go to channels and press right arrow key on your remote it will revert back to its previous settings
Dec 06, 2010 | Televison & Video
Daewoo DVN-14F6N
Same problem...Went to Goodwill Store, they usually have a large basket of remotes. I found a Daewoo remote for a TV only, HOWEVER on the bottom it has a AIR/CABLE button. The remote doesn't say Daewoo on it only..."Remote Controller R-25B03". The rest of the button of course work with the TV portion of the DVN-14F6N.
Sep 17, 2008 | Daewoo DVN-14F6N 13" TV
My daughter brought her tv home from college without the remote. I'm now trying to hook it up to digital cable. It needs to be on channel 3. When I try to manually change the channel to 3 using the...
The easiest will be to make sure that the cable box is on and sending out a signal to Channel 3 and auto-programming the set. Channel 3 is skipped because the last time it was auto-programmed, there was no signal on that channel.
Dan
Jul 10, 2008 | Televison & Video
Magnavox Model # RK 5530 AK02 TV
Can you get to inputs on your tv ? I would use these inputs rather than channel 3 because you'll get a better picture using the inputs rather than the tuner. They are in the back Yellow for video and red and white for audio. But without the remote you can go into the menu to see if you can manuel program your channels but most of these sets you can't do that . www.replacementremotes.com might have your remote should you need one . Good luck
Mar 01, 2008 | Televison & Video
Lost Remote
I personally would get myself a "Universal Remote". These units will operate almost ANY unit that uses Infrared... Ya Punch a "Code" in for your particular TV etc, and thats it... total conrtol...
Sep 22, 2007 | Sharp 32R-S50 32" TV
Open Questions:
See all Symphonic SC1302 Combo Questions
Symphonic SC1302 Combo Logo
197 people viewed this question
Top Symphonic Televison & Video Experts
Computer Repairing
Computer Repairing
matt martin
matt martin
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
