Panasonic FP-D250 display machine error coder E05-06
    Genius:
  • 1,218 Answers
E5-06 indicates a problem with the +12V line to the Scanner. It could indicate a prob with the Low Voltage Power Supply or a connector problem...you will likely need a serviceman for this one.
Posted on Nov 05, 2010
Error staple cover not closed
Make sure there are no loose or stuck staples somewhere in the staple slider tray stopping it from closing properly or that the cover itself hasn't broken off an pieces which may trigger a little switch to say that the door is shut.
May 26, 2015 | Panasonic...
Panasonic error code E01-22 Model FP-D250 Need a Laser unitl where can I find one
A new laser would be over $100, it would be much cheaper to buy a new copier.
Mar 03, 2011 | Panasonic FP-D250F Copier
Panasonic error code E01-22 Model FP-D250 photocopier. what does the error code mean? Thanks Nick 0771 8982344/ 01530 519234
E1-22 indicates a problem with the Polygon Motor Sychronization....this is a problem in the laser unit either the Driver pcb is shorted or broken, the Laser unit pcb is defective, the laser unit itself could be defective.
Sep 16, 2010 | Panasonic FP-D250F Copier
What does the error message E01-22 mena for the panasopnic fp-d250 photocopier
the polygon motor in the laser unit is at fault, this will require a service technician to repair
May 10, 2010 | Panasonic FP-D250F Copier
I have a Panasonic FP-D250 Copier and get a E05-01 Code. Can you tell me what that means. Thanks in advance.
It means printer engine communication abnormal. Check the connections on the pcb control board. you may need a service tech to do this
Mar 31, 2010 | Panasonic FP-D250F Copier
Panasonic FP-D250 copier first displays error U16 - install the developer unit - then changes to machine error E04-01. Any suggestons?
hello robertsona from robertsand. e4-01 is fuser warm up. check connections and fuser thermal fuses, as well as the lamps. good luck
Jan 25, 2010 | Panasonic FP-D250F Copier
Machine Error e1-20 is being displayed after copier was moved.
That error is related to the laser unit. Check your connectors, they may have vibrated loose during move. These machines have a history of laser units going bad.
Apr 15, 2009 | Panasonic FP-D250F Copier
Machine Error
Hello sir; E01-22 that's laser motor synchronization, need to replace laser unit the item# is FFPGC0208
Feb 06, 2009 | Panasonic FP-D250F Copier
47 people viewed this question
jasbo
jasbo
