I have an RCA converter box, where do I get a smart antenna and what are the price ranges
    President:
  • 1,779 Answers
Radio Shack will be a good guess
Posted on May 08, 2008
I have an rca atsc converter box, lost instuctions printed out on line. but need the tv code for my new Sanyo hdtv lcd tv model# DP32640. Can you help? I live in a heavily treed area and think the...
you don't need converter.
get a digital antenna from Walmart along with the power booster that the coax cable screws onto, then a short coax
to the tv. I get great tv from 80 miles away into my woods
Jul 31, 2017 | RCA ATSC11 DTV Receiver
No channels found with automatic channel search
You may need a new antenna.  Go to www.antenna.com for info and help.
May 30, 2009 | RCA Analog (RCA) to Digital (VGA)...
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Converter Box Problem
What type of antenna are you adjusting? If it is not a UHF then you will have to try another such as a Smart Antenna or one from Wal-Mart for digital TV.
Feb 05, 2009 | Televison & Video
I bought an RCA 800 converter box and it keeps saying signal is too weak, so I bought a stronger antenna. It didn't work and the manual says I need a smart antenna. I bought the RCA antenna 1500. This is...
try this:
if the antenna is the kind that takes a power adapter to power try moving it away from the converter box and try changing frequeny on antenna this problem is usually for cbs channels...
Nov 12, 2008 | RCA Televison & Video
What is smart antenna for the convertor box?
Smart antenna is a device that connects to the antenna, and send information on the channel received, adjusting itself for the best reception of that channel.
See below :
What is smart antenna? - a definition from Whatis.com
Smart antenna - Wikipedia, the free encyclopedia
Smart antennas
Sep 10, 2008 | RCA Televison & Video
Need a smart antenna to go with the Digital TV converter box
First, you don't need a Smart Antenna, the manual is simply stating that your converter will use one if you have it. Any standard antenna will work, so there is no need for a coupon to pay for a new one, whether indoor or outdoor depending on your location and distance from each channel transmission tower. Since you don't give details of what antenna you are using, I will assume you have rabbit ears for each converter. Rabbit ears are notorious for poor reception and any metal or persons nearby will change the reception quality. I would recommend a roof mounted external antenna with splitters for the 3 converters if you have the option. If not, use an amplified internal antenna and mount it closest to the channel towers you will watch most and as high as possible. If you can find a smart antenna, which is an amplified indoor/outdoor antenna with a control cable for changing the direction of reception, for a decent price, you can use that but keep in mind that to use the control feature you will need one for each converter. Also, check antennaweb.org for information on digital channels in your area and their direction and distance. Antennaweb.org will also tell you if any digital channel in your area uses VHF frequencies. If they don't then a UHF only antenna will work fine.
Jul 16, 2008 | RCA Universal Remote Control
The instructions for our DTA800 digital to analog converter box for over the air waves for TV signals say since the signal is too weak that we need a SMART ANTENNA. What is that and what do you...
Hey boykinpierce,
The phrase "Smart Antenna" is often used to describe a multi-directional antenna or antenna array. These types of antennas are able to detect and automatically adjust to any changes in the TV signal strength you receive, and can generally be obtained through most major retailers. They primarily are used in areas where digital signals are weaker or somewhat inconsistent, and will attempt to optimize the signals they do receive before sending them to a TV or digital converter box.
Please keep in mind that while some DTV digital-to-analog converter boxes may have built-in Smart Antennas, this particular model (RCA DTA800) does not appear to have this feature.
If you're still not quite sure what to look for, please remember that you can always speak with a home theatre sales agent at your local Best Buy™ store for more information.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
