Question about JVC Cameras
I burned DVD from my camcorder but my DVD player doesnt want to play it.
    Brigadier General:
  • 11,967 Answers
Some DVD players will not play certain types of DVD's such as a DVD-RW. Also, the DVD must be finalized before it will play on your machine. Did you do that?
Posted on Aug 30, 2010
I burned a dvd and i tried to play it in my dvd player it wont read the disk when i took out dvd it doesnt seem to be writen at all
DVDs typically need to be burned in a certain format in order to play back on a DVD player. How exactly did you burn the DVD?
May 17, 2011 | Memorex MEM32023223 Dual Format DVD...
I have a really old Canovision8, E40, 8mm camcorder that doesn't work anymore. What's the best solution to convert the tapes to DVD or to the computer?
You need Hi-8 camcorder/ Hi-8 player to playback your old Video-8 tapes, hook that camcorder/ player with DVD Recorder, play video-8 tapes and burn DVDs directly.
Dec 27, 2009 | Canon ES400V Camcorder
I used -R blanks to burn home movies and they will
NOT ALL DISCS WILL PLAY ON ALL DVD'S. IT'S THE NATURE OF THE BEAST. TRY PLAYING THEM ON A MORE EXPENSIVE DVD PLAYER. THERE ARE MANY DIFFERENT PROTOCALLS USED BY THE DIFFERENT COMPANIES.
Nov 16, 2009 | Daewoo DV-6T955B DVD Player/VCR
Burned video disc does not play on home DVD player
Did you burn the disc as AVCHD or DVD...if avchd will only play on blu ray avchd compatible players or ps3 , If dvd should play fine
May 20, 2009 | Canon VIXIA HF100 Flash Media Camcorder
Did not burn dvd
The DW-100 burns files in the same format as they were originally recorded by your camcorder. The Canon Vixia HG-21 records in AVCHD--a high-definition format--which is completely different from standard-definition DVD and which is not compatible with regular DVD players (even though the disc itself is a standard DVD-R). As it states in the manual for the camcorder, "High-definition (AVCHD) discs created using the optional DW-100 DVD Burner can be played back only with AVCHD-compatible DVD players."
The DW-100 is really more for archiving your files in their native format than for creating standard DVDs that can be played on regular DVD players. Regular (standard-definition) DVD players can't play AVCHD, although many Blu-Ray players can. Unless you use a Blu-Ray player that supports AVCHD playback, there are two solutions to your problem:
1. If you want to keep your recordings high-def, you can view them by playing them back with the DW-100, which must be connected to your camcorder via the USB cable, then from your camcorder to your TV via an HDMI cable.
2. If you want to have standard DVDs that you can play on any DVD player, either import the files to your computer and convert them to standard-definition using video-editing software, then burn them to DVD with your computer's DVD burner, or connect the analog output (component=better, composite=good) to a stand-alone DVD recorder (i.e. not the DW-100).
I've used the route of Vixia HF-10 camcorder > composite output > Panasonic DMR-ES25S DVD recorder (about $65 used on eBay) with pretty good results when I've wanted to give videos to relatives who don't have Blu-Ray players. You just have to make sure to set the camcorder 's analog (composite) output to 480i so that it formats the picture in the right aspect ratio, or else the 16:9 image will be squeezed to 4:3 instead of letterboxed.
Hope this helps. Good luck.
Mar 19, 2009 | Canon DW 100 DVD-RW Burner
DVD playing
You may have to buy a new player! because its not compatable ( you need one that plays DVD+ DVD- and dvd RW!) and the players that play these formats are no more then a regular dvd player (seen them for as low as $30.00 at wall mart!
Dec 10, 2008 | Televison & Video
Download on JVC MG130U
Try saving the files from your camcorder to your PC.
This way you can convert them and use them as you wish.
Burn them to DVD using a NERO package.
If they are of an unsupported format (DiVX), use a relevant programme to convert them up to DVD 'ConvertXtoDVD' is a pretty good, freely available programme on file share sites.
I used it for my Digicam videos.
Hope this helps
Aug 20, 2008 | JVC Everio GZ-MG130 Camcorder
Tranfer mini cd to a normal cd?
put the CD back in the casmcorder, and hook up the camcorder to your tv. put a blank disc in your dvd player and play the small disc through the camcorder on the tv. while the camcorder is playing the recorded stuff, press record on the dvd player and it should burn the stuff onto the blank cd.
Jan 10, 2008 | Panasonic VDR-D200 DVD Camcorder
I want some feedback for DVD Camcorders.
My non-authoritive answers are: 1. Can the DVD-R be played on the Camcorder without finalisation? I'll write no. This is based on one comment by an user plus numerous experiments with DVD+R, DVD+R/W and such formats. 2. Does the DVD-RW / DVD-RAM need a finalisation ? Can the DVD-RW / DVD-RAM be played back on the camcorder/DVD Players/Computers without finalisation ? Based on my experiments with DVD recording and the 3 DVD players I have in the lab, the answers are yes and no in that respective order. 3. Can the DVD-RAM be played in the camcorder and output recorded in a standard VCR Casette ? The media played in the camcorder but placing the media in the VCR doesn't work since it's a phyical media issue. 4. Can the DVD-RAM/DVD-RW be played in the camcorder and the output captured in a computer and then burnt back on the DVD-RAM/DVD-RW or Computer CD/VCD ? Sure, but my method skips the play and re-capture. The files on the media are just placed into the DVD creation software and a new DVD is recorded.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
Cameras Logo
23 people viewed this question
Top JVC Cameras Experts
juanmireles1
JOHN ALBURY
JOHN ALBURY
Are you a JVC Camera Expert? Answer questions, earn points and help others
