Question about American Standard Bath Faucet Ceramix 2000.500 002 Chrome Bath/Shower Fauce...
American Standard single lever shower and tub faucet manufacturered Feb. 1997 no matter what position lever is in a steady stream of hot water continues to pour out. I changed cartridges from plumbing supply part #023529-0070A twice. Still same original problem, hot water continues to pour out of faucet inan off position. Please help me solve this problem. Thank you so much.
    Problem Solver:
  • 3 Answers
Replace gaskets, and hot & cold water stems inside of manifold (turn off water first).
Posted on Mar 24, 2011
American standard single handle shower vavle drips when tub spout is on.
Be sure to pull the plunger all the way up when diverting the water between the the tub and shower if ti keeps giving you a problem it's faulty
Mar 05, 2016 | American Standard Home
No hot water pressure
These types faucets have a what is called an anti scald valve build into them, it is required by law, it is either defective or out of adjustment, contact a local hardware store for more detailed info.
Feb 02, 2012 | American Standard Plumbing
Cold and warm water, no hot water
If this is a new installation or someone has removed the lever and put it back, take the lever off.
There should be an plastic insert with grooves and a stop on it, which allows the lever to only go so far.This is removable. The insert acts as a stop to prevent scalding. you should be able to pull it out and reinstall in with the stop more toward the left allowing the lever to go more toward the hot side. Hopefully this helps out.
May 10, 2011 | American Standard One Handle Tub & Shower...
I have very little hot water pressure on my american standard shower faucet. Can I adjust it?
the pressure in pipes has to do with the volume. The bigger the pipe the better the pressure. Take the time to trace out your hot water line and see if you can find any old galvonized pipe, thats usually the problem in most cases. galvonized pipe over time will rust and corrode causing restriction in the water line. replacing it with 1/2" copper should solve the problem.
Jan 24, 2011 | American Standard 1041224299 Williamsburg...
I have a one handle shower/tub faucet, and when you run straight hot water (to preheat for example) the water shuts itself off. Lever is still in the lifted/on position however. Cold is fine, even warm...
If this is a newer valve what is probably happening is the valve is a scald guard valve and is shuting itself off when it senses no pressure on the cold side. I don't have a lot of experience with am. std. valves but I'm sure you can get instruction on line to set heat setting on valve higher. Thank you.
Jan 20, 2011 | American Standard One Handle Tub & Shower...
Low water flow
buught sink taps same problem do they have flexy conectors with them. my problem was as they are american hot @ cold water suply are maines fed so hole in bottom of taps [or in flexy pipes are too small
May 17, 2009 | Danze D302521 Antioch Roman Tub Faucet...
New house . tub wont turn off. water has a steady
The plumber soldered in the faucet without removing the cartridge, the o-rings are melted. Have the builder replace the o-rings.
Mar 15, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Tub faucet drip
Hi, You have to replace the two rubber cups in the hot&cold faucet lever. Let me know if you need more info.
Nov 09, 2008 | Banner Faucets Pro Series M580 Single...
American Standard Bath Faucet Ceramix 2000.500 002 Chrome Bath/Shower Fauce... Logo
548 people viewed this question
Top American Standard Plumbing Experts
john h
Steve Wood Plumbing...
Level 1 Expert
Mike
Are you an American Standard Plumbing Expert? Answer questions, earn points and help others
