Question about LG WM2075C Washer
Making lound humming sound errors out and door is locked(clothes still stuck in there)... also when starting new load its not spinning...
4 Suggested Answers
SOURCE: "le" on the LG WM0532hw front load washer errror
try unpluging for 45 seconds than hold in the selector knob for 10 sec. & plug back in
Posted on May 18, 2009
MNTECH
  • 1543 Answers
SOURCE: LG front load washer WM2277HW. ''LE'' Error code
First try unplugging the machine for a few minutes and then retry a cycle. If you still get the LE error:
The Hall sensor (part number 6501KW2001A) has failed. The hall sensor is rather easy to replace, and is covered by a seven year part warranty (in the US). Take the back cover off. Take the big nut off and remove the motor rotor. Remove the bolts holding the motor windings. Remove the electric plug on the sensor and unclip it from the motor winding. Snap new sensor on and reassemble. Usually takes under a half hour. On a difficulty scale of 1 - 10, it might rate a 4. This should be a Fix-Ya for your machine, and at basically no cost!
In the US, find a service provider using your zip code at http://us.lgservice.com/index_b2c.jsp or call LG at 800-243-0000
Posted on Jul 03, 2009
beltronic205
  • 1474 Answers
SOURCE: I have a lg front
Check the pump is working if not clean the filter......
Posted on May 02, 2011
I have a brand new admiral high capacity washer Worked the first two times I used it and this last time I went to start a load turned the washer on and heard a humming noise and would not spin My boyfriend...
The most common cause of this is something stuck between the drum and the tank. Rotate it by hand and see if you can locate the source of the sound.
Jan 19, 2018 | Washing Machines
Gltf530ds0 cloths wet after spin
Hello Dallas Hart - Is the washer making a humming noise? If so, either the drain pump/hose is clogged and needs cleaning. If not, the unit may possibly be experiencing a communication issue with the control board, faulty door lock assembly, pump or timer. Contact a professional to move forward accurately and for an accurate diagnosis.
Feb 03, 2013 | Frigidaire ATF6000ES Front Load Washer
My Kenmore HE2 front load washer when I go to start a load of clothes it's making a humming sound and not filling up with water?
Either one of your water valves isn't working properly, or the lines have sediment restricting the volume of water . What I would do is turn the water to the machine off and remove the water lines and make sure they aren't filled will calcium, etc. and look in the water valves where the hoses connect because that are, which has a screen, may be full of nastiness. If both those are good then the water valve solenoid(s) are stuck and won't open. The humming sound you hear lets you know the rest of the machine is working because the sound is generated by power being applied to the valve by the control.
Jun 21, 2012 | Kenmore 43142 Front Load Washer
The machine will "hang" with
Check the pump sump cleaner. Under the front panel at the bottom. DC means the door is still sensed as open . If it occurs more often may need new door lock switch
Oct 29, 2010 | Maytag MAH8700A Front Load Washer
Making humming noise power not on door locked
turn off the unit.use a wet dry shop vac and attach it to the end of the drain hose this will remove all the water then you can turn it back on and should be able to open the door to get your clothes out.
after all thatis done you need to check the drain pump and make sure there is nothing blocking the pump.other likely problems are the door lock mechanism is bad or the main control board
Jul 05, 2010 | GE Energy Star WCVH6260F Front Load Washer
Frigidaire LTF2940ES Hums
sounds like something is stuck in drain pump
washer will not go into high spin untill water is pumped out
Jul 20, 2008 | Frigidaire GLTF2940ES Front Load Washer
Sounds like the belt may be off. Was it moved with the shipping braces out? It may have caused some internar damage. You might check to see if the hum is coming from the door lock area. If the lock is out it won't let drain or spin.
May 16, 2008 | Frigidaire GLTF2940ES Front Load Washer
Washer will not start and is making a buzzing sound.
did the belt fall off in the back of the washer. Mine was overlaoded and the belt came off somehow- it went back on fine.
Apr 17, 2008 | GE WSXH208A Front Load Washer
GE WBSR3140D
I have the same problem. The water drains, but I have no spin leaving the clothes soaked. I get a humming sound and thats it. The rest of the washer works fine. Any help would be great.
Jan 13, 2008 | GE WBSR3140D Top Load Washer
LG WM2075C Washer Logo
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
