Question about Dometic Rooftop RV Air Conditioner
Dip switch problem .what is the settings on front and rear?
    Top Expert:
  • Dometic Master
  • 8,502 Answers
Rear nuber1 no setting except furnace or heat features front is 2
Posted on Sep 15, 2017
Bunn troubleshooting
If you are pressing the secret button behnd the trademark symbol but its not working, you need to make sure the SET dip switch is set on the main PCB. switch off and isolate the machine. Remove the top cover. look at the main PCB behind the front panel and locate the small dip switch on the right side. Set it to the on/Set position to enable the secret button
Mar 10, 2014 | Bunn Dual TF DBC Coffee Maker
Rear ac dometic doesn't responed
check dip switches and communication cable and temp sensor
Mar 07, 2013 | Dometic Rooftop RV Air Conditioner
Signal lights dont work and want to know where the fog light switch is at
With the switch in sidelight or dip
position, pull the switch to its first
position to turn on the front fog lights.
Pushing the switch in or turning it to OFF
or AUTO will turn off the front fog lights (this is for the front)
With the switch in any position except
OFF or AUTO, pull the switch to its
second position to turn on the rear fog
lights. This will also turn on the front fog
lights unless main beam is selected.
or AUTO will turn off the rear fog lights (this is for the rear)
Exterior lighting
Exterior lighting switch
A. OFF.
B. Side (parking) lights.
C. Headlights.
D. Auto.
E. Front fog lights.
F. Rear fog lights.
It is the round knob nest to the steering colume
Aug 18, 2011 | 2003 Jaguar X-Type
I have an opener model no. 139.53515SR. How do I find out what the operarting frequency settings are so I can set the dip switches on the hand held unit. The original hand held unit is lost. Thank you...
You don't need to set the dip switches. Locate the smart/learn button on the rear of the motor unit near where all those white wires go. While holding the button on the remote press and release the smart/learn button. Your remote should now operate the door.
Oct 02, 2010 | Sears Craftsman LiftMaster Chamberlain...
The fog lights on my santa fe want turn on when the switch is depress
hi from uk if your front and rear fogs are of the same specification as uk models of hyundai ? these front and rear fogs although the switches are on these lamps will not operate till you turn headlight on dip beam reason being that if weather conditions req fogs on then you should have rear and front side light and head lights on however if you inadvertently forget to switch front or rear fogs off when you turn other lights off when parking car ? you will/should hear the warning bleep as you open drivers door as you would if side/rear lights are still switched on ? hope this helps?
Mar 03, 2010 | 2003 Hyundai Santa Fe
DIP Switches don't seem to matter
You need to completely power off (wall switch or breaker) when changing the dip switches. Not just power off from remote because it will keep previous setting. I learned it the hard way....
Sep 14, 2009 | Hunter 27185 Remote Control
Remote for tv in closed cabinet
i don't know about the dip switch, but the ir receiver board in this mitsu is located in front of the mirror behind the screens
May 23, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Sony Model SMO-F551-01 MO Disk Drive Jumper and DIP Switch settins
We use a stand alone--single drive and a Jukebox with two drives. Both drives in the Juke box have 15 dips off and the #1 switch closest to the rear, switched on. The Standalone drive has all switches off. Our drives use terminators on the cable connectors on the rear of the drives.
Sep 12, 2007 | Sony SMO-F551-01 Tape Drive
Dometic Rooftop RV Air Conditioner Logo
302 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
