Question about Car Audio & Video
I hooked up the pioneer premier deh-5901b and ran the blue remote wire to my amp aswell as the sub-woofer pre out to the amp and hooked up my negative battery cable to my battery,,,,,,my amps have power,but i get no sound even when i turn the sub woofers sub button on the deck,,,,what could be the problem? i tried a couple amps that were new and i still get the same results.
    Scholar:
  • 98 Answers
Either the rcas arent outputting the audio signal or you have a bad se tof rcas. An amp is obiously not your issue in this case.
Posted on May 09, 2008
I dont know how too hook up a remote wire for a amp for subs
there is a blue wire on back of deck with white stripe thst is the remote hook a wire to that and run to amp plug in to remote on amp and there you go i hope this helps you
Jul 10, 2011 | Pioneer DEH-P700BT Car CD Player
Were is the sub woofer tie into at.
You should have two (or more) RCA plugs on the back of the deck that will act as pre-amp outputs for subwoofer and speakers.
Failing that, your wiring harness should have come with a wiring diagram that will let you know which is the subwoofer output.
Failint THAT, the deck itself should have a wiring diagram on the bottom or side telling your which wire is which.
And if that fails, Your deck may not have a subwoofer output. Just attach your sub to the amp pre-out like everyone else.
May 11, 2011 | Pioneer DEH-2400F CD Player
Can a pioneer DEH-46DH super tuner be hooked up with subs? using its pre out?
Yes you can use the pre out to hook up an amp and subs. Probably the best way to send the signal to an amp to run the subs.
Sep 20, 2010 | Pioneer DEH-46DH CD Changer
PIONEER 300 WATT CAR STEREO AMP WIREING HOW TOO
depending on how many channels the amp is, you may not be able to hook everything up to it.
usually you have a separate amp for subs. 4 channel amp for the speakers in the car, and a mono amp for the subs.
To hook them all up to the same amp you would need an amp with 5 channels. It wouldn't work out right.
If you have a mono amp its only for subs.
If you have a 2 channel you can either hook it up to the rear speakers or bridge them to mono to run the subs.
you need a channel per speaker basically.
Dec 15, 2009 | Pioneer DEH-P2000 CD Player
Amplifier enable. Where to mount rmt hookup on pioneer deh-1400 (old) so my amp/sub can work!!!
Amp turn on wire should be a blue wire with a white stripe on that pioneer unit. extend that wire out to the amps remote turn on wire input. And once the radio is turned on it will sent a 12volt signl and turn on the amp.
Jun 09, 2009 | Pioneer DEH-1400 CD Player
Pioneer deh p4900ib. After installing, only the sub woofer works. Why wont any of the door speakers work
Dodges internal amp requires a remote power wire. I tied the exteral MTX amp to the Dodge internal amp and all speakers work.
Jun 26, 2008 | Pioneer Car Audio & Video
Pioneer DEH-P2600
blue and white wire on a pioneer is usually the power antenna wire, most people use it as the lead for power to turn on the amp that is installed, the amp should be hooked up to the RCA jacks on the back of the player to the input RCA jacks on the amp. then the outputs vary, some amps are bridgable which means that you can hook up one speaker to both output speakers this will almost double the watts to the speakers. you must know which side would be positive and which side negative to set it up like this. also important is it a two or four channel amp. this all matters. if you can provide more info I can assure you the best hookup possible for premium sound.
Dec 11, 2007 | Pioneer DEH-P6900UB CD Player
Pioneer DEH-225 Car Audio
The system remote control is usually a blue wire on your decks harness and it is for an amplifier for a sub or other speakers. It sends power to the subs amp when the deck is turned on. You may need to find the wires coming off the antenna and splice them into the red power switching wire 12v on you decks wire harness. Good luck
Oct 07, 2007 | Pioneer DEH-225 CD Changer
Connecting a amp
It has a remote output if it also has RCA pre-outputs. The remote output wire is blue with a white stripe.
Sep 24, 2006 | Pioneer DEH-1630R CD Player
Car Audio & Video Logo
183 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
