Question about Princeton Digital VL1716 17" LCD Monitor
You helped me yesterday yo get my old monitor, a Princeton VL 1716 to work. From my reading on the web, the sound is supposed to come through the monitor. Do you by any chance know how that works? I have all my sound settings turned on. Thanks
  • 131 Answers
There is a port on the back of the monitor for connecting it to your computer's sound card. Green to green with the provided cable will work.
Posted on Aug 30, 2010
I have no sound on my moniter and on checking I do not have a audio cable on my moniter. Where can I get one.
If this is a new unit all what is needed is to check the first page in the manual for the list of acessories that comes along and if this cord is mentioned you must contact the dealer. If not this is a general type and so must not be a fault to get them in the general market- any spares shop.
Oct 28, 2011 | Princeton Digital VL1716 17" LCD Monitor
My VL 1918 is blinking on and off constantly
It does the same when used with another PC?
Otherwise, look for bad caps, transistors, transformers as shown in my pictures here: http://s807.photobucket.com/albums/yy352/budm/PRINCETON/Princeton%20VL1918W/#!cpZZ1QQtppZZ20
Very common problem as you can see.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Aug 07, 2011 | Princeton Digital VL1918 Monitor
How do I change the size of the image of a Princeton Digital VL 1918?
You can't change the image size as such actually on the monitor but you can change the size of the image feeding the monitor.
In windows right click the desktop, click properties in drop down menu then click settings.The setting should correspond with the native setting of the monitor which is 1280x1024 pixels and that is what you should set it to.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Feb 24, 2011 | Princeton Digital VL1918 Monitor
I've opened my princeton vl 1919 monitor to see if the caps are blown. I can't loosen the grey metal cover covering the boards to see the caps. I've removed the hexes on either side of the video inputs but...
Not sure if the VL1918 uses the same chassis as your, just remove the 4 screws and disconnect all the lamps connectors and other connectors.
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL1918W/
http://s807.photobucket.com/albums/yy352/budm/Princeton%20VL2018W/
Can you post the pictures? so I can see what it is about.
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Please post back what you find.
Please leave rating if it helps.
Jan 06, 2011 | Princeton Digital VL1919 19" Monitor
I have an old Princeton VL 173 that I had been using with an old computer running Windows XP Pro. It works fine. Got a computer with an Asus MB and a Intel Core 2 Quad running Windows 7 Home Premium...
It sounds like a driver/software issue. When you ran the Princeton VL173 on XP you probably had all the correct software for your video card and the correct drivers to support your video output. When you changes OS to Windows 7, the XP drivers are no longer in place. My best guess is that you need to find and install the correct drivers for your system video and for your video card that are Windows 7 compatible. The old XP drivers will not work in Windows 7.
I am running XP with a Princeton VL173. It works great. I identified the correct video drivers for my system and installed them. My video card is nVidia 8800GT. I downloaded and installed the latest software from nVidia and installed it. It runs like a champ.
Several months ago my display died. It was just blank -- black. I tried using a power supply (AC adapter) from an old HP printer that died, and it worked! The plugs were identical, and the power output profiles were very nearly identical. It has been rinnung great for many months now.
I hope this helps.
Steve
Dec 29, 2010 | Princeton Digital VL173 Monitor
Princeton vl 1918 monitor on screen it says check cable no signal. how do you obtain signal?
You need to verify to find out if it is the monitor is bad or the PC is not sending the video signal to the monitor. Try another monitor with the PC, if you still have the problem then you need to fix the PC, if it works OK then it is the monitor problem.
Basic LCD monitor troubleshooting guide:
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
Oct 08, 2010 | Princeton Digital VL1919 19" Monitor
Have old computer ,do not have directdvi-d connection on my computer, can I buy adapter to fit old monitor plug?????
Princeton Digital VL2018W has VGA and DVI input ports, why not use the VGA cable from your old PC to the VGA input of the Princeton Digital VL2018W?
Aug 01, 2010 | Princeton Digital VL2018W Monitor
I cannot get the Princeton VL 1716 to stay on the 32 bit color when I reboot.
This problem occurs when the incorrect video driver has been install in the computer. It defaults to generic VGA driver which does not allow any scope to change to a higher screen resolution and a higher bit color setting.
Oct 23, 2009 | Princeton Digital VL1716 17" LCD Monitor
VL1716 Monitor screen black
they are using java and possibly dhtml scripts, your browser may not work properly with their site, but this is the link
http://www.sonyrewards.com/en/home/base/?ref=http%3A//www.sony.com/index.php
Aug 20, 2009 | Princeton Digital LCD17D (Graphite) 17 in....
I have a Princeton VL1918 LCD monitor. Need help
You have a monitor with a common problem. After a few years some LCD monitors will blow a power supply. The problem is caused by parts called capacitors overheating in the confined space of he monitor. If you are good at electronics repair/soldering you can usually fix he problem. Check out a few pictures on my web site www.ccl-la.com/badcaps.htm You can take the back cover off your monitor and look for the bad parts, replace any that look like the pictues and your monitor should work fine. The capacitors do need to be installed with the correct + and - connections, note the stripe on the old one and insert the new one the same way. If you don't want to try the repair yourself we offer a repair service for $35 plus shipping. If you don't see any bad capacitors then the next thing would be bad CFL (backlight tubes) in the screen itself. If it is that then the monitor needs to be replaced because of the tech skills needed to replace then. I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Over 21 years of computer and printer support/repair
Jun 29, 2009 | Princeton Digital VL1918 Monitor
Princeton Digital VL1716 17" LCD Monitor Logo
Top Princeton Digital Computers & Internet Experts
jairo sanchez
Sunday Ojelabi
Sunday Ojelabi
Daniel Dollive
Daniel Dollive
Are you a Princeton Digital Computer and Internet Expert? Answer questions, earn points and help others
