Question about Frigidaire 24 in. PLD2850 Built-in Dishwasher
I see water leaking from the pump houseing - Frigidaire 24 in. PLD2850 Built-in Dishwasher
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
uygiop788
Posted on Sep 29, 2010
Changed water pump,thermostat, top rad. hose. still leaking leaking antifreeze from what looks like below thermostat housing. have noticed super small hose from water pump to engine. looks hard to replace....
That is called the bypass hose. It could be leaking but I'd take a closer look at the thermostat housing. If you replaced only the thermostat and not the housing, the housing may be leaking. It's a common source of coolant leaks.
Apr 16, 2011 | 2000 Dodge Ram 1500 Truck
Replaced the water pump on our '97 Buick Century because we thought that is where the leak was originating. Replaced the hose from the radiator to the water pump as well. It is still leaking with fluid...
YEP YOU HAVE LEAK AT THERMOSTAT HOUSING.YOU NEED REMOVE THERMOSTAT HOUSING OUTLET AND CLEAN THE MATING SURFACE THOROUGHLYTHEN APPLY RTV SEALANT IN THE GROOVE OF THE WATER OUT LET HOUSING.INSTALL THERMOSTAT WITH SPRING TOWARD THE ENGINE TORQUE THERMOSTAT OUTLET HOUSING BOLTS 89 INCH LBS.IF STILL LEAKS OUTLET HOUSING COULD HAVE CRACK IN IT CAUSING LEAKING.
Sep 08, 2010 | Buick Century Cars & Trucks
98 Ford Explorer SOHC 4.0 V6 Water Leak
take it to a mechinc shop and have them do a pressure test
May 16, 2010 | 1998 Ford Explorer
97 5.2 jeep has a water leak in the housing
It's not leaking from the timing cover.
Your Thermostat gasket is leaking.
May 03, 2010 | 1997 Jeep Grand Cherokee
I have a leak in the water pump housing gasket
Do you have a leak at the water pump cover? The water pump? Or the 4 gaskets that seal the water crossover (that the water pump is in) to the cylinder heads?
Mar 31, 2010 | 1998 Oldsmobile Aurora
Antifreeze leak at lower raditor housing? antifreeze dripping down oilpan by dipstick tube and aircondition compressor only when hot.
you may have a water pump that is starting to fail. Look for the water pump that's driven by the fan belt. look at the housing of the water pump there is a relief hole that they drill in the casting and when the pump begins to fail it will drip out this hole. If that's where your leak is, it's time to change the pump.
K
Jul 29, 2009 | 2001 Chrysler Sebring
Lower radiator hose leak at water pump housing
water pump housing is cracked ,replace the water pump
Apr 11, 2009 | 2002 Chevrolet Suburban 2500
2002 chryler sebring is leaking anti freeze
It depends on where the leak is coming from. If the water pump is leaking, it has a hole on the bottom of it. You will see a trail of dried anti freeze coming from the bottom of it, indicating a bad water pump. It's best to dry everything off, crank it up and let it come to operating temp and check for where the leak is coming from. It may just be an old hose or loose clamp.
Nov 20, 2008 | 2002 Chrysler Sebring
Frigidaire 24 in. PLD2850 Built-in Dishwasher Logo
Top Frigidaire Dishwashers Experts
Mike
Charles T Nevin
Charles T Nevin
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
