Question about Bosch SHU5315UC Dishwasher
Takes more than 2 hours to complete a one hour cycle. Will sit on "1" minute left for the last 45-60 mins. If the door is opened during this long one minute the washer still has water in it and will reset to 13 mins remaining.
  • Bosch Master
  • 2,605 Answers
Welcome to fixya.
**What I`m about to share applies to Almost all Electronic control B/S/H/ dishwashers. That includes Bosch, Thermador, Gaggenau and Siemens.**
Based on your description I know what the problem is, though you may not like it.
I would still start by checking your water inlet temperature, the unit must be connected to a "hot" water supply line.
Try running the hot water at your sink tap to insure the cold water is out of the lines just before you turn on the dishwasher.
That is just a suggestion out of courtesy however...
If it is what I suspect, the control, this won't make any difference but it's worth a try. If on the other hand the water is good and hot entering the machine, you likely have an issue with the control as I alluded to.
The reason your dishwasher never completes a cycle and displays "1" ( 1 is an error code for not heating ) or takes an extremely long time, is the control has detected a heating error.
Here`s the most likely reason why it has detected the error...
Even if your home water supply appears hot, it's not hot enough and must be heated by the dishwasher to insure a proper clean and dry.
The error likely lye`s within`the electronic timer/control, specifically the heater relay solder joint. ( a faulty flow switch, ntc or heater can also cause this, but not very probable ).
This is why it runs really long/forever, display`s "1" unless you "stop" it or by pressing the two buttons for "cancel".
To repair your unit It will require you to remove the control from the unit and then remove the control from it`s plastic housing and look for a burnt solder contact on the printed circuit board.
The burnt solder joint will be one of the pins from the heater relay, hence the unit runs on and on ( because it can`t heat to advance or until canceled ) trying to heat the water.
You can also enter a test to check for proper amperage via the use of an ammeter as such...
**Further to this, if you or someone you know is proficient at soldering, a lot of times it can be remedied by simply repairing the solder...although Bosch recommend`s replacing the control and I don`t pretend to speak on there behalf nor do I profess to know better. This is just my experience (it work`s) and my opinion (why buy new if one can repair ?)**
**Please disconnect the power before attempting any service to the dishwasher. If you do not feel comfortable attempting this service, call a local pro, preferably one familiar with Bosch/Thermador/Gaggenau, to service your machine.**
Hope this answer`s your question's, let me know if I can assist you further. Thank`s for visiting "fixya" for your repair inquiries.
Please take a moment and rate this solution to it's helpfulness to you and leave a testimony if you're satisfied.
Good luck.
Macmarkus :)
Posted on Sep 04, 2010
I have a Bosch Exxcel front loading washer dryer and can't remove the detergent drawer to clean it, plus all washing cycles take well in excess of 2 1/2 hours to complete. Annoying
Normal wash loads do not take over one hour, but you have to set them on clean any stain option and it will take 107 minutes to wash.
It sounds to me like your washer needs servicing by a trained Bosch serviceman, because it should not do this.
Jun 26, 2017 | Bosch Washing Machines
How do i operate the self cleaning function
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Freezer door was accidentally left open for about one hour. Now the refrigerator and freezer are not cooling.
If the freezer or fridge door remains open for one hour or few more hours by mistake, then to again get to its proper cooling cycle, it requires approx another 24 hours.And in that also, dont open the refrigerators doors for few hours.If you open, close it quickly.Once it cooling cycle again gets set, then you can use it like you use regularly.But approx it takes 24 hours to get proper cooling.-------- ------------------ But if its already more then 24 hours and there is very low cooling, then it can be internal defrost cycle issue.You will have to do manual reset procedure.The manual reset procedure is as follows:-------- First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check,it will get set to its cooling cycle and work as normal.------------- This should help.Thanks.Helpmech.
May 04, 2011 | Refrigerators
Lost Manual and would like instruction on how to set for self clean cycle?
Make sure you have everything out of the oven, including the oven racks.
1. Press SELF CLEAN.
2. Press the TEMP/TIME "+" or "-" arrow pads to enter the desired self-clean cycle.
3. Press START.
The oven door will automatically lock. The DOOR LOCKED and CLEAN indicator lights will be
displayed.
4. When the self-clean cycle is complete and the oven cools, the DOOR LOCKED and CLEAN
indicator lights will turn off.
5. When the oven is completely cooled, remove ash with a damp cloth.
Recommended times are 2 hours 30 minutes for light soil and 4 hours 30 minutes for heavy soil.
If your oven has a HI and LO self clean time, HI is 4 hours 30 minutes and LO is 3 hours 30 minutes.
It is also recommended that you remove anything plastic from the top of the stove during cleaning.
Nov 27, 2010 | Whirlpool RF263LXTQ Range
My self-cleaning oven has been on for 2 1/2 hours. Is that too long? If so, shouldn't it turn off automatically. Please advise.
If the model number you listed this question under is correct, the Clean cycle time NORMALLY takes about 4 hours and 20 minutes. You can adjust the cleaning cycle time between 3 hours and 5 hours and 59 minutes, using the HOUR and MIN pads. Once the cleaning cycle is complete, and the oven temperature cools to a safe temperature, the latch can be opened.
These instructions are listed on page 24 of the owner's manual. If you no longer have an owner's manual, you can obtain a FREE copy at managemylife.com. For your convenience, here's a direct link:
http://www.managemylife.com/mmh/owner_manuals/3453/GE-Free-Standing-Electric-L0904261?brand_name_search=jbp78
If you have questions, please post back and let me know. I hope this helps you.
Oct 25, 2010 | GE Spectra JBP78 Electric Kitchen Range
Run cycle goes for 2 hrs or more
In the last ten years the machines have been using a water heat feature. The water will heat roughly 1 degree a minute so depending on the installation and temperature of the incoming water, a complete cycle can be 90 min to over 4 hours.
Eric
Jan 12, 2010 | Kenmore Dishwashers
My GE drop electric range will not turn on the self cleaning unit. I set the time and push start and it flashes clean oven, door lock, however, the door will not lock. I hear a clicking sounds, it beeps...
You will need to press the stop/cancel button, next press the self clean button, you do not have to set the time the cleaning cycle takes approx 3-1/2 to 4 hours and the cool down takes another 45 minutes to one hour, it will clean and cool down and you do not need to interrupt this cycle, it will let you know when it is complete.
Nov 14, 2009 | GE Profile JTP18 Electric Single Oven
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Whirlpool Flat top Accubake self clean 24 inch
Of course - Empty the oven and clear off around it.
The AUTO-CLEAN cycle time is adjustable, from 2 hours
30 minutes and 4 hours 30 minutes in 15-minute increments.
Suggested clean times are 2 hours 30 minutes for light soil and
4 hours 30 minutes for heavy soil. The last 30 minutes of the
cycle is for cool down.
To Self-Clean Using AUTO-CLEAN
1. Press AUTO-CLEAN.
2. Press the TEMP/HOUR “up” or “down” arrow pad to set the
desired self-clean cycle time.
3. Press START.
The oven door will automatically lock. The “DOOR LOCKED”
and “CLEAN” indicator lights will be displayed. The time
remaining will also be displayed.
the “DOOR LOCKED” and “CLEAN” indicator lights will turn
off.
5. Once the oven is completely cooled, remove ash with a damp
cloth.
To Delay Start Self-Clean Using AUTO-CLEAN
2. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired self-clean cycle time.
3. Press START TIME.
4. Press the TEMP/HOUR “up” and “down” arrow pads to set
the desired start time.
5. Press START.
The oven door will automatically lock. “DOOR LOCKED” and
6. When the self-clean cycle is complete and the oven cools,
off.
7. Once the oven is completely cooled, remove ash with a damp
cloth.
Owner, Warranty, Installation and Parts manuals are here:
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=sf362lxst&siteCd=WHRCOM
Sometimes search links don't work when copied.
Here is the direct link to the Use and Care Guide:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%20W10110369.pdf
Page 16 has the above instructions.
God Bless!
-Ptochos
Jun 19, 2008 | Whirlpool GR399LXHS Electric Kitchen Range
Bosch SHU5315UC Dishwasher Logo
602 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
