Question about Whirlpool MH7155XM Microwave Oven
Microwave comes on but does not heat anything. Is 10 years old
  • Whirlpool Master
  • 3,051 Answers
Hello there:
If it It sounds normal,and seems to run ok but there's no heat When the microwave sounds okay, but there's no heat, one of the internal door switches, the high voltage circuitry, or the megatron or power inverter or the circuit board may have a problem. To resolve this problem, you need the assistance of a qualified appliance repair technician. ok hope this helps best regards mike
Posted on Aug 30, 2010
My 10 year old GE Spacemaker XL1400 microwave has stopped heating the microwave's contents.
probably a magnatron failure
take it to an appliance repair shop for a proper diagnosis and get a quote as repairs can be more expensive than new unit
Nov 24, 2015 | GE SpaceMaker Microwave Ovens
I was heating my tea and I heard a loud pop and the unit turned off...I thought I had blown a fuse and went out and checked fuse box..flipped all fuses and microwave still not turning on at all...micorwave...
The description you provide indicates the magnetron has failed, "heats food" and blown the main fuse in the microwave oven, since the unit is 10 years old it is much cheaper to replace with a new one rather than have it repaired.
May 15, 2011 | Amana Radarange Microwave Oven
Buzzing sound... Turntable stopped. food heats up but uneven. No microwave fan when heating.. no light inside expensive fix?? Unit is 10 years old
If the microwave oven is 10 years old then it is time to consider a new unit, by your description it is going into cascade failure where different parts have stopped working, the buzzing sound is the magnetron warning you, it is about to fail. The fans job is to keep the magnetron cool while it is running.
Mar 08, 2011 | GE JVM1850 1000 Watts Microwave Oven
Sparks are coming from the bottom of the microwave
generally the microwave will only spark if there is metal on the container you are cooking with or you are operating it without anything in it. as it is that old and with all the advances they have made with microwave ovens ... if it is in the budget i would certainly suggest getting a new one
Jan 17, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Turns on but not heating food sounds a bit louder
Hi, this is common in most microwaves. this abnormal noise is coming from a faulty Magnetron. this device is responsible for the heating process and, it is damaged and not heating at all at this point.Simply replace the Magnetron and, this unit will start to heat once more.
May 31, 2009 | GE Profile Spacemaker Over-the-Range...
Microwave won't heat anything
Yeah, it's time to invest in a new oven. The magnetron tube in yours most likely just finally wore out. It's the source of the microwaves, and like any tube it gets weaker with age and finally just quits altogether. It would cost more for a new magnetron than it would for a new oven these days.
May 15, 2009 | GE Microwave Ovens
Microwave on w/light but fan and heat not working
The problem is the door switch is defective. I'm on my third new switch in 3 years. The part number is 5304440026.
Mar 29, 2009 | Electrolux Microwave Ovens
Microwave lights and buttons work but doesn't heat up anything
When you start the microwave say for 1 minute. Listen closely when you hit start, the light should come on and about a 1/2 second later you should hear a little click and a slight hum. This means the controller is turning on the high voltage transformer and that part of it is working. My guess is that the magnatron is bad. That's the most common problems with all brands of microwaves. The mat on the top should not have caused the problem since the microwave has heat shutdowns in it. I would say that it's a 90% chance it's the magnatron. Most microwaves have a 5 year warranty on that part. Look at your owners manual. Good luck.
Scott
Jan 23, 2009 | Amana Radarange Microwave Oven
Whirlpool MH7155XM Microwave Oven Logo
101 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
