Question about Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator
The part where you would press to get ice, well up in side is not releasing the ice and closing back
On mine, using crushed ice will cuase a build up of ice along the shoot. I take off the storage bin and manually open the door cleanining out the shoot. Make sure to check under the removed storage bin before replacing.
Posted on Sep 05, 2010
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
I have a GE GSS25TSRD SS refrigerator. The cubed ice dispenses properly but crushed ice is not working. Any thoughts?
Remove the ice bin and move the metal bar that sticks out the back of it up and down. It should move easily and spring back. If ok look at the white plastic square piece below auger where the metal bar inserts into when bin is in place. You should be able to lift that up and down easily. If its stuck it probably needs replacing. If thats ok then press the freezer door switch in while pressing the dispenser paddle for cube ice. The white plastic part should move up the down when paddle is released. If no movement the solenoid is bad for it or its not getting voltage.
Sep 12, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker will not make ice cubes, only crushed ice.
take out your ice bin the look in the back of the freezer and ytou will see a small hole with a plastic sqaure actuator.hold the door switch closed and make sure the unit is selected for cubed ice then try and dispence ice if the swaure plastic acuator moves up it is working fine it shoeld drop down when you release the dispencer arm.if it dropps back down then make sure that the metal bail arm is properly inserted into the hole in the auger case when that actuator moves up this opens the small plastic door on the ice bin to allow subed ice to come out.make sure there is no ice build up on the ice bin that would stop the trap door from opening.good luck with you fridge i hope this helps you out,let me know how thing s go for you.
Jan 20, 2010 | Frigidaire FRS23H7C Side by Side...
Ice maker makes ice but will not rotate and dump the ice.
You have a thermostatically controlled heat release ice maker. Any number of issues can cause a failure to "dump" the ice. The harvest is started when the thermostat closes. A motor rotates the ejector fingers which are at rest in the 2 o'clock position. The ice maker operation will stall until the heater releases the ice from the mold. After the cubes are ejected into the ice bucket, the water valve will refill the mold with water to begin the next cycle. Lack of ice dispensing could be a failed thermostat, heater, motor or switch contact withing the ice maker module. You could simply replace the ice maker and save the expense of the service call.
Dec 29, 2009 | Maytag MSD2756G Side by Side Refrigerator
Ice maker door does not close all the way and the ice maker switch that releases the ice when press does not work all the time
Sounds like your saying that the ice dispensor flap is not closing completely which will cause frost on the inside shoot and on the ice bucket . Could be because of a broken guide ( clear plastic piece attached to the ice dispensor arm ) . Need brand and model number to help .
Aug 20, 2009 | Whirlpool Refrigerators
Panel flashing, ice door opening and closing constantly
That is a faulty icemaker solenoid switch, or a contact on wiring.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Jan 10, 2008 | GE Monogram ZISS480DRSS Stainless Steel
Ice Maker Not Working
Vik, the ejector blades should be pointing toward you in the 2:00 position when the ice maker is home. This tends to make me believe that your module is bad. Pull the ice maker out again and check the center white gear. There should be 2 clips holding it on. If one of those clips broke, the gear will not rotate right. Another thing you mentioned is that you had water on the back side where the line goes into the fill tube. You may have a frozen inlet tube too. If the tube is frozen, the pressure will force it out the back by that connection. Pulling that tube out can be a pain, try using a hair dryer if the baster not working. On this model, you can't just jump T&H to start the cycle because of the immiters. Follow these instructions to start a cycle.
To jump start the ice maker do the following: Unplug the refrigerator. With the ice maker out of it’s mount but connected to the harness use a insulated jumper wire stripped a quarter inch on each end and place the jumper in the holes marked T & H on the module. Place the ice maker with the jumper in, on the shelf with enough clearance to close the freezer door. Close the freezer door. Plug the refrigerator back in and wait 50 seconds. Now open the door and see if the module is rotating. If so remove the jumper, put the cover back on the module and place the ice maker back in its mount. The water fill should take place when the ejector blades are at the 12:00 position. Note that on some models, after you have done the aforementioned proceedure you have to press and release the light switch 3 times for the module to start.
Dec 02, 2007 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Frididaire Gallery series side by side with ice and water in the door
First pull out the ice bucket and close the door.  Set for cubed ice.  Press the button for ice to come out and listen for a loud clunk noise.  That is the sound of the solenoid.  You can open the door, hold the light switch and press the button and watch for the solenoid moving up and down.  Solenoid is at the back of the freezer in a little square opening where the rod on the ice bucket goes into.  If that solenoid is moving ok then put the bucket back in while the solenoid is in the down position and cubes should work.  If solenoid is not working then it will need to be replaced.  Let me know what you find.
Oct 14, 2007 | Frigidaire FSC23F7D Side by Side...
Whirlpool side-by-side refrigerator ice dispenser
Oct 13, 2007 | Whirlpool Gold White-on-White 21.9 cu. ft....
Kenmore 5553 / 655532 / 55534 / 55539 Side by Side Refrigerator Logo
146 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
