Question about Craftsman 17765 Canister Wet/Dry Vacuum
IS A CRAFTMAN SHOP VAC MODEL 500A THE SAME AS THE 17765 MODEL?
2 Suggested Answers
Richie_asg1
  • 1036 Answers
SOURCE: old shop vac
Yes there should be a filter fitted onto the top section.
For suppliers, it would be cheapest to find your nearest stockist, or buy online and have it shipped. It's still current stock - so spares should be readily available.
Sears stock it -
CRAFTSMAN FILTER
Thank you for using Fixya,
Posted on Sep 22, 2009
How to replace the swith vacum craftman model113.177765
I suggest you go to Sears repair parts website. They have parts for most stuff they sell, plus a lot for other appliances, etc. I hope this helps.
Apr 01, 2014 | Craftsman 17765 Canister Wet/Dry Vacuum
Switch bad on shop vac how do i bypass it
Remove the switch (with unit unplugged) remove wires from switch and solider the two together
Nov 08, 2013 | Craftsman 17765 Canister Wet/Dry Vacuum
Need filter for craftsman6hp. 16 gal shop vac model 113.177060
They're availabe at Sears and Kmart. Lowes and Home Depot also have filters that will work.
Dec 27, 2012 | Craftsman 17765 Canister Wet/Dry Vacuum
Step down 2 1/2 inch hose to 1 1/4 or to fit household vacuum accessories
Adapters are commonly available for canister vacs. Shop Vac is one such brand
Dec 25, 2012 | Craftsman 17765 Canister Wet/Dry Vacuum
Shop-vac model 500A 52713-75
what is the problem ?
God bless you
if if suction, test the hose blockage 2) belt drive is worn 3) power brush dirty, clean or replace, 4) test the motor for repair, clean, and lube.
see the diagram
Sep 06, 2012 | Shop Vac Vacuums
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Old shop vac
Sears stock it -
CRAFTSMAN FILTER
Sep 22, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
I need to replace a brush to operate the shop vac. Where can I find it?
true value hardware stores have books to order these parts , piar of brushes are between $3 -$7 ,also most vaccume sweeper shop
Jul 13, 2009 | Craftsman 9-17765 12 Gallon Wet/Dry Vac,...
Craftman Canister Wet/Dry vac- Motor just stopped working
It is Repairable But, The parts will cost almost as much as a New Vac. I would just get a New Vac and save the Hastle and the Cash. The choice is all yours Though. Please Rate My Response! Thanks!
Feb 07, 2009 | Craftsman 17765 Canister Wet/Dry Vacuum
Shop vac
the neoprene sleeve used as the filter may have come off the cage. there's a plastic ring that fits over the filter and cage and holds it in place. as far other suggestions, use an old cotton sleeve from a pajama top. tie it off one end, slip it over the cage and fasten with a large wide rubber band.
Sep 03, 2007 | Craftsman 17765 Canister Wet/Dry Vacuum
Craftsman 17765 Canister Wet/Dry Vacuum Logo
44 people viewed this question
Top Craftsman Vacuums Experts
Tim Doolittle
Tim Doolittle
 steve
steve
Are you a Craftsman Vacuum Expert? Answer questions, earn points and help others
