Question about Samsung Magnet SGH-a257 Cell Phone
Everytime I try charging my Samsung Magnet it reads the battery temp is too high or low. Does that mean I need a new battery? thanks
  • 4,102 Answers
Hi, yes it does it indicates one of two things, it can either be that your battery and your phone has got hot and this has caused bad cells in the battery, or it could just be that you have got bad cells in your battery due to normal use, it does happen from time to time.
all you need to do is go and purchase a new battery then this will solve your problem.
a little trick though so remember this.
once a month let the new battery go totally flat let it go that flat that it wont switch the phone on when you press the on button, then do a full charge, if you do this say every 4 to 6 weeks then this will ensure you battery lasts longer and it will hold its charge a lot longer and it will also prevent it from getting any bad cells.
let me know if you need further assistance ok
plz rate this solution as i have a whole page of unrated posts, thanks
Posted on Aug 30, 2010
Testimonial: "Thank you, I will be purchasing a new battery and taking your advice on charging every 4-6wks"
Low side reads 60.65 high side reads 350 and up compressor runs all the time
Hi, That may mean a low charge, but it depends on what refrigerant you have and the indoor and outdoor temps.
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Aug 16, 2011 | Heating & Cooling
My fujifilm 10.2 camera has a flashing red light everytime i try to switch it on
Red blinking light according to the manual means low battery. Charge it up and try again. If you have tried to charge it, you may need to replace the battery.
Mar 03, 2011 | Cameras
My car recently had an issue with charging the battery. We replaced the altenator. That did not fix the problem. Batter was still not getting charged. So we got a new regulator. Still nothing. I...
ALL OF THE FUSES NEED TO BE CHECKED WITH A FUSE TESTER. THERE ARE FUSES UNDER THE HOOD & INSIDE THE VEHICLE. ALSO, WITH THE MOTOR RUNNING AT A HIGH IDLE, PUT A VOLTMETER ON THE BATTERY. IT SHOULD READ BETWEEN 13.80 & 14.90 VOLTS. IF IT READS LOWER THAN 13.0 IT IS NOT CHARGING. IF IT READS TOO LOW MEASURE THE VOLTAGE AT THE ALTERNATOR WITH THE MOTOR RUNNING. IF IT READS TOO HIGH THE ALTERNATOR IS CHARGING BUT THE VOLTAGE IS NOT GETTING TO THE BATTERY. YOU MAY HAVE TO REPLACE THE WIRE BETWEEN THE ALTERNATOR & THE BATTERY.
Jan 18, 2011 | Honda Accord Cars & Trucks
Charger is not workking
Sometimes, the power supply to the charger might be too high or too low hereby resulting in damaging the charger. I will advice you test the charger on another phone before you conclude that the charger is bad. Once You have confirmed that. The only solution is to replace the charger. Once you have confirmed that the problem the problem is from the charger. Then You test the battery and the phone to know where the problem is from.
To test the battery,
  1. Power off the phone,
  2. Remove the battery,
  3. Insert it in another phone,
  4. Try to charge it with another charger,
If it charges, then it means the battery is working, but if it does not, then it means the battery is bad and need to be replaced.
Further test the phone,
  1. Insert a well tested battery into the phone,
  2. Plug a well tested charger into the phone to see if it will charge,
If it does not charge, then it means the connection port is bad and if it does charge, then it means the problem is not from the phone.
Before the end of the of the tests, You will have detected the problem and the solution to any of it is to replace it.
Hope this helped. Thank You for using FixYa!!!
Jan 12, 2011 | Samsung A501 Cellular Phone
Charging paused. Battery temp. too high or too low
In my technical experience
this occurs mainly in the samsung mobile phone
it is not because of your battery.it is because one of your ic chip is being damaged......you need replace it.you can touch the phone internal chip and see which one of the chip is getting more heated up..you need to replace it..can you please tell me your model no.?so i may help you in chip replacement.
Jul 22, 2010 | Samsung Highlight Cell Phone
NOT COOLING PROPERLY. SUSPECT CHARGE SUPERHEAT TOO HIGH
take the temp and press reading as per manf. and cal actual superheat. what are the reading for amb, evap temp, pressures high low. Then adjust charge. you need to determine super heat based on dry bulb indoor and outside ambient the read suction line temp vs suction line pressure
Aug 09, 2009 | Goodman CLQ36AR49 Air Conditioner
Meter Explanation
You are correct on all accounts. A high number means you dying battery is sucking more juice from the Schumacker. A low number means the battery is not as thirsty. That's how I always think of how to read the meter on mine. Slow charge is a better, deeper charge. The quick charge will get you going, but you should maybe follow it up using the normal mode - car alternator and prolonged drive time. I never use quick charge, personally.
Apr 26, 2009 | Jeep Grand Cherokee Cars & Trucks
Can't get the power on...
I would try a new battery. How old is the battery? Your probably right about the battery not holding a charge.
Feb 17, 2009 | Samsung Cameras
Samsung Magnet SGH-a257 Cell Phone Logo
144 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
