Question about Vulcan Kitchen Ranges
Oven knob is stuck in the on position - Vulcan Kitchen Ranges
    Genius:
  • 1,417 Answers
what you are to do to resolve this problem is to carefully apply oil (mechanical or vegetable oil)on the knob then allow it for sometime then go back to it then also apply fill force on carefully on the knob to the order side (off) still it retune to it position.
thank you.
Posted on Aug 30, 2010
Why won't oven temp knob click into clean position?
The knob may have to be depressed to rotate it past a stop into cleaning position.
Dec 28, 2015 | Kitchen Ranges
How to light oven pilot
When the oven control knob is in the off position(vertical), turn it counter-clockwise to the next position. This is the oven pilot light. Push the knob down, and while holding down, push the red piezo ignitor button located behind the bottom plate under the oven door. This little door swings open top down, like the oven door. Push the ignitor repeatedly, while holding the knob down. If it doesn't light, or you smell gas, let it dissipate before trying again.
Jun 13, 2014 | Star Tri-Tsr-6 36" Gas Heavy Duty 6 Burner...
NEW WORLD - NW601FP Electric Oven
i believe after buying this oven that the left knob at turning clockwise position 1 is defrost which works by just blowing room temp air around, position 2 is oven on, position 3 is conventional grill must be used with door open and position 4 is fan grill can be used with door closed ,and the knob on the left is for setting oven temp and and turn fully round when using the grill to heat the grill
Jan 17, 2012 | New World Ovens
Bottom oven element stays hot will not cut off
In order for the element to stay on, the oven switch must be broken. No details are provided, but if your oven is like most, you have an Oven Selector knob for ~bake, broil, clean and another knob for Temperature selection.
Look at your Oven Selector knob closely to make sure it is not slipping on the shaft. It may be as simple as the knob being broken, and even though you are turning it to the Off position, the switch may still be on. If the knob is indeed turning the switch shaft, then it is most likely the switch stuck in the own position. Thanks for using FixYa.
Mar 03, 2011 | Ovens
I have a arrow oven and when i plug it in and turn the socket on the oven turns on even tho the oven is in the zero position
Most likely the fastening screws on your knob might have come loose and shifted position. Turn the knob anticlockwise i.e.towards left of "0" position and see whether it will move. If it does, then your knob is loose. If the knob does not use a fastening screw, then the spring clip/the center hole of the knob is enlarged resulting in the knob shifting position. Replace the knob.
Dec 22, 2009 | Ovens
Pizza, banana bread, etc. doesn't get done in the middle.
some oven temperature dials are adjustable by pulling knob off,turning a bit and pushing it back on in a different position.use an oven thermometer to determine the accuracy of your control knob.adjust knob or make note of difference between dial setting & thermometer reading.i.e.knob is at 350* thermometer says 300* set knob to 400* to achieve an oven temp of 350. could you E-mail me a slice of banna bread?
Sep 27, 2009 | Ovens
Oven Stays On When knob is in off position
My electric oven stays on and gets hotter and hotter even when knob is in Off position.
Mar 28, 2009 | Kenmore Kitchen Ranges
Oven will not shut off broiler element stays on
The control knob more than likely operates a relay that has gotten stuck in the energized position. If this isn't the case then the Temp sensor or thermostat probably shorted internally. Unplug the unit before attempting any work.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Jenn Aire lock for self clean in locked position
The LOCK INDICATOR light must be OFF. This can take up to one hour!!!
Do NOT force the door.
Leave the SELECTION and TEMPERATURE knob alone. The Temperature knob MUST be set to CLEAN
Indicator Light OFF, knobs set to CLEAN - OPEN the slide lever.
Lever open, set the knobs to OFF and away you go
Oct 26, 2008 | Jenn-Air Ovens
Retractable function selector knob stuck
problem is caused by the sprung mechanism within the control knob sticking remove the knob completly, try to squeeze together in your hand to release and then spray with a wd40 type product, if this fails you will need to replace the knob, the knob only pulls off. Engineer
Jul 02, 2007 | Bosch HES436U Electric Kitchen Range
Kitchen Ranges Logo
220 people viewed this question
Top Vulcan Kitchen Ranges Experts
Treefrog15
Treefrog15
Oloyede Monsuru
Dan Webster
Dan Webster
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
