Question about LG Washing Machines
Thermistor error on lg tromm wm2487HWM. I have the part here but dont know how to install it. please assist me if possible. thank you.
  • 5 Answers
SOURCE: LG Tromm washer WM2688HWM tE error code. Very easy
LG Tromm Washing machine te error. The manual says to call for service. Not much help there. The reason for the error is the thermistor circuit (resistive element that becomes less resistive as it increases in temperature). The thermistor acts as a heat sensor. In many cases, the error occurs because the wireing harness is too tight at the bottom of the drum and one of the wires in this circuit becomes disconnected with all of the movement of the drum (unbalanced load, normal cylcing etc).
1. Unplug the washing machine from the wall. The thermistor circuit is at line voltage (110 in the U.S.) and it will bite! So do this first before proceeding.
2. Move the washer out so you can get access to the back of it.
3. Remove the stainless panel (the one that is not painted, it is large (aprox. 16x18 inches). It is held in place by 4 phillips screws.
4. Locate the thermistor connection block near the bottom of the machine, at the center of the wash drum. It is the small white connector that has two wires running to it. One wire is dark blue, the other is light blue. Insure that neither wire has pulled out of the connector. If either of them have, repair the connector and provide enough extra wire ( aprox. 2") to provide cable relief.
5. If the cable connector and wires are ok, there are other solutions here that recommend either cleaning or replacing the thermistor.
Good luck to you.
Posted on Aug 04, 2009
SOURCE: We have an LG Tromm WM2487HWM that has an upside
We have the same problem on our washer - same model as yours. Home Depot has the warranty on this thank goodness we bought it. They replaced the motor and water pump - didn't fix the problem longer than a month. A new repairman has come out and says we need a new heater and thermistor (whatever that is - I checked - not a thermostat but possibly related??) Approx a $300 fix. Good luck.
Posted on Jul 22, 2009
  • 497 Answers
SOURCE: Error Code LE on LG Tromm WM2277HS
Locked motor error. Cause: The connector (3-pin), male,white) in the motor harness is not connected to the connector. (3-pin,female,white) of stator assembly. Or the electrical contact between the connectors. (3-pin,male,white) in the motor harness and 4-pin,female,white connector in the main PWB assembly is bad or unstable. Or the motor harness between the stator assembly and main PWB assembly is cut (open circuit) Or the hall sensor is out of order/defective
Posted on Sep 15, 2009
SOURCE: on my frontload LG tromm I have the error code EO it will
There is a filter on the bottom left of the machine. If you pop the door off you can drain it with the hose, then spin the black filter out of the housing. This may help. Keep a wet/dry vac handy.
Posted on Dec 21, 2009
heatman101
  • 43501 Answers
SOURCE: my LG tromm dryer wont heat and i don't know how ignite the pilot
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Jan 15, 2011
What does the code te on the LG Tromm washing machine mean?
The TE error or fault code is to indicate a defective water temperature sensing thermistor. The thermistor cannot be repaired and will have to be replaced.
Sep 07, 2014 | LG Washing Machines
I have a LG WM2487HWM front load steaming washer. It has had the regular odor/mildew/mold problem from almost the first month. Recently the machine has struggled with draining all the water. Now it leaves...
Leave the door open for 24 hrs after wash for Odor problem. You need to clean the rubber gasket around the door with 1:4 Bleach/Water (It's Fun!...Not!) First though. Not draining? You need a New Drain Pump! Go to YouTube and place LG Washer not draining. They have 20 videos on how to repair...Very Easy!
Oct 20, 2013 | LG WM2688HWM TROMM SteamWasher
Error code te for lg tromm front load washer wm2496hsm
The TE error code is a Thermistor error. Replace the thermistor and you should be good to go.
Feb 29, 2012 | LG WM-2032H Front Load Washer
Have an lg tromm washing machine wm1814cw, it has an error code of ce, what is that.
'ce' stands for Current Error i.e. the motor (or something else) taking too much current to run requiring a service engineer's attention I suggest ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 08, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm washing machine model WM2487HWM has an error code. First letter looks like a capital E without the top horizontal line. second letter is an E
That's 'te' standing for temperature error/ heating error. Before you call an engineer try emptying the washer then pouring a couple of kettles of boiling water into the drum and leaving for 30 minutes then see. Another thing is to empty a couple of packets of limescale remover into the drum together with a couple of kettles of boiling water (again!) and leaving overnight. It possibly needs de-scaling anyway ;-0) If these fail it will be an engineer call, sorry ;-0(
Good luck, John C
Mar 22, 2011 | LG WM2487H Front Load Washer
Te code is showing up. how do i fix this
Sorry to read about your problem, I hope this helps you out.
The te code means a defective thermistor. but thermistors rarely fail in LG washers.
The most likey cause of the "te" error is:
1) Loose wiring at the control panel (directly behind the CYCLE SELECTOR KNOB)
2) Broken wire at the THERMISTOR (located at the bottom /front of the tub)
Test the washer. If the "te" error still occurs--it will be neccesary to remove the FRONT PANEL as well (two sets of special plier-type tools are needed).
Inspect the THERMISTOR closely--with good lighting. If there's a break in the wire it will be at or near the black sheathing / heat shrink material.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
LG Tromm washer WM2688HWM tE error code. Very easy to remove and replaced the thermistor, BUT still, it's not working, tE error code still there. ????????????
Good luck to you.
Jul 17, 2009 | LG WM2688HWM TROMM SteamWasher
We have an LG Tromm WM2487HWM that has an upside down f and e error code. The machine will sometimes start and then quit after about a minute into the run. Unplugging and replugging in does not seem to...
Jun 20, 2009 | LG Washing Machines
Need Directions on how to use machine
Hello maemaez4,
I will put a link below which will take you to a web page with a downloadable PDF owners manual for the Tromm. You will have 4 different options,( WM2487HRM, WM2487HRMA, WM2487HWM, WM2487HWMA ) just click on the model of the one you have and it will give you the correct manual. Hope this is what you were looking for.
http://us.lge.com/support/download/search/1000000376_EN_OM_WM2487.jhtml
Thanks,
edgin96
May 19, 2009 | LG Washing Machines
Washing Machines Logo
386 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
