Question about VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
Set ip address on vx570 - VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA)
Find proxy server address
Changing TCP/IP settings Win 7 TCP/IP defines how your computer communicates with other computers.
To make it easier to manage TCP/IP settings, we recommend using automated Dynamic Host Configuration Protocol (DHCP). DHCP automatically assigns Internet Protocol (IP) addresses to the computers on your network, if your network supports it. If you use DHCP, then you don't have to change your TCP/IP settings if you move your computer to another location, and DHCP doesn't require you to manually configure TCP/IP settings, such as Domain Name System (DNS) and Windows Internet Name Service (WINS). To enable DHCP or change other TCP/IP settings, follow these steps:
  1. Open Network Connections by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, and then clicking Control Panel. In the search box, typeadapter, and then, under Network and Sharing Center, click View network connections.
  2. Right-click the connection that you want to change, and then click Properties. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
  3. Click the Networking tab. Under This connection uses the following items, click either Internet Protocol Version 4 (TCP/IPv4) or Internet Protocol Version 6 (TCP/IPv6), and then click Properties. 25e7e385-9327-4f7d-aab0-afa5aaf952ba_49.jpgThe Network Connection Properties dialog box
  4. To specify IPv4 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IP address automatically, and then click OK.
    • To specify an IP address, click Use the following IP address, and then, in the IP address, Subnet mask, and Default gateway boxes, type the IP address settings.
  5. To specify IPv6 IP address settings, do one of the following:
    • To get IP settings automatically using DHCP, click Obtain an IPv6 address automatically, and then click OK.
    • To specify an IP address, click Use the following IPv6 address, and then, in the IPv6 address, Subnet prefix length, and Default gateway boxes, type the IP address settings.
  6. To specify DNS server address settings, do one of the following:
    • To get a DNS server address automatically using DHCP, click Obtain DNS server address automatically, and then click OK.
    • To specify a DNS server address, click Use the following DNS server addresses, and then, in the Preferred DNS server and Alternate DNS server boxes, type the addresses of the primary and secondary DNS servers.
    f598cd96-6bf9-47be-942d-7d0b0afdbd88_47.jpgThe Internet Protocol Version 4 (TCP/IPv4)Properties dialog box
  7. To change advanced DNS, WINS, and IP settings, click Advanced.
Mar 10, 2014 | Dell Latitude D600 Notebook
How to set an ip address
To set an IP address in your PC Laptops (Windows 7, xp and vista) visit the site Howtogeek.com ,here they have given detailed procedure to sen an IP address of your own. After setting an IP address you can check it in two ways.
1)Go to Start-> Run-> Cmd Press Enter.. Type ipconfig or ipconfig/all command line to know your IP address.
2)Visit the site Ip-Details.com to get your IP address.
Apr 10, 2013 | Computers & Internet
What is the default ip address for powerconnect 5212
You must assign an IP address to the switch to gain management access over the network. You may also need to a establish a default gateway between the switch and management stations that exist on another network segment. You can statically configure a specific IP address or direct the switch to obtain an address from a Boot Protocol (BOOTP) or Dynamic Host Configuration Protocol (DHCP) server when it is powered on. Valid IP addresses consist of four decimal numbers, 0 to 255, separated by periods. Anything outside this format is not accepted by the CLI program. notice.gif NOTICE: By default, the IP address is assigned to VLAN 1 through DHCP. If you select the bootp or dhcp option, IP is enabled but does not function until a BOOTP or DHCP reply has been received. Requests are broadcast periodically by the switch in an effort to learn its IP address. (BOOTP and DHCP values can include the IP address, default gateway, and subnet mask).
To display assigned IP settings using the CLI:
  1. From the Privileged Exec or Normal Exec level mode, type show ip interface and press <Enter>.
The assigned IP address and subnet mask displays.
  1. From the Privileged Exec mode, type show ip redirects to display the assigned gateway IP address. Press <Enter>.
The following example displays IP settings assigned by bootp or dhcp using the CLI.
Console#show ip interface
IP address and netmask: 10.1.0.1 255.255.252.0 on VLAN 1,
and address mode: User specified.
Console# show ip redirects
ip default gateway 10.1.0.254
Console#
Before you can assign a static IP address to the switch, you must obtain the following information from your network administrator:
  • IP address for the switch
  • Default gateway for the network
  • Network mask for the network
To assign a static IP address to the switch:
  1. From the Privileged Exec level global configuration mode prompt, type interface vlan 1 to access the interface-configuration mode. Press <Enter>.
  2. Type ip address ip-address netmask, where ip-address is the switch IP address and netmask is the network mask for the network.
  3. Type exit to return to the global configuration mode prompt. Press <Enter>.
  4. To set the IP address of the default gateway for the network to which the switch belongs, type ip default-gateway gateway, where gateway is the IP address of the default gateway. Press <Enter>.
  5. To save your configuration changes, type copy running-config startup-config and then press <Enter>.
notice.gif NOTICE: Only one VLAN can be assigned an IP address. If you assign an address to any other VLAN, the new address overrides the original IP address. The following example shows how to set a static IP address using the CLI.
Console(config)# interface vlan 1
Console(config-if)# ip address 192.168.1.5 255.255.255.0
Console(config-if)# exit
Console(config)# ip default-gateway 192.168.1.254
Console(config)#
To configure the switch for DHCP or BOOTP:
  2. At the next prompt, use one of the following commands:
    • To obtain IP settings through DHCP, type ip address dhcp
    • To obtain IP setting through BOOTP, type ip address bootp
  3. Press <Enter>.
  4. To save your configuration changes, type copy running-config startup-config, and then press <Enter>.
Nov 26, 2012 | Computers & Internet
Invalid ip address
im thinking your Credit processor IP settings have changed or your ternminal for some reason is not seing your processor IP settings and port. Calll your processor, and maybe you will need set the right IP address manually to your machine or they might ask you to redownload the application. Call (775) 358-2922 ask for Randy and maybe we can help you. Thanks
Jan 31, 2012 | VeriFone VX570 Credit Card Terminal (Dual...
My Verifone vx670 needs to release and reestablish it's IP address frequently for wireless communications and after taking a vacation I forgot the key combinations to perform it!
I also need to change the network settings on my Verifone VX 670 as i have recently installed a new wifi connection. Any help would be appreciated!
Aug 31, 2010 | VeriFone VX570 Credit Card Terminal (Dual...
No IP address was set
Turn off DCHP after setting the IP address
Sep 21, 2009 | Toshiba E-Studio167 Copier
Dell 5100cn change ip address
Changing Printer's IP Address isn't that complicated. There are two ways on how to change the printer's IP Address.
If you know the old printer's IP address, you can simply type that old IP address on the Address Bar of your Internet Explorer or any other browser (ex: http://192.168.1.101). It should redirect you to the printer's User Interface. From there you can go to Network then TCP/IP settings. You can change the IP address of the printer. Make sure to use an IP address within the same range of your network.
The other way to change the printer's IP address is by its own Menu/Settings on the printer's LCD panel.
On your printer, press Menu then got Settings. Look for Network or LAN settings and click on Advance. Select TCP/IP and click on Edit. You can now change the IP address of the printer from there. Click on Done or Save after that.
Note: Make sure the use the correct IP address within the network's range.
Jul 16, 2009 | Dell 5100cn Laser Printer
How do I place a decimal point with Vx570 Verifone
you have to press the #1 key and then the alpha key till the decimal point appears.
Mar 20, 2009 | VeriFone Omni 3700
I can not connect to the local area connection.
1. check your network adapter TCP/IP settings if its set into "Obtain as IP address Automatically".
2. if the settings is set as Automatic and your not getting IP address then select "Use the following IP Address"
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 justcheck the next address IP in your network.
4. after typing subnet IP will automatically set
5. type the router IP address as your default gateway
6. click OK to save your new settings
hope this will help you
Nov 26, 2008 | NetGear WGR614 Wireless Router
Wireless router won't connect to my laptop
3. use IP address followed to your router address like if192.168.0.1 in router type 192.168.0.2 or192.168.0.3 just check the next address IP in your network.
Hope this will help
Nov 24, 2008 | Arris WR850G Router (DHWR850G)
VeriFone VX570 Credit Card Terminal (Dual Comm DCSC) (M25755302NAA) Logo
625 people viewed this question
Top VeriFone Computers & Internet Experts
ray gallant
Are you a VeriFone Computer and Internet Expert? Answer questions, earn points and help others
