Hello, do you know how to reset drum of Oki Es 8460 Mfc? Oki Es 8460 Mfp? Thanks You
SOURCE: reset drum - brother mfc-8860dn
Open front cover
Remove drum unit and toner cartridge assembly
Put drum unit and toner cartridge assembly back in machine, but do no close front cover.
Press Clear/Back
You will get a message "Replace Drum?"
Select Yes to confirm
Posted on Mar 16, 2008
SOURCE: HELP! Brother MFC-8460 "Toner Life End" won't clear
The problem with a new toner cartridge that will not signal the printer that it has been changed has to do with a gear positioned wrong on the new or rebuilt cartridge... we had 3 factory brand new toners that would not clear the replace the toner message... I finally found the following link that came from a toner company that sells refills that tells how to reposition the gear to let the machine know a new cartridge has been installed. I did the proceedure on pages 5 & 6 having to reposition the gear and all cartidges then worked flawless... it works.
http://www.castleink.com/265/cartridge/TN580.pdf
Posted on Sep 23, 2008
jtuminaro
  • 56 Answers
SOURCE: RESET DRUM
Open the front door where you put the toner/drum unit in the machine. Press options then press 1.
Close the door.
Counter reset!
Posted on Jan 15, 2009
  • 628 Answers
SOURCE: OKI c5600 drum reset
It usually resets automatically when you replace the drum/toner units. Are you trying to get it to reset before it's supposed to? I don't know of any way you can do that.
Posted on Apr 20, 2009
SOURCE: oki b4600 drum reset ?
On the printer press the menu button until you reach MAINT.Then press the item + button until you reach DRUM CT RESET. Then press select.YOUR DONE!!!!!!!!
Posted on Jul 09, 2009
How to reset drum life on brother 8460
first open the front cover, Then press the clear\back button. When the machine displays "replace drum? press *00 and close the front cover
Aug 16, 2014 | Brother MFC-8460N All-In-One Printer
How to reset drum error on oki c5550n mfp
Hi Eric, what is the exact drum error you have? CMY or K?
Aug 02, 2014 | Oki Electric Industry Okidata C5550n MFP...
Oki C5350 error 563
563 I usually drum code reset, some OKI machine have sensors in the side frames they look like a little round window, clean with Q tip, I will assume you have replaced the drum, right?
May 05, 2014 | OKI C5510 MFP All-In-One Led Printer
Brother Model MFC-8460 drum reset
Open front cover. The one you use when you replace the toner, while open hit the clear button the machine will ask if is a new drum and says yes and your good to go.
Feb 15, 2011 | Brother MFC-8460N Laser Printer
Reset the Drums on Okidata C5510 MFP Printer
Yes, you have to install a fuse in each drum unit, it's a littelfuse # 251-062. You can use google to find the procedure.
Jul 03, 2009 | OKI C5510 MFP All-In-One Led Printer
How to reset toner drum for the oki c5510 mfp?
. Turn machine on while pushing and holding the TWO up/down menu buttons at same time.
2. Menu window will show "OKI USER"
3. Scroll to " Engine Dialog Mode" is indicated. Push Enter button.
4. "Diagnostic Mode xx.xx.xx S-Mode is indicated.
5. Scroll to "NV-Ram initial" is indicated. Push ENTER.
6. Window shows "NV-Ram- Initial Table 1".
7. Push ONLINE and ENTER Buttons simultaneously and HOLD for 10 seconds after you see "Executing Reset" appear in menu window.
8. Restart printer.
All toner, drum, fuser and transfer figures return to 100
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 16, 2009 | OKI C5510 MFP All-In-One Led Printer
Dec 20, 2007 | Brother MFC-8460N Laser Printer
723 people viewed this question
k24674
jasbo
jasbo
