NEVER HAS BEEN FIXED THE PROBLEMS CONSTANTLY CHANGE THEREFORE TECH SUPPORT IS USELESS ONE WHOLE YEAR OF 100 HOURS OF TECH SUPPORT. DRIVERS HAVE BEEN DOWNLOADED FROM INTERNET SEVERAL TIMES AFTER FORMATING COMPUTER. THIS PRINTER MUST HAVE SOME MECHANICAL DEFECTS BUT HP WILL FORCE THE USER TO COMMIT SUICIDE BEFORE GIVING AN EXCHANGE PRINTER
  • 11,800 Answers
HP NEVER replaces a printer unless it's completely dead, and even then only if it's newer than 6 months - otherwise they will use replacement parts to fix it.
Since now its out of warranty they will not even be bothered to take a look at it.
Cut the problem to the root - junk this POS and buy a new printer. This will save you time and money that would be better used elsewhere.
Posted on Aug 30, 2010
What is the definition for controlled variable?
You have either constants or variables. Constants are things that does not change. Time is a constant - you can't move forward or backward in time.
Variables are parameters that change. Some variables are fixed, others can be controlled.
A controlled variable is a variable that can be changed at will or according to circumstance.
For example, if you have a radio with a fixed coil / tuning capacitor which can receive only one station, the variable (radio stations) cannot be controlled, it is fixed, therefore a fixed variable. A normal radio can be tuned to different stations, therefore a controlled variable.
The engine on a car has a controlled variable speed. A normal light bulb is controlled by a fixed voltage, until you build in a dimmer switch, which now makes the voltage variable, and controlled.
Nov 07, 2014 | Cars & Trucks
Display driver crash when playing sims 3
Hello, there are many reasons for a computer to lag and crash. But most probably is because the cpu could be working at 100%. If the cpu is working at 100%, you need to find out if it's Windows, or some kind of malware.
Please, search for "My cpu is working at 100%" and some instructions on how to identify the problem should be display.
May 14, 2017 | Dell Inspiron Computers & Internet
7 blinks of death Monday Aug. 8.Unplugged, waited,plugged back in, 7 blinks. Unplugged for several hours, plugged back in,again 7 blinks. Talked to a tech. After he researched, was told certain boards may...
just like crt tv units, plasma are old technology
besides that they use enormous amounts of power and are now a waste of time in repairing
If you leave it powered on , that is alright as the main destroyer of electronics is the constant on/off operation as the temp changes of the components is the problem
However knowing that it uses probably 100 times more power than a led unit, , you are having problems with it and knowing the price of parts , I would recommend considering a newer more economical unit of a quality brand
Mar 16, 2017 | Panasonic Viera TH-50PZ80U Plasma TV
We have the Kenmore progressive direct drive (bagless) and have had it for about 3 years. We have taken good care of it, and paid quite a bit for it hoping that it would last for a good long time. It has...
there has to be a clog or block somewhere - if the motor works, it should work did you try a wire coat hanger to go up in further where you cannot see?
Bets regards
Ck
Jan 15, 2011 | Kenmore Progressive Bagless Upright with...
My sony kdf e55a20 cuts on and off, but the lamp indicator never turns on
Order a new bulb, easy to replace, just read the manual. In the meantime, go into Settings and change the Power to Power Saving, instead of Standard. Your bulb will work fine until the new one arrives.
Dec 07, 2009 | Sony KDF-E55A20 55 in. LCD Television
My 3.5 year old wd-57731 has gone thru 6 lamps since purchase. I vaccumm the rear of the tv every month and the last tech that came out changed a sensor. TV is still under warranty. Any suggestions on what...
Howdy;
It is your ballast that is causing your short life of your Lamp. The original Part Number for the 'PWB Power' is 934C228001.
I have had this problem at least 100 times and it will give your Lamp a life of about 2 years, 5,500 hours.
Good luck with your Warranty Company, Big Irish.
Dec 03, 2009 | Mitsubishi WD-57731 57" Projection HDTV
Phaser 6110 - red light on, not printing
Just had user with same problem. Printer status = paper jam but no paper in feed path therefore suspect paper pick up problem. Asked user to take out paper tray and turn paper in tray over. This solved problem.
So possible fix = turn paper over or try different paper.
If printer is old try cleaning pickup roller. My users printer had only done 227 pages.
Sep 11, 2008 | Canon PIXMA® MP530 All-In-One Printer
KV 27S65 Sony Trinitron 27"
So far you have done all you can and you have done everything right. The fact that the TV turned off by itself and then turned back on by itself suggests that one or more solder joints have come loose inside the set. A qualified tech should find this easy to fix, and Sony sets are always worth repairing, so it is now time to have the set serviced by a tech experienced in Sony standard sets.
Sep 01, 2007 | Sony KV-36XBR400 36" TV
Toshiba 42H81 - Constant jumping picture on scren
it needs the hyper module replaced might as well have em do the stk packs too its too old to be a lemon the part that was replaced was not new it was in someone elses tv and had problems there too the trick is to find someone that will fix it so it lasts
Dec 05, 2006 | Toshiba 42H81 42" Rear Projection...
11 people viewed this question
k24674
