Question about Smeg 24 in. DWI612 Built-in Dishwasher
Hi my Smeg dishwasher (DWI612C) sounds as if its working when programmed and door closed but does not spray any water, after 5 mins on opening the door there is a small amount of water at the bottom.
  • 641 Answers
SOURCE: dishwasher leaves residue in top rack only
Most cleaning problems are caused by the dishwasher not getting enough water. It could be cause of the switch level, which control water level in the tub. The switch level is usually a diaphragm device with a small clear tube attached between the switch and the bottom of the washer's outer tub. I am not familiar with your machine, but if you will open the rear panel you will find it easily. Be aware you should discoonect the power cable !!! Clear the tube (attached between the switch and the bottom of the washer's outer tub) from any obstruction.In case it will not solve the problem, you should replace the switch. Good luck !
Posted on Jun 01, 2006
zeusfaber
  • 247 Answers
SOURCE: Smeg Dishwasher
This is usually the heating element - corrosion lets small amounts of water through the element jacket, making the mineral insulation inside slightly damp. When the machine applies power to the element, enough current leaks from live to earth to trip the RCD. In the absence of a proper electrician's insulation tester (a DVM in ohms mode doesn't test at a high enough voltage to give a meaningful result) the best way to prove this fault is to (carefully, and with the power off!) disconnect and tie back the wires that go to the element, then run the machine and see if it gets any further in the cycle. A.
Posted on May 17, 2007
  • 1462 Answers
you may have a foreign object stuck in the pump. it may well disappear with time and it is an aweful job to get at
Posted on May 22, 2007
ginko
  • 19396 Answers
SOURCE: Machine won't drain fully
If the drain pump is working fine, and water flows from the machine and there are no clogged drain lines, then the problem is usually the water level sensor.
This is usually a floater sensor located on a side inside the dishwasher.
Check if water level is working properly, if the floater is too low then that is the problem.
Posted on Apr 07, 2009
  • 3600 Answers
SOURCE: SMEG DWI612C WON'T PUMP WATER OUT
even if the pump is running does not mean the impeller shaft is turning, You could unplug the machine and disconnect the washer and pull out and drop the hose to see if water will drain when you lower the hose to about 8 inch's does it run out freely? if not check for a plugged water pump or water pump hose if the water flows freely you will need to drain the washer if it's on rollers roll it out side to allow the water to drain out the machine from the porch. while it is draining check the hose that the washer connects to see if you see any plug in the pipe. put the sink drain plugs in and fill half way with water put a bucket under the sink after filling the water to half full pull the stopper out of the sink that connects to the dish washer. Hold your hand on the hole of the connection to the sing watch to see if the drain allows the water to flow. If it flows freely you can assume that the water pump is bad. If thats the case it's best find someone to replace the unit the pump can be replaced but you need tools to do so and you did not state if you had any. thanks for using fix-ya.
Posted on Apr 18, 2010
Smeg DWI612C not ending a cycle- it goes on for hours
Sounds like your Dishwasher may not be heating. If this is the case then it maybe the heater itself or one of the thermostats
Feb 03, 2013 | Dishwashers
Machine not takin any water
Before starting a washing program make sure that:
• The water supply tap is open.
• The correct amount of detergent has been added to the
dispenser.
• The baskets have been correctly loaded.
• The spray arms are able to rotate freely and without
obstruction.
• The dishwasher door is securely closed.
After you check all start the dishwasher again.
Jun 05, 2011 | Smeg 24 in. DWD1SSE-1 Built-in Dishwasher
Set dishwasher to start - sounds as if it starts but then 5 mins later beeps. When door is opened nothing has happened and instead of the i.e. P4 programme displayed E1 is displayed? Can you help on what...
Possible that there are no outputs from the program controller unit and so you will need to check with a multimeter the voltage to the inlet valve/motor while the washer starts. If there is no supply then the controller is faulty , if not check the inlet valve and the pumps for fault.
Make sure that the door switch is working as unless the switch latches the program controller will not work- safety feature.
Feb 14, 2011 | Smeg DWI614 Built-in Dishwasher
Water leaking out from inside onto floor
Check your spray arm that nothing got stuck in its holes. make sure the spray arm is turning all the time when using the machine :
put the spray arm in 90 degree position, turn the unit on , open the door after few min check that the spray arm move...
make sure your seal of the door is clean and nothing prevent it to close evenly the door...
good luck 911servicetoday . com
I hope you find this Very Helpful and best regards!
Apr 19, 2009 | Whirlpool GU2700XTSB / GU2700XTSQ /...
SMEG dishwasher - cycle buttons
What is the model of the dishwasher? Open the door and look down the right hand side for a sticker and repost please. As a rule number 3 is a normal wash :D
Mar 23, 2009 | Smeg 18 in. DWI410 Built-in Dishwasher
Smeg DI 612 C Domestic Dishwasher
I was told by a SMEG engineer that I needed to replace the detergent dispencer. Just waiting for him to get back with a new one.
Aug 15, 2008 | Smeg 24 in. DWI612 Built-in Dishwasher
Tecnik DW2677
check your water intake- i had the same issue - a leaky fitting wasn't supplying enough water to the dishwasher. had exactly the same symptoms you describe. fixed the leak, reset the dishwasher & it's working fine.
Oct 29, 2007 | Tecnik TDW2677 Built-in Dishwasher
Smeg 24 in. DWI612 Built-in Dishwasher Logo
32 people viewed this question
Top Smeg Dishwashers Experts
Cleverer2
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
