Question about Craftsman Air Tools & Compressors
My five gallon, one HP model 921.166360 won't build any more than 20 psi. Can't figure out why. thank you.
4 Suggested Answers
manhandy
  • 146 Answers
SOURCE: 1 HP 3 Gallon Air Compressor does not build up pressure.
it sounds like the regulator is out of whack turning down increases air pressure. make sure there is no leaks
Posted on Jun 28, 2009
  • 24 Answers
SOURCE: My compressor will not go
The problem with compressors not building pressure is usually a bad pressure switch or bad regulator. Does the motor shut off at 20psi or does it continue running and not build pressure? If the motor continues to run with no increase in pressure, the you should go over the machine looking for air leaks from your regulator back all the way to the motor. Any air leak while the compressor is running can cause the pressure to "peak" way before the intended shutoff that it is regulated to.
Posted on Mar 02, 2011
Hello I have a 20 gallon kobalt model 033204. I just replase pressure switch but does same thing. When I tur on the compressor jus build 50 psi and shuts off.
This usually occurs when the motors internal thermal / amp breaker opens due to overload or weak breaker. Use an amp gauge to test for too much amp draw. If amp draw is normal, then problem could be the in-tank check valve leaking pressure back to the pump overloading the system, or weak capacitor or weak breaker. Bypass the breaker temporarily if the amp draw is normal to test system. Good luck
Oct 31, 2015 | Psi Air Tools & Compressors
I have a 3 gal craftsman air compressor. Compressor runs but will not build more than 20 psi in tank reserve. Whats wrong?
if shuts down at 20 psi regulator is set wrong
it runs but only builds 20 psi, compressor is probably worn out
Oct 03, 2015 | Craftsman Air Tools & Compressors
Why will my bostitch pancake compressor 240 psi tank 180 regulator that the guages will not show building pressure
Hi, There are different posibilities. I would need more information. Was it always like that? Does the guage on the main tank and the guage on the regulator both not show more than 20psi? When the auto shut-off is triggered do you feel there is more than 20 psi in the tank?
Sep 15, 2014 | Stanley NEW Bostitch 2 HP 6 Gallon...
My compressor will not build up over 20 psi. seems like a lot of air is blowing out of exhaust, is this normal?
You may have the pressure release valve stuck open.
Check that. If it isn't stuck open. take it back to the place you bought it for a refund / exchange.
Jun 30, 2010 | Stanley NEW Bostitch 2 HP 6 Gallon...
Capacities and pressures of Ingersol Rand Air compressors
Model Number: SS3J5.5GH-WB Manufacturer: Ingersoll Rand Tank Size: 8 Gallons Engine Engine HP: 5.5 HP Engine Type: Honda GX 160 Fuel Tank: .8 Gallon Pump CFM @ 90 PSI: 11.8 Max Pressure: 135 PSI Certification: UL/CSA/ASME Overview Dimensions: 43" x 18" x 26" Product Weight: 175 lbs
this can be a reference.
May 06, 2010 | Ingersoll Rand SS3J5.5GH Wb Ir Portable...
I have a model 921.153101 compressor,3 gallon
the pressure regulator is at fault. It will need to be replaced
Mar 11, 2010 | Measuring Tools & Sensors
Air pressure does not go over 25 psi I have taken the whole unit apart and check, relief valve,regulator,check valve. Pressure switch, Piston & Gasket. everything seem good I have taken the pressure...
Does it shut off at 25 psi or just keep running and never build more pressure than that? Also, did this come on gradually or suddenly? Also, was it being used regularly when it happened or had it been sitting for a while?
Mar 07, 2010 | Craftsman 1 Hp, 4 Gal. Air Compressor
Jun 28, 2009 | Air Tools & Compressors
Air Tools & Compressors Logo
74 people viewed this question
Top Craftsman Air Tools & Compressors Experts
John Trevino
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
