Machine rumbles when spinning - Bearings? - Washing Machines
  • artificer195 Aug 31, 2010
    My machine is a Hotpoint WT540 - I'm pretty sure that the drum is a closed unit and you have to replace the whole thing as the bearings are inaccessible ? is this correct?
    Thank you
    President:
  • 670 Answers
You did not mention the make or model of the washing machine. Most likely if it is very noisy when in the spin cycle, it usually is the bearings that need to be replaced. It may not be cost effective to replace if you have a front loading machine, since some machines need the entire machine to be taken apart and the rear drum replaced. Get some estimates before considering having the work done on your machine.
Posted on Aug 30, 2010
  • Stephen Lam Aug 31, 2010
    The outer drum is a welded unit and can not be taken apart. You need to buy an entire replacement tub assembly. You have a couple of options, if your washer is less than 5 years old, it should be covered under the parts warranty. The parts are covered but, you will have to pay to have the tub installed.
    If it is older than 5 years and you have the ability to take you washer apart and replace the tub assembly, the cost is L119.99 at espares.com. My advice to you is to call the company and see what they can do for you first, then decide on your options. Sorry.
    Thank you very much for confirming my assumption.
    I will follow your advice.
    Thanks again
    kind regards
    Brian
Noisy spinning
First make sure that the load is balanced, if you are washing and spinning a dense load like trainers etc this can cause an imbalance. If you are washing a duvet cover or a pillowcase, make sure that the loose clothes washed with it haven't migrated inside the cover or case, this happens so easily. It is always worth checking that the support feet are all touching the ground when the washing machine is empty as this can cause excessive noise
hope this helpsKind regards ki
May 11, 2015 | Washing Machines
Spin Cycle is very loud on front load washing machine
See here
How to fit a Bearing in a Washing Machine | Appliance Repair Help
  • If a washing machine is rumbling, and very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Another drum bearing failure symptom is excessive up and down play in the drum which can be checked for by lifting the drum up and down from the drum lip behind the door seal. A further symptom of drum bearing failure can be a brown rust patch underneath the washing machine and down the back of the outer drum, underneath the drum pulley (where the belt goes) although this patch is not always present. There are usually two small holes at the back of the drum bearings where water that has got past the drum bearing seal trickles out, and it's usually stained with grease and rust if water has got into the bearings.
  • Loud noises when turning the drum by hand can also be caused if the drum itself splits, or the spider at the back of the drum has come away from the drum, is corroded or even broken. This would normally be a loud noise on each revolution of the drum whereas the noise when drum bearings have gone is constant all the time the drum is turning. Lifting the drum checking for excessive play can often reveal a broken or loose drum spider which sometimes only occurs at certain points round the drum (the spider has three arms and is bolted to the drum at three points)
From
DIY washing machine repairs (2)
for repairs check
Sep 04, 2008 | Washing Machines
Washer makes rumbling noise during spin cycle
You have to take the whole drum out and IT IS YOUR BEARING(s). Order all four of them
Oct 22, 2014 | Washing Machines
Why does my washing machine make a load noise on the last 6 minutes of the spin cycle..especially when I have bed linens in.
It is not unusual for a machine to make a lot of noise and jump about when washing sheets as they can sit out of ballance in the drum. That is why the drum turns to and fro and short spins trying to balance the wash. If how ever the noise is rumbling like a big lorry going by, then I'm afraid it sounds like your drum bearings have gone. Replace bearings by an engineer or replace machine either is expensive.
Oct 01, 2014 | Samsung Washing Machines
(washing machine )when spinning a large banging noise like the drum coming out
Spin the drum by hand from inside, if it feels rough or is rumbling or grating, then the main bearings have failed, a major repair involved.
Nov 28, 2010 | Hotpoint Washing Machines
Hi there my machine has gone very loud when spinning,washes perfect,any advice
Sounds like the main drum bearings have failed.
Spin the drum by hand from the front of the washer, if it feels rough, or is noisy or rumbling, then the the main bearings have failed.
A major repair!!!.
Jan 15, 2010 | Zanussi Washing Machines
Machine makes awful noise during any movement, spins very slowly, not enough to spin out. Making an awful noise, like stripped gears and won't drain
There are three reasons for such awful noise during spinning. Either the drum or the bearing turning the drum. Check for drum bearing failure if your washing machine is noisy on the spin cycle. Drum bearing failure is common when the bearing seals start allowing water to enter. You can take the belt off and spin the drum by hand, and if the drum rumbles, replace the bearings.
Thanks
Jan 01, 2010 | Washing Machines
What would make my washing machine leak water and make a funny noise?
this sounds like the main bearings have worn out (they start to rumble first) when they start to brake up they rip apart the water seals that are between them and the back of the washers drum, and then it starts to leak water, to test them to see if there claped out,,,, open the door and try lifting the top of the drum lightly , if it lifts a bit then drops back when you let go its the bearings going, now spin it by hand and you will here a rumbleing noise or grinding noise, when the washer is running on spin it will sound like the end of the world is coming???? im sorry to tell you this part is not cheep to fix, its 2-3 hours work?
Oct 22, 2009 | Kenmore Washing Machines
Washing machine noisy when on a spin
  • If a washing machine is very noisy on spin, the main suspect is the drum bearings. Drum bearing failure is common on many washing machines due to water getting into them if the drum bearing seal fails. (Hotpoint and Zanussi in particular in my experience) To check for drum bearing failure you can take the belt off and spin the drum by hand. If the drum rumbles when spun then the bearings may have gone. There should be a constant rumble all the time the drum is revolving.
  • Aug 28, 2009 | Zanussi ZWF1430W Front Load Washer
    Loud banging
    Several possibilities for noise. check concrete balance wieghts at top and bottom of washer, make sure they are not loose.
    Check drum restraint spring(s) are not broken.
    Check suspension legs for wear.
    Check for loose motor fixings.
    Finally, remove drum belt, and spin drum by hand, tjhere should be noise from bearings, if it feels rough or is rumbling , then main bearings have failed.
    Please rate my comments.
    Thanks.
    Jul 27, 2009 | Hotpoint Aquarius WD63 Front Load...
    Washing Machines Logo
    50 people viewed this question
    Top Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
