posted by mhussen on May 08, 2008
my kenmore rotating brush is not spinning at all, and its causing the motor to cut the belt. should i get a new brush?
Thank you.
Comment by mhussen, posted on May 09, 2008
reddevil6, i have Kenmore upright vacuum, model # 20.30005, what is the quickest way to get a new brush ?
Comment by mhussen, posted on May 13, 2008
reddevil6, when i check my vacuum's base label, the model # is
20.30005 , and i try to enter this number in sears.com , it gives me no results, what can i do to find the brush roll.
Best Solution
Sounds like the brush roll has an end that is melted or frozen up so it won't move, in which case you need to replace it.
Comment by reddevil6, posted on May 10, 2008
Go to sears.com, click on the parts link, put in your model number(look on the metal tag to get the correct number),then select the one that is yours, a parts list with a link for a picture breakdown will come up. From the parts list, you can select the part, then you can pay for after clicking on the shopping basket.
The model number will look something like this:
116.*********
116.*********
Comment by reddevil6, posted on May 13, 2008
You can either call their parts line, (800) 252-1698, or on the sears.com you can email them thru their contact link, give them the model number that you have and what you are looking for and see what they have to say. The number you are seeing is a sales number so if you don't see a different number, then you will hve to contact them direct. The other possible thing is to take out the brush roll and find a local repair shop that has various brands of parts, maybe they can match one up for you.
Rating Locked! (?) mhussen has rated this solution as FixYa!
This Problem Also Relates To:
Black & Decker 15.6 Volt DustBuster Vacuum
Black & Decker CFV9600 DustBuster Bagless Upright Vacuum
GE 106766 Bagged Canister Vacuum
Bosch BSG81360UC Premium Health Guard Bagged Canister Vacuum
Electrolux EL7020A Oxygen 3 Ultra Canister Vacuum Cleaner Bagged Vacuum
Electrolux EL5035A Bagged Upright Vacuum
Electrolux Envirosteamer 370A Canister Vacuum
Can you Help with these Vacuums problems?
Eureka Altima Upright Vacuum Model 2996AVS...
no suction
no suction
my vacuum will not **** up... Answer This...
Hoover F5906-900 Upright Steam Vacuum
replacement part
replacement part
i broke a piece of plastic off... Answer This...
Repair Service
Find Vacuum Repairman Near You:
