Question about Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241
Genarac Briggs and Stratton Engine Family 3BSxS3422HT-275385 Use: Wheelhouse 5550 Generator Need Tune up instuctions and maintenance information
    Scholar:
  • 97 Answers
Posted on Aug 30, 2010
How to test portable generator stator for short in windings
You will need what the factory resistances valuea re supposed to be, cold. Then use a high quality ohm meter with 3 decimal places, disconenct all wires off the stator. Check each wire with a meter to the ground frame, if there is any value, stator is shorted. Then check between stator wires ie L1 L2 and compare resistance value with factory values.
Oct 02, 2014 | Briggs & Stratton Electrical Supplies
What is the fuel capacity of the Briggs and Stratton 5550 watt generator and what type of motor oil does it neet?
Hello, probably a really good guess is 2 1/2 to 3 gals. Oil type I would use cleaing additive multi-temperatur 10/15 or 10/20 well know brank. Synethic oil I don't know how well does it work in an air cool engine. GB...stewbison
Aug 23, 2011 | Briggs & Stratton Power Products 5,550...
Neighbor has a Briggs & Stratton Elite Series 5550 generator. How do you remove the generator from the engine. Need to repair oil capacity switch inside.
Hello; The Briggs engine front case is shaped to accommodate the internal mounting of the Alternator section. A service manual for this model would be very helpful. I believe you need to dismantle the back of the Alternator where the outlets are and then the outer case with the stator windings in it. This will leave the rotor ( the long shaft with windings on it ) which will be attached to the output shaft of the engine by some coupling device the you must dismantle. John
Aug 15, 2011 | Briggs & Stratton Power Products 5,550...
Wheelhouse 5500 Genarac Generator Replace rear Briggs Stratton engine Oil seal
the gen head will need to be removed if it in on that side and the flywheel side should be done as well the seals can be purchased from any auto parts store with using the numbers off the seal some engines need to be split do to the seal needs to enter from the inside side if this is the case reseal the hole engine i suggest you get a small engine repair manual or the manual for your unit this will be a involved undertaking removing the gen head can be tedious and special tools will be required so no damage to it hope this helps
Aug 30, 2010 | Briggs & Stratton Electrical Supplies
I have a 5550 Watts Briggs & Stratton that only ran since purchase for 2 hours tops The pull starter locked up when I tried to start engine.
unscrew the four bolts holding it on and chek the rope has not become tangled dont unscrew the centre bolt as the recoil spring will suddenly shoot out everywhere
Mar 20, 2010 | Briggs & Stratton Power Products 5,550...
Recoil starter spring has unwound Briggs & Stratton 4 HP mower motor
you can buy the whole recoil + pull cord ready to install ,or have a small engine shop rewind it if you cant. some times the tab that held it breaks and you have to replace it.
Mar 06, 2010 | Briggs & Stratton Power Products 5,550...
Briggs & Stratton Power Products 5,550 Watt Portable Generator #30241 Logo
1,291 people viewed this question
Top Briggs & Stratton Electrical Supplies Experts
John Trevino
Falcon52
Level 1 Expert
Craig Butler
Craig Butler
Are you a Briggs & Stratton Electrical Supply Expert? Answer questions, earn points and help others
