Question about Kenmore Dryers
I have a Kenmore 90 series gas dryer that is not drying clothes in the normal cycle time and today when I opened the dryer door to add a piece of clothing the dryer smelled of gas.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Switch off the dryer and unplug it from the power socket and mains. Now check the igniter, gas coils and also check that the vent line is not kinked or clogged. Check that the air flow is fine and also check, change or shorten the venting and vent hood. Clean the air vents and check that the drum seals are not loose or worn out. Check that the dryer air ducts and lint filter is clean. If still the issue is not resolved then check that the thermal fuse is not open or gone bad and required to be replaced. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 30, 2010
Kenmore dryer 90 series
Since no model number was given, check to see if you have a setting commonly noted as "wrinkle guard", "wrinkle shield", "press care" or something to that affect. Those settings will run the dryer for as much as 90 min after a completed drying cycle to prevent wrinkles in clothing, allowing you time to remove the cloths after a dry cycle if you are busy. Pleazer Appliance...
Apr 09, 2014 | Dryers
I have a kenmore dryer 80 series it only makes a lite sound when I push the start button. I won't come on. The power is good.
The Kenmore 80 Series of dryers are consumer grade dryers for home use. As with most home appliances, the Kenmore 80 series dryers will occasionally not work as intended. If a problem occurs with your dryer, however, you do not necessarily need it serviced by a technician. You can attempt to troubleshoot and fix any problems with your dryer before contacting a technician.
  1. Kenmore 80 Series dryers may not run for several reasons. First, make sure that the power cord is plugged into a working power outlet. You may need to plug a different device into the outlet to check that it is receiving power. If the second device does not run on the power outlet, you may have blown a fuse or tripped a circuit breaker. Check your fuse box or circuit breaker box and make the change as needed.
    Next, make sure that the dryer door is fully shut. The dryer will not run with the door ajar.
    Finally, check that the "Start" button was fully pressed and that a cycle was chosen on the machine. If you do not choose a cycle for the dryer, it will not run.
  2. If your Kenmore 80 Series dryer does not heat up during use, check that a heat cycle has been chosen for the load. There are several different dryer cycles you can choose, some of which do not use heat. Make sure that you have chosen a heated cycle.
    As above, check that you have not blown a fuse or tripped a circuit breaker. The dryer may use more than one fuse or breaker: one is used to power the drum, and the other for the heating element. Make sure that both fuses or breakers are in working order.
  3. There may be times when Kenmore Series 80 dryers do not fully dry your clothes. When this occurs, check the lint screen and clear out any lint. The air may not flow as well if the lint screen is clogged.
    Next, check to see if the exhaust vent is clogged. Lint and other particles may clog the exhaust vent over time, restricting air flow and making it more difficult to dry your clothes. To check the vent, run the dryer and hold your hand under the vent. If you do not feel any air flow, clean or replace the vent.
    If you used cold water to rinse the clothes it may take longer than normal to dry. The same is true if the load of laundry is very wet or is filled with items that are very absorbent.
    Finally, check the load size. The more clothes in the load the longer it will take to dry. If you want to reduce drying time, separate the clothes into piles of light and heavy items and dry them separately.
  4. please comment on these solution by saying how helpful.
Dec 22, 2010 | Kenmore Dryers
We have a Kenmore 400 Series dryer. It heats up but our clothes is not getting dry. We have to cycle it twice to get our clothes dry on high heat. Any idea why it would take 2 cycles to dry?
This was the out vent of my dryer... If it gets this bad... open up the dryer housing and clean inside too. Also make sure the intake is free of lint.
Aug 23, 2010 | Kenmore 74602 Gas Dryer
DLG5988S gas dryer takes long time to dry cloths in either mositure sensor mode or timerd mode. I have throughly cleaned the dryer exhaust and internal part of dryer where all electronics and controls are...
How long is the exhaust venting system from the dryer to the outside, where it vents? The dryer is not equipped to push air through any pipe that is too much past 8-10'. Each 90 degree bend in the pipe adds 3-5', so a few feet plus a few 90 degree turns makes it nearly impossible for the dryer to do a good job drying clothes. I own a Tjernlund LB1 dryer boost fan and it works wonderfully - a great solution to drying clothes in a reasonable amount of time with much less wear and tear on my dryer.
Here is another idea - I recently opened up my dryer to fix a problem and found that the interior exhaust pipe - the part that takes the exhaust air out of the dryer, into the vent pipe on the back of the dryer and eventually outside - had become disconnected INSIDE the dryer. The dryer itself was full of lint and the air wasn't getting out of the dryer at all. If you have this problem you'll also have a lint problem, so check this out - it would be an easy thing to fix.
Mar 01, 2010 | LG DLG5988 Gas Dryer
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Kenmore 70 Series gas dryer Dryer will not heat I just moved in and the dryer has not been used in a while. What do I need to do to start it back up?
your flame will not be on all the time during the dry cycle. It cycles to prevent it from over-heating? Do you have clutter on top of it, such as clothes? If yes take everything off of it and never use the top for clothes piles or anything of this nature. When you have stuff on top it insulates it and the excess heat cannot disipate. 90% of the world uses the top for clothes piles. DON'T DO THAT EVER.
Good Luck
Feb 23, 2009 | Kenmore 73952 Gas Dryer
Kenmore 90 series not drying.
remove the ventin from behind the unit you need to replace and or clean your vent !!!!!
Jan 16, 2009 | Kenmore 62602 Electric Dryer
Kenmore 90 series gas dryer, NO HEAT!!!
Hi, if you get no glow on the ignitor and you have voltage its the little white two terminal fuse on the exhaust side that has no continuity on the series 80 it has 2 blue wires, these complete the circuit for both gas valves and the ignitor. If you have an ohm meter it you will find it rite away. Hope this helps.
Mar 21, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
