Question about ThermoKool Refrigerators
What is the normal cooling temperature for a walk-in cooler measuring 10 x14 x 8 interior ? Walk-in is a custom made.
  • 531 Answers
SOURCE: high humidity in walk in cooler-cakes are dripping
you are leaving the door open to long
Posted on Apr 07, 2009
  • 27 Answers
SOURCE: WHY THE FAN IN MY WALK-IN COOLER GETS FROZEN
check the settings of the pressure control or if the fan is operating or if it has a defrost timer if the coil ices up the fan cannot pull air over the coil thus loosing cooling effect. possibly call a local tech im in logan city brisbane if that helps?
Posted on Jun 30, 2009
SOURCE: Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Posted on Jul 27, 2009
SOURCE: Kolpak walk-in hinge adjustment
loosen the hinges slightly on door and door frame. Shim the door even in the door frame so its not touching on any side. Tighten hinge hardware and see if that helps. If it doesn't you are probably due for some new door hardware.
Posted on Oct 29, 2009
SOURCE: My Avanti wine cooler, model WC3201D, stopped cooling
same problem, can not fix. Had a authorized service tech who said that you can not add freon to this unit, the only option is to plant flowers in it.
Posted on Feb 17, 2010
External unit on my walk-in cooler will not shut off. Seems to be due to the Ranco Pressure Sensor. How do I fix or adjust?
Diagnosing Walk-in Coolers & Freezers Problems
blog.uscooler.com/walk-in-cooler-freezer-problems/
Jun 7, 2013 - Diagnose Walk-in Cooler & Freezer Refrigeration Problems ... For many evaporator units, the ice isn't melted, or the water isn't .... It works for few days (2-3 days) and it stop and does not run until I shut off the power .... My walk in compressor seems to be running and not shutting off. .... outdoor ambient= 85
Maintaining & Cleaning Your Walk-in Cooler or Freezer
blog.uscooler.com/maintain-walk-in-cooler-freezer/
Jan 7, 2015 - Torn gaskets can let warm air infiltrate your walk-in cooler or freezer. Close the door when not in use. Do not block or prop the door open for extended periods of time. ... on suction lines between the condensing unit and evaporator coil. ... Make sure the lights are off when exiting the walk-in. ... clean walkin ...
[PDF]INSTALLATION & SERVICE MANUAL - Polar Leasing
Dec 10, 2015 | Refrigerators
I rigged my danby airconditioner to cool a walk-in cooler. so i cut off the temperature sensitive resistor and put a what i think is a 10 ohm one and it seemed to cool the walk in continuously. then i...
Not exactly sure what you did but it is not designed for what you did nor are they designed for constant use. If there is ice building up on the condenser, the part that is in the room and not exhausting. If there is you need to put the part back before the unit destroys itself
Oct 04, 2013 | Danby Heating & Cooling
Installing walk in box
This is the wrong section for Experts of this type of problem. We are Cars and Trucks Experts in this section; contact Refrigeration or something more closely matching your product.
I would imagine having reinforced floor for the weight, drains for defrosting, and cooling lines are a minimum. If the box sweats, you need mildew protection and clearance to circulate air over the box. Commercial units may use 220Volt power.
Big part will be if rollers are on bottom. If none, you are looking at forklift type carrier. Quite possible unit would be installed by removing exterior wall and inserting box, then replacing wall. You have to consider a minimum 8 foot opening which kinda limits moving through most interiors.
Sep 22, 2013 | US Cooler 8x10 Walk-in Cooler-Indoor Box &...
Commercial walkin condenser freezing up
Defrost Timer on walk in cooler
Sep 15, 2013 | Heating & Cooling
How can I adjust the temp. on a norlake walk in cooler?
There are many variations for a Norlake system
I assume the cooling coil hangs from the ceiling of the cooler and the condensing unit sits on the top?
The temperature is controlled by a control that is located in the condensing unit on the top of the cooler. This can be either;
\ a digital thermostat. You will need the progam key to get in
\mechanical thermostat. Adjust the dial setting
\ pressure stat. Adjust the dial setting
Probably best to get a technician in
Apr 22, 2011 | Refrigerators
Water cooled walk in Refrigeration not cooling and compressor and condensor fan turning not turning on
if u live near madison wi i charge u $55 to check what it is wrong
if fan work. the relay is bad
Jan 13, 2011 | Kolpak KOL-P6810CS Walk In Cooler Polar...
Walk in chiller.Evap freezing up, Appears to start freezing just after the TX valve.R22 HP 235psi LP 40psi. Sight glass no bubbles. Suspect TX valve. Have adjusted in and out with no change. Any...
First front seat the valve stem on the expansion valve (in all the way), then backseat the valve (out) six turns. Next pump the system down and change the drier, evacuate, open the "King-Valve" on the receiver and allow refrigerant to circulate. Rule of thumb (ole school) measure ambient temperature add 25*F convert this temperature to pressure for head pressure. Also check RLA (running load amperage).
Allow system to run about 2 hours then check TXV Superheat should be 6*F for low temperature.
Dec 14, 2010 | Traulsen Commercial 2 Door Cooler /...
Walk in cooler cycleing
It has lost some freon and is not charged correctly...the unit is pumping down and shutting off on low pressure and then after being off a bit the pressure comes up and it restarts...
Need to check the charge and top it off and you will be good to go..
heatman101
May 28, 2010 | Nor-Lake Norlake Refrigeration 4' x 6'...
After pugging in the water cooler, the fan starts running, all good water is cold but the fan never turns off. is this normal.
Yes except if it has a temperature control but would cut off only when it has reached the desired temperature, and water coolers are not the efficiency compared to a heat pump or air-conditioning, it only cools the air with the water running over the pads so whatever the temperature of the water is that’s the temperature the cooler will cool the air to. so in theroy it will only drop the temprature 10 to 15 degrees.
Sep 14, 2009 | Hamilton Beach Water Cooler with Storage...
How to Replace walk in cooler defrost timer
Jun 30, 2009 | Refrigerators
Refrigerators Logo
16 people viewed this question
Top ThermoKool Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a ThermoKool Refrigerator Expert? Answer questions, earn points and help others
