Question about HP LaserJet M1522n MultiFunction Printer
HP MFP 1522nf turns on and display error 49 turn off and on. The printer restarts and gives the same message again and again
    Sniper:
  • 56 Answers
Try the following: got to the menu (the wrench) and with the arrows look for service, press ok and look for restore defaults. After that unplug the fax line (this is very important). Go to the hp website and download the firmware update and run it (while updating dont to anything to the printer, no print, copy, fax.) when that is completed try to fax again this should resolve it. If not I recomend to contact a service center, it could be the formatter (the motherboard)
Posted on Sep 08, 2010
HARD RESET hp laserjet m175nw ?
Try this:
1- Make sure printer is off.
2- Press and hold Red X and Right Arrow key.
3- Switch printer on (Red X and Right Arrow still pressed down)
The goal is to get the printer display a "Printer Settings Init" message. Release the two buttons when you get this message. If nothing happens, try the procedure over again.
May 14, 2014 | HP LaserJet Pro 100 color MFP M175nw -...
ERROR 49.FF81
From HP support forum possible defective hard drive.
http://h30434.www3.hp.com/t5/Printer-All-in-One-Install-Setup/M3035-MFP-49-FF81-Error-Code/td-p/1272713/page/2
you may be able to disconnect the drive to get the printer operational,
but you lose some functionality
49 errors are communication errors with other devices in printer.
Mar 20, 2014 | HP LaserJet M3027 MFP Printer
Hp color laserjet cm1017 mfp 49 service error showing in disply screen and restart the printer
Aug 15, 2011 | HP LaserJet CM1017 MFP All-In-One Color...
Tengo un problema con la impresora hp modelo m4345 mfp, la cual ya estaba funcionando pero de repente envio un error el cual es el siguiente 49.4c02 - error para continuar apague y encienda , ya lo...
49.XXXXX ERROR To continue turn off then on
A critical firmware error has occurred.
This type of error can be caused by invalid
print commands, corrupt data, or invalid
operations.
In some instances, electrical noise in the
cable can corrupt data during transmission
to the MFP. Other causes include poorquality
parallel cables, poor connections, or
specific software programs.
Sometimes, the formatter itself is at fault,
which is usually indicated by a 79 ERROR
message.
Follow this:
1 Turn the MFP off, and then turn the MFP on.
2 Upgrade the firmware.
3 Try printing a job from a different software program. If the job prints, go back to the first program and try printing a different file. If the message appears only with a certain software program or print job, contact the software vendor for assistance.
4 If the message persists when using different software programs and attempting specific print jobs,disconnect all of the cables that connect the MFP to the network or a computer.
5 Turn the MFP off.
6 Remove all DIMMs and flash-memory cards. Do not remove the firmware memory card that is in slot 1.
7 Remove all of the EIO devices.
8 Turn the MFP on.
9 If the error message disappears, reinstall each DIMM, flash-memory card, and EIO device individually, making sure to turn the MFP power off and then on again as you install each device.
10 Replace the component that caused the error message.
11 If the error persists, replace the formatter.
Jul 14, 2011 | HP LaserJet M4345 MultiFunction Printer
49 error turn power off then on
this is the firmwere error pls turn off the printer up to 30 min then on if problem persiste replace the formatter cart ur problem will be resolved
Jul 14, 2010 | HP LaserJet M1522n MultiFunction Printer
HP MFP 1522nf turns on and display error 49 turn off and on. The printer restarts and gives the same message again and again.
You need to be a little bit more specific nex time, the error 49 its normally related to an internal communication error between the DC Controller and the formatter board on the unit
Now we need to know if the problem appear when scanning, copying, printing, sending or receiving faxes
Heres some troubleshooting you can follow, its going to clear this error 49 most of the cases :
1. Turn off the product.
2. Press and hold both the down arrow button and the Cancel button, and then turn on the product.
3. Wait until the message Permanent storage init. appears, and then release the buttons.
4. When the printer comes back to ready, go to hp.com and download the latest firmware update for this 1522nf
if you need more assistance you can contact me at :
eliteprintersolutions@gmail.com
Jun 26, 2010 | HP LaserJet M1522n MultiFunction Printer
I get an error in HP LaserJet 4345 MFP printer, 49.ff95 error, Tunr off and the turn on
a 49.xxxx error on an HP means that there is an issue with one or more hard disks. you can try to re-initialise the hard disk(s) by rebooting the printer while holding the green button. when the three leds are lit, release the green button, and navigate using the numerical buttons until you see "initialise hard disks" on the display of the printer. confirm by pressing the green button again. if all goes well, your printer will take two minutes longer than usual to boot. if you still get the same error afterwards, you need to replace the disk.
Apr 21, 2010 | HP LaserJet M4345 MultiFunction Printer
49.4co2 service error will not clear
Error 49.xxxx - this type of error can be caused by invalid print comands, corrupt data or invalid operation...try this steps to resolve... :
MFP on.
computer.
5 Turn the MFP off.
8 Turn the MFP on.
device.
the error message.
formatter
Jan 06, 2010 | HP LaserJet 4650 Color Printer Manual...
HP LaserJet M1522n MultiFunction Printer Logo
802 people viewed this question
Seeker5211
Seeker5211
