Need help connect dvd to a walmart blizt 32' LCD Symphonic Tv
Cant find this tv anywhere, friend finally had it setup last week after buying it over a year ago. daughter's boyfriend set it up. Can't find manual. trying to connect dvd player to Tv. Looking for model#
  • Scott Hill
    Scott Hill May 11, 2010
    could you please post full specification like dvd model and tv model on the back of the units so we can look for your stuff?
  • 558 Answers
Never mind
Posted on May 11, 2008
My tv was on 1 minute and then the picture went out then the sound what could be a problem
Customer Reviews: Seiki 32" Class LCD 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/14978588
WalmartShop all · No-Contract Phones · Unlocked Phones · Prepaid Minutes & Data ..... Seiki 32" Class LCD 720p 60Hz HDTV, LC-32G82 ... 1-20 of 45 total reviews ... for an inexpensive 32" TV for our guest bedroom and came across this one and ... Walmart is sending me a replacement and if it works well, I will update my review.
Customer Reviews: Seiki 32" Class LED 720p 60Hz HDTV ...
https://www.walmart.com/reviews/product/19717659
WalmartSeiki 32" Class LED 720p 60Hz HDTV, (2" ultra-slim) SE321FB .... I bought this as a gift for my girl friends home bar...we were booth very happy with the tv.
SEIKI TV SETUP - YouTube
? 1:42
https://www.youtube.com/watch?v=OZlNRxBe1fg
Feb 28, 2014 - Uploaded by Kevin Davidson
+Kevin Davidson Uhm how do I manually set my dns settings? ....Can u help me can u go on amazon and type in seiki 32 inch tv if its the same one as yours ... Can you help me purchase SEIKI LED SMART TV and would like to change .... Seiki SE50UY04 50-Inch 4K UHD 120Hz LED HDTV Initial Setup ...
25385173 My 32" seiki TV has no picture but sound
Dec 29, 2015 | Seiki 32" LED HDTV SE322FS - CAM CONSUMER...
We need to connect a wii and a dvd player up to our 32 in Emerson? Unsure of which jacks to use?
First, you must figure out If your TV has component video inputs. This is a set of five cables (red, blue and green for video and red and white for audio) and will give you the best picture on an hdtv
Then, If your TV does not have the component video cables, you will be using the red white and yellow composite yellows the system came with. A very simple connection.
Last, If your TV does have the component video inputs, you will need to buy a set of the Nintendo Wii Component Video cables from Walmart, Target or any other gaming store. These will enable widescreen view and the best picture quality.
To connect your DVD player, you need to located the composite video inputs and s-video. Composite video is a yellow, female RCA jack, normally found next to two audio jacks, one red, the other white. The three jacks together provide an interface for audiovisual connections. The red RCA jack connects the right channel of a stereo system, while the white RCA jack connects the left. The yellow composite video jack rounds out the set.
When playing the Wii, you will need to be on the correct video input "Component"
When playing the DVD, you will be on "Composite/Svideo."
Dec 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
Will not come on. Has power from the outlet.
mine did the same thing finally i tryed unpluging it from back of tv well still plugged in and then pushing in the power button on the tv and mine turns on but i cant use a remote to shut it on or off and cant seen to find any info on this tv anywhere so for last 3 months that is how ive been turning it on and off any ideas ??
May 19, 2010 | Proscan 32LA25Q 32 in. LCD TV
32" Sylvania TV/DVD won't work with my AT&T UVerse Remote
I bought a 32 inch sylvania LD320SSX TV/DVD and had trouble with a Media-Com remote. Finally got it to work using code 1864
Good Luck
Jul 22, 2009 | Sylvania LD320SSX LCD TV
I own a symphonic 27" television
I had this problem on a symphonic 27 inch TV I just bought from a friend who no longer had a remote. The thing with the menu and buttons on the front of the TV doesn't actually change the TV to true game mode. I don't know what it acutally does, but it isn't really in game mode. When it is in true "game mode" you can't change the channels until you turn game mode off. What I did was bought a universal remote (a specific one that someone told me about) for 8 bucks at walmart and I was then able to switch to game mode with the Input select on the remote. The remote I bought that actually worked is this one: http://www.amazon.com/Philips-Magnavox-PM435S-4-Device-Universal/dp/B00006686A/ref=acc_glance_ce_ai_-2_1_tit/002-3174824-8273629
Make sure you look at it before you buy it and make sure it has a button that specifically says "input" on it. I know that some of the universal remotes don't have an input select button or one that doesn't work. As long as you get a Philips-Magnavox that has that button, you should be ok. Much better solution that paying 30 bucks for a new remote specifically for the TV. Hope this helps.
Mar 04, 2008 | Symphonic ST419E TV
Programming help
Try to buy another manual (univesal remote control) because its not easy for you to get the codes if it will not work the write to us again.
Feb 24, 2008 | Symphonic ST419E TV
DVD operation
scroll down on the channel button from channel 2. the different aux inputs should be there.there may also be a video/line in/source button on the front of the tv.if there isn't, you can buy a cheap universal remote for under $10 [even in some dollar stores for $1]
wg
Feb 16, 2008 | Symphonic SC319C 19 in. TV/VCR Combo
Samsung 32" LCD TV
Attention, noisy pictures on dynamic image does not mean to change the main board, most of the time , the panel need to be replaced, not the main board.
Jan 08, 2008 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Need code
i too went 3months with no remote or codes finally a young tech at walmart in another town told me to use 0171 code but cable guy set me up on cable remote to turn tv on and off tech told me to get a one for all remote 9.99 at walmart and code it but to also push setup code for tvdvd and enter code i use cable remote for tv viewing and the one for all to reach video 2 (press tv/vid button twice) for games and dvd player now i can access menu and use my tv as it should hope this helps
Jan 03, 2008 | iLO 3200 32 in. LCD Television
Televison & Video Logo
105 people viewed this question
Top Televison & Video Experts
