Question about Kenmore Elite 45986 Front Load Washer
Moldy smell I have a dreadful, moldy smell in my washer. I can wash my clothes and they come out clean & smelling fine. As soon as I put the clothes in the dryer I can smell the stale, moldy smell in the washer. It has gotten so bad I have had to keep it washer closed (which intensifies the smell). I have cleaned under the rubber rim at the front with pine sol & that didn't help. Any suggestions?
  • Anonymous May 09, 2008
    I have the same problem. I found the inside of the rubber rim ito be full of mildew. I am concerned about health risks involved with breathing in the mildew oder 24/7.
  • Anonymous Jan 11, 2009
    I have a very very bad smell coming from the washer. It smells like a wet, dirty dog.
    Master:
  • 452 Answers
One of the best solution's is use a good quality soap powder after u clean machine,after u have checked ur filters and cleaned them put 1/2 gallon of bleach in tub put on hottest cycle and longest running time this will clean it after wards leave door open if no more smells that's it if it comes back repeat every month hope this helps u .... i do this in my machine
Posted on Oct 13, 2013
You can also use vinegar. Just pour some in with an empy load and let it run a normal cycle. Some people say use 1/4 cup of vinegar, but I use whatever seems like enough! Try it whenever it gets smelly. It could be done with your dishwasher also, but to really get rid of soap buildup, you'll probably want to get a dishwasher cleaning product.
Posted on Apr 03, 2010
The Sears repairman told me to use a whole bottle of "Washer Magic" (WalMart) in an empty load using the Sanitize cycle. Use this quarterly and then use "affresh" tablets monthly. I hope it helps.
Posted on Mar 28, 2009
I found that when I opened up the little filter basket under the tub, the smell was over-powering. One I cleaned this out, the smell was gone. Just be careful because the drain lines will dump out alot of water, so be prepared to catch this with towels.
Posted on Mar 13, 2009
    Champion:
  • 207 Answers
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
Posted on May 08, 2008
Moldy smell in clothes, especially towels
need to clean the bellow ( rubber around door). theres a tablet you can buy called "Affresh". It will help to remove the moldy smell. just throw it in washer and run through a regular wash cycle. no clothes, just the tablet. If there is a clean cycle on the machine then use that cycle. Whenever you're finished washing, you should leave the door open for about 20-30 minutes so unit can air out. Also you should wipe around the glass and bellow after each use.
Mar 19, 2011 | Whirlpool Duet GHW9150P Front Load Washer
After completing a load of clothing, the laundry sometimes has a moldy smell. If it doesn't smell right away, it smells after wearing the clothing and sweat a bit. This is not a body smell - this is a...
It sounds like your leaving the clothes in the washer long after the cycle is finished. Once your clothes smell from the washer they will smell moldy dry.
Aug 19, 2010 | Dryers
Moldy smell always tried bleach and vinegar. Use
You need to replace the rubber gasket around the front of the door. This gasket holds moisture and over time molds. Give us a call or email us and we;ll be sure to get the correct gasket out to you right away. We hope this helps and we hope to hear back from you real soon.
Oct 01, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Our front-loading HE washing machine delivers
try putting in 2 caps of a citrus or pine bleech straight in to the drum with some old rags. then select a boil wash. the rags will spray the water around the tub, the bleech will clean the tub and make it smell fresh. DON'T put any clothing in whilst doing this. if you are worried about bleech in the machine just select a rinse cycle after. i do this once every 3 months
Aug 05, 2009 | Maytag MAH2400A Front Load Washer
Moldy smell
Hi Jewel,
You may want to try some Washer Magic, or similar product specifically designed to clean out washing machines. I personally use Affresh in my front loader and it works very well.
SG
Mar 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
The machine smells moldy...
moldy smell, may not be mold at all, in fact most "moldy musty" smells actually come from user not using proper detergents, you NEED to be using an HE detergent and little amounts of that even. cut back on fabric \softneer if using, www.affresh.com new product to help alleviate this issue
Nov 29, 2008 | Frigidaire Affinity ATF7000E Front Load...
Moldy smell in front load kenmore washer
forget the vinegar, theres a product www.affresh.com this will help. you also MUST USE HE( high efficency) DETERGENt. reccomneded amount is 2-3 tablespoons. regular detergent, and too much fabric softener is possibly adding to the moldy/musty smell..
Nov 22, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Moldy smell in front load washer
www.affresh.com this will help with odors, also make sure you are using HE detergent and little bit at that(2-3 tablespoons)
Oct 12, 2008 | Kenmore 44072 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
662 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
