Question about Panasonic Toughbook CF-51 Notebook
Serial port does not work? - Panasonic Toughbook CF-51 Notebook
  • 629 Answers
Most likely, serial port is faulty. things you can try: update chipset driver, bios, reset BIOS settings, then test serial device through hyperterminal. if the device response through hyperterminal,
Posted on Aug 30, 2010
Hai mr.igot problem when i install usb bf-810 iwas isntal driver but when i plug the port inthe PC it's show"USB devivice not recognice"can u solve my problem
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 98 or Windows® ME driver 5.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 5.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 5.3 Select the “Next” to install.
Before you start installing the driver, please don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® 2000 driver 6.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 6.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 6.3 Select the “Next” to install.  Before you start installing the driver, please Don’t plug your USB TO Serial Adapter into the USB port of your computer.  Follow the steps below to install Windows® XP driver 7.1 Turn on the power of computer and make sure the USB port is enabled and can working properly. 7.2 Insert the driver of USB-SERIAL ADAPTER into CD-ROM drive. Select “Install Products - USB-SERIAL ADAPTER - Install”. 7.3 Select the “Next” to install.
.1 Driver Installation (MAC OS X) 8.1.1 Power on your computer and make sure that USB port is enabled and working properly. 8.1.2 Insert the USB adapter software driver into CD-ROM driver. 8.1.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS X " folder run on "PL2303_1.2.1r2.dmg", it will auto run the program and appear "PL2303 driver" folder in the desktop. 8.1.4 Click on "PL2303 driver" folder , execute "USBSerialOSX1.0.9b6.pkg" will auto install, you may change the driver directory that you want to install. 8.1.5 System will demand restart computer. 8.1.6 Plug in the USB-Serial adapter into USB port. 8.1.7 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". 8.2 Driver Installation (MAC OS 8&9) 8.2.1 Power on your computer and make sure that USB port is enabled and working properly. 8.2.2 Insert the USB adapter software driver into CD-ROM driver. 8.2.3 Click "USB-SERIAL ADAPTER\DRIVER\MAC\OS_89" run on "PL2303_OS9_v136b1.hqx",it will auto run the program and appear "ProlificUSBSerial" file. 8.2.4 Copy "ProlificUSBSerial" file into "system folder"-"Extension". 8.2.5 Plug in the USB-Serial adapter into USB port. 8.2.6 To make sure that your computer can use the device, you have check the "Apple System Profile"-"Device and Volumes". It will show the USB Device.It will show in USB port "USB-Serial Controller". Follow the steps below to install driver of USB-Serial adapter:
hope that helps you
May 29, 2010 | BafoTech BAFO BF-810 Serial Adapter
Usb/serial adapter not working
check the com port of the appliaction, it is based on com1 only then you will need to make changes to the com4 to com1 follow these steps
open device manager
choose com4 and then right click for properties
choose port settings
choose advance
change the port number from 4 to 1
that will be all you can now give it a shot again
Jan 01, 2010 | Bernina Artista 180
Both printer and 9 pin serial ports not working
What has changed? One solution is to go into BIOS when you first turn on your PC hit <del> key. Make sure the ports are enabled. The second solution is to make sure you didn't add a device with serial ports or something which is sharing the same IRQs, which is 3 4 and 7 traditionally (for COM1/2 and parallel port).
If you tried all this and it doesnt work, then somehow the chip on the motherboard which handles these (the UART chip) has broke, you need to replace the motherboard or buy a card with serial and parallel ports on it (this should be quite cheap, ie 10-20 dollars).
Nov 07, 2009 | Intel Computers & Internet
Computer says no contact with machine have tried everything
Youn don't say what Windows flavor you're using, or whether you have a serial port or not. I'm going to guess you have a laptop with Vista on it, and the laptop has no serial port for you to connect the 7570's cable.
You need to get either a serial to USB cable that works with the 7570 (read some of the posts in this section. There's at least two or three that do), or another device called a Port Replicator, that has the serial port as well as a parallel port for printing, and perhaps one or two USB ports.
In my case, I have two of the latter ones, the Targus PA090U and the PA075U, and both need no drivers with Vista and work OK. They simply get recognized when you plug them into a USB port and are available to you, except that in my case, the serial port always defaults to COM port 4.
The other reason why you may not be getting a connection may be found in your Machine Configuration, in PCD_WIN. In version 2.0, which is the one I have, go to the Machine menu option, and at the bottom, click on Configuration.
Here make sure the COM port is the correct number, and then set the speed to LOW. That works for me.
Aug 23, 2009 | PfaFF Creative 7570
My older hi-pro box will not work with my serial to USB adapter. It keeps saying it cannot find it on com 1,2,3,4. In the device settings it says the hipro is on port 2 and the serial/USB bridge is on port...
I just set up a serial Hi-Pro box for one of my customers on their new laptop. According to Beltone, the only usb adapter that will work with the Hi-Pro (or at least the only one they have gotten to work) is a Belkin F5U409. I know some usb serial adapters don't use true serial communications if that makes any sense, so there isn't really a baud rate. They kind of just send out the communication in bursts...
In any case, ive only tried with the belkin adapter and that worked fine with no problems. The other point here is that your Hi-Pro and Adapter are on different com ports... This is odd, the hi-pro should be on the serial adpater's com port. Also the software i was using - Noah, with a beltone module for programming hearing aids.. only looked on com ports 1-3. The computer put the serial adapter on com 8 - which would not do. I checked for available com ports and saw that 2 was unused. I set the adapter to 2 and was able to set up the program normally.
I did this on Windows 7 Professional 32 Bit. The procedure for selecting the com port is the same on earlier versions of windows.
First, open device manager, open the list titled "Ports (COM and LPT)". You should see your serial adapter in there. Double click it. In the window that opens click the "ports" tab, and hit the button labeled "Advanced" In the window that opens there will be a drop down list to select a com port. Select the desired com port and hit ok. That should fix it.
Jul 12, 2009 | Uniden Unipro PC100
Do I have a Serial Port on my acer window vista home premium mfg date 12-18-2007
Most newer computer do not have serial ports but there is such a thing as a USB to Serial converter that might work to load what you need to load. USB to Serial converters don't always work but they are worth a try
Nov 09, 2008 | Computers & Internet
I need to connect a receiver to my computer's serial port, and it doesn't work
which serial port and where > sounds like ya need to do the updates on that computer..... and where or why havent you contacted the makers of that computer to see if they can issue support for that simple task ?
Jul 19, 2008 | Dell Dimension 4600 PC Desktop
Serial port 1
here try this; its free. Virtual Modem PRO 3.0 creates software virtual IP-modems and maps them to virtual serial ports in Windows. http://www.freedownloadscenter.com/Network_and_Internet/Network_Management_Tools/Virtual_Modem_PRO.html
Sep 03, 2007 | Alcatel Newbridge MainStreet 3624...
There is a serial port besides the parallel. how can i make it work with serial cable?
if the printer is built with a usb port, the it should work, is there another USB device in the PC that is working ?
Jun 02, 2007 | OKI OL 400e Led Printer
Panasonic Toughbook CF-51 Notebook Logo
107 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
