Question about Creative Labs ZEN V Plus MP3 Player
Stuck on recorery mode
What can i do to fix the problem.
  • 1 more comment
  • roshunda ray ray May 23, 2008
    my mp3 player is stuck in recovery mode. And I formatted the firmware. How do I know if it's charging?
    I deleted the firmware how do I fix this problem
  • tevin2625 May 27, 2008
    idk how to fix mine neither
  • 8,596 Answers
Recvery mode instructions:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
Posted on May 30, 2008
Hansgrohe talis s stuck in spray mode
Some disassembly may be required to determine the cause of the stuck button and fix it. There may be mineral deposits preventing proper operation.
Jan 20, 2014 | Plumbing
Tip
FIXED keyboard stuck in fn mode ...
keyboard stuck in fn mode ASUS eeePc .. what you have to do is press and hold the Fn key, then while holding the Fn key, press Num LK or Number Lock key, That should fix it. Good luck!
on Feb 10, 2010 | Computers & Internet
Missing or corrupt. \windows\system32\config\system
You probely have to use recorery disc or reintall windows
Feb 19, 2011 | Computers & Internet
Canon Power Shot SD750 screen went black. Read solutions, not sure what TV mode is? Is it same as video mode?
Tv is "shutter priority" mode. The Canon SD cameras do not have that mode. Instead see Fix 5A of the below link. A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, sometimes with lines, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Dec 25, 2010 | Canon PowerShot SD750 / IXUS 75 Digital...
I have a HP Compaq nc6320 laptop & the Bluetooth used to work, but hasn't for a while now. On the the logo on the taskbar, instead of it being blue & white, it is blue & red. If I click on it,...
I have had the same problem this might sound bit extreme but it worked after re-installing windows xp (if you have the recorery disks)When laptop starts up hold down "f11"
Sep 26, 2010 | HP Compaq nc6320 Notebook
Camera shows black in picture mode
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see the following for further info and a simple fix that may help: http://camerarepair.blogspot.com/2009/05/simple-fix-for-stuck-shutter.html
Jul 05, 2009 | Canon PowerShot S2 IS Digital Camera
Indoor pictures are fine; however, when I take a picture outside, it is "white." Have I accidently changed a setting? Thanks for your help.
First make sure your mode selector dial is set to the red camera WITHOUT an M next to it (ie it's in Auto and not Manual mode). If so...
Now the A430 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. If after many tries this does not work, then consider trying Fix #5a on the site. But do so with the camera turned off and the lens retracted to lessen the chance of damaging the lens mechanism.
Jul 05, 2009 | Canon PowerShot A430 Digital Camera
My A460 camera has a diffrent kind of problem which is while clicking a photo in a daylight or well lighted area the picture contains very light where i cant see anything and when i make veido it works...
First make sure that you're in full auto mode and not in manual or any of the special scene modes. Check your rotating mode dial that its set to the first red camera by the blue arrow.
If you already are and were in auto, then a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
Now the A460 is not capable of taking 15 second exposures as recommended for the fix. Instead try setting the camera to manual mode, turn off the flash, got to a darkened room, and take a picture. Open the battery door while the red and yellow light are flashing. Repeat as the fix recommends, but please note that there may be only a small hope that this will work as the shutter may be stuck in the open position. This is harder to get unstuck than a closed shutter.
Jun 03, 2009 | Canon PowerShot A460 Digital Camera
Creative Labs ZEN V Plus MP3 Player Logo
18 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
