Question about Insignia 2.0 Speaker System (2-Piece)
Speakers will not make sound. all cords are connected. computer doesn't show that any sound device is present
    Sergeant:
  • 203 Answers
After reinstalling/installing an Operating System you can lose the Audio Drivers or sometimes they just corrupt.. Try reinstalling the Audio Drivers from the disk provide with your P.C./Laptop. If you no longer have the disk just visit the website of the makers of your P.C./Laptop or Motherboard and download the Audio Drivers from there, after that install them.
Thumbs up please if this works for you, thanks.
Posted on Aug 30, 2010
Audio device
Click start right click on computer select properties then device manager scroll to sound and video game controllers if you see a yellow question/exclamation mark or a red X the driver will need to update drivers Click start right click on computer select properties then device manager scroll to sound and video if you right click on sound and video then on high definition audio device select update driver software Click start control panel hardware and sound manage audio devices right click on your speaker select configure speakers. Right click on the speaker icon in the bottom taskbar you will see an array of options select playback devices make sure it has a green tick and the correct speakers are selected be updated. If you computer came with a motherboard disk the drivers could be on it although once speakers are connected widows 7 should automatically update the drivers Click start control panel hardware and sound manage audio devices playback you might have to set a default go for via high definition audio then right click on speaker You might have to configure them then select properties you will see tabs general level in this tab make sure your settings are loud enough also enhancements and advanced from the drop down list in the advanced tab select dvd quality or another then apply Hope this helps
Jan 16, 2013 | HP Compaq 6730s Notebook
My computer is a SyncMasterP2570HD i cant get any sound to come out but it is detecting sound how do i fix it
The Samsung SyncMaster P2570hd is a monitor with speakers; it isn't the computer itself. I'll assume that you are dealing with a computer connected to the monitor and not a set-top box. Make sure that Mute is not enabled on the computer. There should be an icon on the lower right hand side of a Windows desktop. If the mute is enabled, it will have a red circle with a diagonal line through it. Left click on the icon to remove the mute (change the volume or click on the mute icon). Test the monitor's speakers by connecting it to another device with known good audio output.
Next how are you connecting the monitor to the computer (VGA, DVI or HDMI)? If you are using VGA or DVI (including DVI to HDMI), you need to connect an audio patch cable (3.5 mm) between the speaker (green port on the back of a sound card) or headphone jack of the computer and the audio input jack of the monitor. The audio input jack is between the DVI and VGA ports. You can test the output of the speaker jack on the computer with regular computer speakers. Plug in the power cord (or USB cable) for powered speakers. If the free-standing speakers work, check the volume setting on the monitor with the +/- buttons to the right of the menu button. Do not press menu first, though. If that doesn't solve the problem, continue using the separate speakers. (Unless the monitor is still under warranty, it usually isn't worth taking apart a monitor to replace the speakers. You may be able find replacement parts online.)
If you are using an HDMI cable, check the output audio setting to see if the HDMI audio is available. For Windows, click on Start > Control Panel > Hardware and Sound (Windows 7). Then click on Manage Audio Devices under Sound. In the Playback tab, check what available audio devices you have. Make the HDMI the default device by right-clicking on it and selecting Make this the default device. (Other versions of Windows will a slightly different route to this panel.) You may need to restart the computer to get the audio signal on the HDMI cable after setting this. Note: not all video cards/computers support HDMI audio. If you don't see HDMI listed in the Playback devices, connect an audio patch cable as with a VGA or DVI cable, described above. Use stand-alone speakers if the monitor's speakers are bad.
I hope this helps.
(I have had the speakers fail in monitors; <$30 separate speakers are an adequate replacement for those built into a flat panel monitor.)
Jun 26, 2012 | Audio Players & Recorders
My multimedia speaker doesn't work. has no sound. could it be the wiring harness?
First Check that your speakers are powered on. On your desktop go onto your bottom task bar to the right far end and open the arrow which shows you a speaker sign. click on the speaker sign it will open up and show you the audio device that is in your computer. Check that all volumes and speakers are on, check that the speakers and controls are not muted. If everything is okay here then go to the next step.
Then go to your computer desktop and check on 'My Computer' right click on your mouse go to 'properties' the 'systems properties' dialog box opens up then you go to 'hardware' panel and click on it then press on 'Device manager' button. You will see a whole list of the devices in your computer. go to Sound, video and game controllers click on the + sign to open it if it's not already open. Check on the speaker signs you should some drivers and devices something like Realtek High Def audio. if there is a question mark on any of the devices then it means that the device drivers are not loaded. Look for the drivers and load them.
Oct 07, 2011 | Altec Lansing Multimedia Computer Speakers
Hyundai L90d+ has internal speakers. There is one cord connecting on the back to two positions next to each other. Using vga port for connection to computer. How to connect speakers to computer? I...
Plug the headphones/speakers into the computer. Go into Control Panel -> Sounds and Audio Devices -> Audio Tab -> Sound playback -> Select your headphones from the drop-down list. Voila headphones/speakers that work.
Sep 14, 2011 | Hyundai ImageQuest L90D 19" LCD Monitor
No sound coming out of my hp monitor speakers. Monitor shows speakers are on and not muted. I have a green cord connected from my monitor to my desktop.
if your computer came with a motherboard disc the sound drivers could be on it
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 16, 2011 | HP (PP036AA) Computer Speakers
My dell computer will not recognize the logitech speakers. I think it is something to do with the usb plug in versus a normal "jack" type plug in. I am using Vista as my OS>
Ok firstly make sure that the the speakers are connected to the green port at the back of the system tower. connect the usb cable to the usb port.
check with a headphone if there is sound . If sound is present then connect the speakers as above and then click start control panel - sounds - on this screen see if the speaker icon has a green check mark beside it , if not then click on the speakers and click use default device option present at the bottom of the screen. This should fix it.
In cases where the screen is greyed out .
strt - rgt click on computer - manage - device manager - audio device - chcek if ter is a yellow ! or red X beside it al;so check if you see other devices on screen
You could reinstall the audio drivers from the dell website support.dell.com for a DELL desktop . Reinstalling audio drivers should fix it.
try using the speaker on other system .
Hope its informative :)
Mar 31, 2010 | Logitech X-120 Computer Speakers
My speakers still work but no sound comes from my pc
check for sound card is present( configured) on Op. System, normaly is sound card drivers problems, try to reinstall audio drivers
Jan 30, 2010 | Dell Dimension 3000 PC Desktop
Audio cuts in and out in media center or while watching a dvd
Check to ensure that the speaker connection plug is fully inserted into the speaker jack on the computer. Do the same for the power connection at the speaker, too. Slightly wiggle or twist the connections and wires - one at a time to isolate the source of the failure (can be the power plug or wire, audio plug or wire, or even the jack on the PC . If related to the speaker plug, try using the speakers in another speaker jack on the PC - or other device (mp3 player, etc.) if the problem is still present on both locations, it is related to the speakers / power. Try using a pair of headphones plugged directly into the speaker jack on the PC to see if the problem is present still. If the problem is common to both speaker and headphones, the jack on the PC is likely the culprit, and a new sound card will probably have to be installed. Otherwise, replace / repair the speaker cable, plug or system.
The likely source of the problem is a stretched wire along the cord - or at the plug. A repair can be attempted if desired - or replace the speaker system if lacking tools or if unsure how to go about it.
Sep 28, 2009 | Gateway GT5016E (RBGT5016E) PC Desktop
My speakers are not working. The computer came with Realtek speakers but not with the normal jack. I believe it is a USB jack which I plugged into two USB ports above where the jacks would go. I'm not sure...
Check if your computer has a sound card available
Check on the back of your computer
Power up you set of speakers, some speakers doesn;t work without power
Check the speakers connections (between them)
Don't forget to rate my help! :-)
Thank you for using FIXYA!
Pablo
Oct 15, 2008 | Gateway Computers & Internet
Computer stopped recognizing the speakers
You need to reinstall the latest drivers for your present sound device then restart your pc then check it. It will work surely! you should install the drivers that came with your sound devices! thats it!
Dec 07, 2007 | Polk Audio M3 Speaker
Insignia 2.0 Speaker System (2-Piece) Logo
91 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
