Question about Dell Dimension 4600 PC Desktop
Dell CPU fan inside went out
Fan went out in my Dell desktop CPU
  • Sugar55 May 08, 2008
    Fan went out in my Dell Desktop 4600 CPU is it easy to replace
If your computer is running kind of sluggish, you can fix it with an easy clean up of your registry. Here's a link to a free scan that works well:
www.your-free-info.com/RegCure
I've used this one and it sped up my computer by quite a bit. Hopefully this helps.
Posted on May 08, 2008
Cpu fan failure dell optiplex 360
Make sure the fan cables are plugged in on the motherboard. Or the cpu fan may have went bad and needs to be replaced.
Jun 24, 2014 | Dell Systems Dell OptiPlex 360 Minitower...
Whining fan dell E520 computer
Replace the fan as soon as possible. If the noise suddenly stops, DON'T assume the problem corrected itself. More likely, the fan completely froze and stopped spinning entirely and you're at risk of overheating something inside. Generally, there are usually 3 fans in a desktop computer (cpu/heatsink, case, and power supply) and sometimes a 4th fan if the computer has a separate graphics card. Laptops usually only have one fan.
Apr 27, 2014 | Dell Dimension E520 PC Desktop
Clicking sound and hot computer
It could be a broken fan, the fan sits on top of the CPU heatsink inside your computer, is there warm air blowing from the vents? if not you need to replace the fan or contact the dell service center.
Jun 10, 2012 | Dell Inspiron One 2305 Desktop Computer...
Dell 370 fan runs loud and won't start
If the fan is failing the most times the computer will not start because it will overheat. There are two fans inside the system, one inside the Power Supply and one that sits on the motherboard.
Remove the Power Cord, Open the case, Remove the cover and with a can of compressed air blow out the dust inside the computer. Clean the dust away from the Fans, Vents, CPU and Heat Sink are that sits under the Fan on the motherboard.
Apr 23, 2012 | Dell Precision 370 (370TREC) PC Desktop
Cpu fan can't run on dell dimension
You can clean or replace the fan.
Get the manual from www.dell.com/support
You can download it free and look up the fan repair instructions.
Hope this helps.
Mar 05, 2012 | Dell Dimension 2350 PC Desktop
I have a Dell Inspiron 530. Was getting 2 quick beeps on start up and loud fan noise. I replaced the cpu fan but the one I bought did not have the right plug for the motherboard connection. I had to modify...
This model (as well as many other Dell desktops) has a DUAL SPEED CPU fan. If the motherboard detects that the CPU temp is running hot it will increase the speed of the CPU fan to lower the temp of the CPU. You should do a Google search for the correct CPU fan and purchase it and install it back into your computer.
Aug 28, 2011 | Dell Inspiron 530 Desktop Computer
Dell Dimension 8400 Start up Fan Noise
Might be a hard drive issue. I had the same problem with one of My desktops. I replaced the hard drive and it worked fine.
Jul 01, 2009 | Dell Dimension 8400 PC Desktop
Dell 8400 runaway fan no diagnostic lights and very ocassionally it starts normally
Which fan?, the cpu fan or the cpu fan?
Most Dell pc come with a below average power supply. I recommend replacing your power supply with a better one. Do a search on Google for a good replacement power supply for you Dell 8400.
Please rate response.
Feb 17, 2009 | Dell Dimension 8400 PC Desktop
Loud CPU fan
check your cables. it may be in the way of the fan's fins. also clean your fan for dust.
Sep 16, 2007 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Dell Dimension 4600 PC Desktop Logo
112 people viewed this question
Alun Cox
