Question about Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas
I have a Teledyne Laars Series 2 pool heater, it just recently been shutting down on it's own, I use to have to shut it off. Tank is full, pilot light is on. It will turn on but just shuts off. If I turn the on and off switch back and forth can usually get it to work. Just doesn't stay on long. Cleaned out the inside with a blower. All looks ok, thermostat set at highest
    Top Expert:
  • Teledyne Laars Master
  • 5,706 Answers
Sounds like its overheating look inside by heat exchange if sooted-up check gas pressure if ok clean out exchange try again or take out baffels
Posted on Jan 14, 2016
  • 718 Answers
SOURCE: Where can I download an instruction manual for
You can download some information from;
http://www.manatron.net/Pdf's/JANDY%20MANUALS/heaters.pdf
This will give a parts list, applications and diagram.
Posted on Mar 27, 2009
  • 139 Answers
SOURCE: starting a teledyne laars heater
check for proper millivolt reading( 400-600).it could be 20 different problems and/or components
Posted on Jun 21, 2009
  • 2069 Answers
SOURCE: teledyne laars series 2 pool heater
First of all, I'm assuming that your heater has a pilot and not self ignition.You will need a jumper wire ( 16" of wire with an alligator clip on each end)attach one end to the terminal on the gas valve that the red wire from the pilot generator is connected to ( pilot gen. is the thing the pilot flame touches).
Now attach the other end of the jumper to the terminal where the wire from the connects to the knob where you set the water temp).
NOTE:
JUMPING BYPASSES ALL BUILT IN SAFETY DEVICES AND IS FOR TEST LEAVE THE JUMPER CONNECTED TO RUN THE HEATER FOR HEATING PURPOSES!!!!
Posted on May 22, 2010
  • 3 Answers
SOURCE: Teledyne Laars LD250 Propane Pool heater cycles on and back off
Do you replace the thermopile or check the milivolts?
Check the Pressure gas
You need replace all of them terminals and check again the milivolts at the gas valve
Posted on May 29, 2010
  • 33 Answers
SOURCE: pool heater will not stay lit
Problem with the thermocoupler its not producing a minivolt of 250 plus that is needed to open the main gas valve
http://www.laarsman.co.uk
Miles
Posted on Jun 05, 2010
How turn on pilot on teledyne laars series 2
turn gas valve to pilot hold down for 1 minute keep holdibg and light pilot hold for 2 minutes then turn to on
May 27, 2014 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne laars xe pool and spa heater
look inside on panel directions if not turn to pilot setting hold down button light under where small silver line goes under while holding down button when lit keep holding for about a minute then turn to on should stay lit if wont stay lit need new pilot generator
Jun 09, 2012 | Teledyne Laars Laars Lite 2 Pool Heater...
Pilot and heater works for about 2 min and shuts off heater and pilot
check gas pressure if too small a line that will happen or too low gas pressure
Aug 08, 2011 | Teledyne Laars Laars Lite 2 Pool Heater...
My pool heater wont start the pilot light is on the red light is blinking and the fuel tank is full the temp. Is on high .the burners came on for asecond and then shut off?????what should i try to do now??
With these pool heaters, there are a couple things that you can check yourself before you call a pro for this problem. Try cycling the ignition sequence until all air is out of the gas line. Also, check your gas valve. If it is manfunctioning, it will need to be replaced.
Jul 12, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Apr 01, 2010 | Teledyne Laars Laars Lite 2 Pool Heater...
Pool pilot keeps tripping,what might be the problem ?
One of the most common problems will be the flame sensor. If it doesn't sense the flame, it shuts down the burner. Good luck...Lee
Nov 09, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
I have no pilot light on my series 2
First see if the gas supply line shut off is open and the heat set to minimum. Then turn the knob to pilot to line the marking . Press the knob down same time igniting with a safe/ long barbecue lighter. Hold down knob for 1 min. Turn the knob to ON.
Aug 12, 2009 | Teledyne Laars Pool & Spa
Pilot light on but heater will not start
check the high-limit switches. Under the inlet/outlet header. if either is open it will not allow you to fire up. my 150 degree switch was corroded and after jump9ng out, bam it worked.
May 25, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Teledyne Laars Laars Lite 2 Pool Heater 250,000 Btu / Natural Gas  Logo
119 people viewed this question
Top Teledyne Laars Pool & Spa Experts
Paul Carew
Jay Finke
Jay Finke
Bill Jordan
Are you a Teledyne Laars Pool and Spa Expert? Answer questions, earn points and help others
