Question about Kenmore 23822 Top Load Washer
My kenmore 80 series wont agitate - Kenmore 23822 Top Load Washer
    President:
  • 1,937 Answers
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump
removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (110.#######) and you'll see a list of major sub-components with diagrams and parts.
Two possibilities:
Newer model Whirlpool / Kenmore washers use a Lid Switch as a safety device. Unless the switch senses that the lid on the washer is closed, the washer will neither agitate nor spin.
Older models only used the switch during the spin cycle.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the washer still doesn't work, check the motor coupler.
Kenmore / Whirlpool top load, direct drive washers use a "Motor Coupler" between the motor and transmission.
It's used as a fail safe device and consists of three parts.
Two of the parts are the same, plastic units with three prongs that fit on one of the motor output shafts and the other on the
transmission input shaft. Between them is a rubber piece with six holes.
The power from the motor is transmitted through the rubber piece to the transmission.
The other shaft on the motor directly drives the pump.
If the motor coupler is broken, or worn, the motor may not be able to send full power to the transmission for agitating or
spinning.
See the following for how to remove the cabinet, pump, motor and motor mounting plate to inspect and replace the motor coupler.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=135
If the coupler looks damaged, it's a relatively easy fix.
Pry the plastic pieces from the motor and transmission. Some people use a claw hammer but I've found that using a small (6 inch) pry bar works well.
Carefully fit the plastic pieces over the motor and transmission shafts and press them in place (Use a 1/2" of larger socket to put pressure equally around the pieces.
Put the rubber piece on the transmission plastic piece.
Replace the motor mounting plate.
Carefully line up the plastic prongs on the motor based plastic piece to the three un-used holes in the rubber piece. If they don't line up right, the coupler could be damaged.
Mount the motor, don't forget the two screws, put the pump back on the motor and use its' clips.
Put the cabinet back on, don't forget to plug the lid switch back in and re-mount the console.
Posted on Aug 30, 2010
Kenmore 80 series washer won't spin or agitate
check to make sure the belt hasn't come off. if it's direct drive make sure the shaft is working and moving freely. if all of these check out the motor that turns everything my be stuck, frozen up or just bad all together.
Jul 14, 2012 | Kenmore 24032\24036 Top Load Washer
80-series w/ broken top agitator
There is a video at www.appliancehelponline.com/servicemanual.html that will walk you thru the replacement of the agitator dogs, this is a common problem with this style washer.
Mar 28, 2010 | Kenmore Washing Machines
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Kenmore Series 80 wont do anything.
Check the coupling/transmission.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 15, 2009 | Washing Machines
Kenmore washer 80 series 110 model not spinning.
unless your washer is over 20 years old, then it wont have a belt. the temperature of the water wont have anything to do with it spinning or not.
need to know if it agitates or drains and just wont spin.
if it agitates but no spin or drain, then you have a bad lid switch.
if it wont agitate or spin, but will drain, then you have a broken drive coupling.
Jan 08, 2009 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 Series will not fill up with water
if your washer will agitate when set to fill but not fill, then your pressure switch is bad.
also you may want to check and see if you are getting both hot and cold to your washer.
Nov 24, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 80 series agitator problem
time to look for a new washer, this is a gearcase problem, or cluth. Not easy to fix , unless know how.
Nov 08, 2008 | Washing Machines
Kenmore 23822 Top Load Washer Logo
70 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
