Question about Kodak EasyShare Z740 Digital Camera
When I turn on my Kodak Z740 camera it only stays on for about 3 seconds then it shuts off completely. When I turn it on, the lens moves out then back in, then shuts off. The battery is one I bought fairly recently, I tried taking it out, leaving it out for seversl hours and putting it back in, this did not help.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel after dropping it. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
Hope the advise is useful.
Regards
Andrea
Posted on Aug 31, 2010
The lens thing gets stuck wont go in or out and camera shuts down
I may be able to help with your Kodak EasyShare Z740 with a stuck lens.
Try these steps to fix your camera.
I hope that helps.
_____________________________________________
Kodak EasyShare Z740 Turns Off Fix
Kodak EasyShare Z740 Manual Download
May 05, 2010 | Kodak EasyShare Z740 Digital Camera
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
Camera turns off when you use telephoto lens camera turns off.
I may be able to help with your Kodak EasyShare Z740 that turns itself off.
I hope that helps.
Apr 21, 2010 | Kodak EasyShare Z740 Digital Camera
Camara wont stay turned on
It may be a 'lens extending' problem, or it might be fixed with a combination of button presses to reset it while turning it on.
I hope that helps.
Apr 15, 2010 | Kodak EasyShare Z740 Digital Camera
My z740 camera will not stay on
I hope that helps.
Mar 19, 2010 | Kodak EasyShare Z740 Digital Camera
Bought a kodak easy share z740 camera I love it very much but it just stopped working and I paid over 400.00 for it can I get it fixed or replaced
Won't turn on at all, or shuts off after a few seconds? This problem is frequently due to weak/worn out batteries or corroded battery terminals inside the camera. if charging/replacing the batteries doesn't clear the problem, remove the batteries and wipe the terminals with a soft cloth (heavy corrosion may require a fine wire brush, steel wool, or sandpaper). Remove any residue left in the camera by the cleaning. Clean the terminals on the batteries in the same manner, and then replace them in the camera. This cures most problems, but if it doesn't work for you, check the Kodak troubleshooting guide at:
http://www.kodak.com/global/en/service/repair/troubleshooting/troubleshooting.jhtml?pq-path=6198
It uses a simple Q&A format to diagnose problems and propose solutions.
Jun 24, 2009 | Kodak EasyShare Z740 Digital Camera
Camera won't stay on
I hope that helps.
May 11, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak z740 will not turn on
I hope that helps.
Mar 29, 2009 | Kodak EasyShare Z740 Digital Camera
Camer comes on for 15sec then go off
I hope that helps.
Mar 03, 2009 | Kodak EasyShare Z740 Digital Camera
Kodak EasyShare Z740 Digital Camera Logo
302 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
