Question about Car Audio & Video
How does the brightness signal work on a 2008 Buick Lacrosse?
  • 30 Answers
Since your car is relatively new, I would say the brightness signal is controlled through your on-board computer. If it's not, then the brightness knob is essentially a dimmer switch (such as those found in your house). It controls the amount of voltage being sent to the lights/LEDs and this voltage is proportional to brightness. The more voltage, the brighter they burn and vice versa. If you want even more detail, the know is probably made of a potentiometer (variable resistor). These are extremely cheap resistors that can be replaced (assuming you can find the correct replacement).
Hope this helps!
Posted on Aug 30, 2010
What is the labor time to fix a bcm on a 2008 buick lacrosse?
fix a bcm ? That would depend on the problem . Your best bet , take it to Buick dealer
Jan 05, 2017 | 2008 Buick Lacrosse
Need transmission pan bolt pattern for 2008 Buick lacrosse cx v6 3.8 litre
I just snug a couple up on two sides of the pan and go around it until tight. This is not a critical sequence tighening, like doing heads.
Aug 26, 2016 | 2008 Buick LaCrosse CX
How much does it cost to repair a HDM module on a 2007 Buick lacrosse
  • Subject of a RECALL so free
  • http://www.dealerrater.ca/recalls/Buick/LACROSSE/
  • 2007 Buick LaCrosse Recall Item Affected: EXTERIOR LIGHTING: HEADLIGHTS Date Announced: 08-14-2015 Description of Recall: General Motors LLC (GM) is recalling certain model year 2007 Pontiac Grand Prix, 2006-2009 Buick LaCrosse, 2006-2007 Buick Rainier, Chevrolet Trailblazer, GMC Envoy, 2006 Chevrolet Trailblazer EXT, GMC Envoy XL, 2006-2008 Isuzu Ascender, and Saab 9-7x vehicles. In the affected vehicles, the headlamp driver module (HDM) may overheat and fail, causing the headlamps and daytime running lights to not illuminate. Action Need To Fix It: GM will notify owners, and dealers will replace the HDM, free of charge. Interim notices were mailed to owners on September 2, 2015. Dealers will install a new HDM Service part as an interim repair. Owners will receive a second notice when remedy parts are available. Owners may contact Buick customer service at 1-800-521-7300 or Pontiac customer service at 1-800-762-2737. GM's number for this recall is 14291. FIND YOUR LOCAL Buick Service Centre
  • Buick Lacrosse Fires Caused by Faulty HDM Module? ' R.J ... https://rjhillconsulting.wordpress.com/2014/07/23/buick-lacrosse... 2014-07-23 · On 7/2/15 my 2009 Buick LaCross fuse box caught fire, I have since then learned that it began in the HDM module. There is a Technical Service Bulletin for ...
  • What is a Buick hdm module - Answers.com www.answers.com > ... > Pontiac > Pontiac Grand Prix > Grand Prix SE It is the headlight drive module. It is used for daytime running lights and low beam operation. It works in conjunction with the light sensor on top.
  • Buick LaCrosse Recalls DealerRater
    May 23, 2016 | Buick Cars & Trucks
    One high beam not working 2006 Buick lacrosse
    Sampson, sounds like a bunt out bulb, which will need changed.
    If you feel comfortable doing it yourself. Basically three screws, and you have to pull one plastic fastener from the fascia (bumper) and pull the bumper back a bit, and pull the assembly out. I believe it is in the manual, not bad to do. I will post a link to tell or show you how to do it. Press the helpful button
    Headlight Change 2005 2009 Buick LaCrosse 2006 Buick LaCrosse CX 3 8L V6
    2008 Buick LaCrosse Headlight Replacement
    Thread how do replace the headlight bulb in 2005 buick lacrosse
    Headlight Bulbs
    Feb 13, 2016 | Buick Cars & Trucks
    Where is the trunk light on/off switch located on a 2008 buick lacrosse
    In the newer Chevy Cobalts the trunk release button is usually located to the left of the steering wheel instead of the glove box.-----------------------------------------------------------------------------
    Car cable & OBD Connector
    Dec 07, 2012 | 2008 Buick LaCrosse CXL
    How to change the headlamp bulb on 2008 buicl lacrosse
    to change the low light bulb on your buick you have the remove the front bumper I was told.
    Sep 16, 2011 | 2008 Buick Lacrosse
    My 2008 Buick Lacrosse will not start. The electrical system seems to be going crazy when I try - like unlocking the locks and trunk and the windshield wipers coming on.
    I have a buick lacrosse and it wont crank it not saying anything everything woorks in the car but when i try to turn it over nothing happens
    Sep 15, 2010 | 2008 Buick Lacrosse
    Car Audio & Video Logo
    18 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
