My thermostat display went blank. I changed the batteries and now none of my buttons are functional.
  • 43,501 Answers
The keypad lock is activated...
check your book to see what buttons you need to push to unlock it...all t-stats are different...
heatman101
Posted on Aug 31, 2010
1f88-290 thermostat is blank
Change batteries, the display should come up. If not, the thermostat is probably defective. Some of the cheaper White Rodgers stats require batteries to function.
Feb 20, 2015 | Heating & Cooling
Thermostat is working, but display is blank
My thermostat used to go blank when heating. It was caused by the overheat protector inside the heater. That switch cuts the power to the heater and the thermostat. The heater could also be burned out. If it's a 24Volt system, the power supply could be bad.
Oct 13, 2014 | Heating & Cooling
The display went blank on my honeywell t8600c thermostat. when the batteries were changed, the display shows the time and -AC. Nothing else functions
I believe this thermostat will display -ac if it loses power from the furnace or air handler. Your thermostat will operate on low voltage(same as your door bell) and constantly powers your thermostat. I would check your furnace breaker, and fuses to see if there is power to the equipment
Nov 03, 2013 | Heating & Cooling
I have a honeywell programmable therm that worked fine last season - didn't turn on during the summer as didn't need A/C. It is currently displaying the correct day and time, but the temp is not...
Hello my name is Heath it will be my pleasure to assist you. Your thermostat may be on the blink and need to be replaced. But first lets try a couple things first take the batteries out of the thermostat and let the display go completely blank ( aprox. 5 mins.). While that is going blank go to the indoor air handler and turn the power off to it either from the switch or the inside panel box. Then once the display has gone blank turn the power back on and put the batteries back in. Then set the switch to cool and turn the temperature down and press hold and try it like that to see if it goes back to heat if it does then the thermostat is changing the temperature on its own and going into heat mode and will need to be replaced.
Sep 21, 2011 | Honeywell Programmable Thermostat Heater
Just went to my thermostat & pressed the temp button. It made a fizzing sound for a few seconds and he display disappeared completely. Have changed the batteries but yhe display is still blank. Is it...
Thermostat is bad. Relace the thermostat. I suggest having a professional replace the thermostat as there are many ways to install incorrectly and lead to expensive service call to repair.
Sep 01, 2011 | Honeywell Programmable Thermostat Heater
Carrier a/c thermostat was working fine, then display went blank!
if it has no batt I would ck transformer for 24to26 volts no voltage replece transformer be sure trans has 115 volts to it trans should be in furnace section
Jun 09, 2010 | Carrier 38CKC030 Air Conditioner
CT3600 display went out. Replaced all 3
My honeywell CT3600 thermostat went blank.
Replaced batteries - no change ?
Dec 25, 2009 | Honeywell CT3600 7 Day Electronic...
New batteries ...display not working
remove the batteries and pull the metal tabs at each end stretching out a little the reinstall the batteries
Nov 26, 2008 | Honeywell Programmable Thermostat Heater
Display and all functions other than time have ceased to function
I had this problem after the battery was replaced at a jewellers. It turns out they had used the wrong battery as it only lasted a week.
May 16, 2008 | Tissot T-Touch T33759851
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
