FixYa.com
Tags:
Standard Televisions
Generic problem for all Standard Televisions
White lines across TV screeen (by 2 users)
posted by Sugar55 on May 08, 2008
My TV has little white lines sort of like dashes across the entire width of
the screen. It runs across the heads of the people on the screen and looks like it will soon come down to the eyes
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Comment by etsubuc83, posted on Aug 19, 2008
I have the same model and the same problem.
Best Solution
posted on May 08, 2008
Helpful (85)
meknow
Rank:Guru Guru
Rating: 85%, 40 votes
if these lines are just at the top of the picture then i would suspect an electrolytic capacitor in the vertical circuit.
Rating Locked! (?) Sugar55 has rated this solution as Helpful
Solution #2
posted on Jul 02, 2008
Not Rated (0)
crapmail8976
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
It's data attached to the video stream - closed captioning and the like - whic is always there even when you can't see it. In some TVs in some modes, seeing this is normal, even a feature. CRT and projection TVs: adjust vertical size or position. LCD/Plasma: feature or software flaw.
Comment by crapmail8976, posted on Jul 02, 2008
Worth noting that some cable systems incorrectly format this data, causing it to be displayed by a TV that id functioning normally. Of course, they'll deny this.
That is, of course, unless you have a continuous line and a CRT set. Then there's a flat cap in the vertical out. As a general shotgun assessment, replace all electrolytic capacitors in the vertical section and it will likely be fixed. Nothing to try if you're not electro-tinkering inclined.
Was this solution helpful? Show your Appreciation by rating it:
Solution #3
posted on May 31, 2008
Not Rated (0)
Guest
Guest
Rating: 0%, 0 votes
well can this be fixed?
This Problem Also Relates To: GE 27GT271 TV GE 32GT740 32" TV GE 13R100T 13" TV GE 27GT270 TV GE 27GT277 27" TV GE 27GT722 27" TV Jensen TS2050J 20" TV
Can you Help with these Standard Televisions problems?
GE 27GT622 27" TV
cable channel setup for 1995...
Hello, My Tv is only getting 7... Answer This...
Philips Magnavox MS3652S 36" TV
tv shut off
my tv shuts off after about 35... Answer This...
HELP NO SOUND NO PICTURE
I have an RCA 32V434T and had... Answer This...
Sony FD Trinitron WEGA KV-32FS100 32" TV
Set Won't Turn On
Sony XBR 32 inch about 3years... Answer This...
Samsung TXM2756 27" TV
Cannot play videogames or DVD's
I recently purchased this TV... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
