Question about Dell UltraSharp 1901FP 19" Flat Panel LCD Monitor
Dvd's on 150
I have a blade 150 and would like to try and play a movie dvd on it what do I need ?
  • jrw046 May 08, 2008
    The blade has the player in it . When I try to play a movie it does not work . What software might be needed
My emerson ewr20v4 plays cds with music but not dvd with movies. It keeps displaying disk error
check and see if the dvd player needs to be cleaned. you can pick up contaminates from other dvd's or cd's get yourself a dvd disk cleaner and run it thru seveveral times . and try to play your money then.
May 09, 2014 | Emerson EWR20V4 DVD Recorder/VCR
I have a Magnavox Digital Video Disc Recorder & Video Cassette Recorder. Model# ZV427MG9 A. When recording from a VHS home movie tape to DVD there is a high pitch squealing sound. When playing the DVD...
U play another movie like a Hollywood movie DVD disc play on it have no squealing noises wright?Yes,than the blank DVD discs batch u have is bad.Tries buy another batch DVD blank discs,tries recording again should solved this problems.
Mar 16, 2011 | Magnavox ZV427MG9 DVD Recorder VCR
Cannot get the visual from the videos
Today with HD High Definition TV these kind of problems appears because the new dvd players have more video resolution options, so, for playing all variety of dvd, and home done dvs,s (like family movies on dvd) you need set up your resolution video on your DVD player at 480i or 480p option, not higher because some DVD movies (mainly oldies) have lower resolution than newer , for example new movies on HD format have 1080 P resolution, and if you have this option chosen in your DVD player you only can see this kind of videos, on the other hand if you have chosen 480i or 480 p on your dvd player , you can play all dvd formats including home movies made with any movie software, in this way you can play dvd-r and +r movies and of cours you can play HD movies also. So put some dvd where your dvd player works well (you need see the dvd menu in the tv screen), then press stop. Then press setup in your remote control, go to video resolution and choose 480 I or 480p, then press ok AND ENJOY THE MOVIE.
Smart techniques
Jun 24, 2009 | Insignia IS-DVD1001 DVD Recorder/VCR
Dvd stopped playing in the middle of a movie...
I work for Coby technical support. Our customer service phone number is 1-800-727-3592.
Unfortunately, if the player will no longer read any commercial dvd that you attempt to play, the unit is defective and needs to be replaced. Hopefully, since it's brand new, you still have the receipt and can return it to the retailer for an exchange or refund. The unit has a 90 day warranty from the date of purchase. You would need the receipt in order to receive a warranty exchange.
If you feel this solution doesn't deserve a good rating, please let me know why so that I may better assist you. If there is anything more I can do to help, I will!
Dec 28, 2008 | Coby DVD-224 DVD Player
Have philips dvd-vcr and cannot figure out how to play 2nd movie
you need to select that play option on the dvd players menu!
Dec 07, 2008 | Philips Magnavox DVD/VCR Dual Player
Will Not Play DVD Movies
What program are you trying to use to play these movies? Windows Media Player will play some, but not others - I highly recommend Nero, WinDVD, PowerDVD or similar programs.
Question - are you able to browse the contents of the DVD drive in My Computer? Even if the movie doesn't play, you can still see the files (there will be an AUDIO_TS and a VIDEO_TS folder, which a bunch of VOB files under the latter).
If you can see the files, but movies won't play, you just need the appropriate DVD playback software.
Hope this helps - remember to rate :)
Oct 06, 2008 | Computers & Internet
Can't play dvd-r or dvd+r
try to buy and play original dvd movies. when it play, it is how you burn your dvd, use some software which will automatically create dvd movies so you can play to your DVD player.. If not, try to clean DVD lens using lens cleaner. usually used DVDr will not play to DVD player.. try also to use new blank DVD
Aug 26, 2007 | Toshiba SD-1800 DVD Player
Wont play some newer rented DVD movies
If it is a blue ray, you need a blue ray dvd player.
Aug 26, 2007 | Curtis CMD5000 DVD Player
Why do some DVDs play well and others don't?
just check the data transfer wires.may ur probles sloved
Mar 06, 2007 | Power Acoustik PADVD-150 Car DVD Player
Dell UltraSharp 1901FP 19" Flat Panel LCD Monitor Logo
Alun Cox
