Question about Canon PowerShot A590 IS Digital Camera
Memory card error - Canon PowerShot A590 IS Digital Camera
  • 6,831 Answers
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Posted on Aug 31, 2010
  • cabinrenovat Nov 09, 2010
    If your getting this message is it all the time?Try deleting all the pics off your card see what happens.It can pay to reformat the card in the camera.But isn't required.Some SD cards just don't like being left loaded up with lots of pics.It also slows the download rate from camera to pc.Cheers.
Eclipse avn110m sd card error 013006
This must be very upsetting for you - what make and model of camera has this occurred on ?
Jan 05, 2017 | Cameras
Memory harddrive corrupt in satio TM
well, bro! I think your phone memory card is error or damged, because of the frequent data transport, and the reasons for error memory card are various, for example unpluging memory card without shutting down mobile phone, formatting the card in wrong way, and virus attack, etc.
and after error, the data in the memory card may damages and you have to formate the memory card for reusing. And how to recover data from error memory card, you can know more from here: http://goo.gl/CMfQI
Mar 31, 2013 | Sony Ericsson Satio Cell Phone
My cam says "memory card
If the camera displays Memory card error or No Memory Card when a memory card is inserted or any of the above error messages, make sure that the card is inserted properly. If this is the case, you may wish to Format the memory card in the camera using the Setup Menu option [Format] as shown below. Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data. This can also be caused when images shot with another camera are stored on the memory card.
If after formatting the card in the camera the error persists, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service. If the card appears to be defective you may wish to contact the memory card manufacturer.
Thank you!!
Sep 04, 2011 | Canon PowerShot SX210 IS Digital Camera
Memory card not formatted operation failed problem solutions
Well. There might be quite a lot of reasons that may cause this kind of format error problem saying memory card not formatted. Check out this article how to fix memory card not formatted to see fix step by step. Best regards.
Aug 07, 2010 | Computers & Internet
When i turn the camera on it says memory ard error
If camera show Memory Card Error, Check whether the card is inserted properly or not. For SD card, check out the card lock switch is in the correct position and not stuck in between.
You can Format the memory card in the camera using the Setup Menu option (Format). Please be aware that formatting the memory card will remove any images currently stored on the card along with any other data.
If after formatting the card do not clear the error, try another memory card. If this occurs with only the one card it is likely that the memory card is defective, if the error persists over more than one card the camera may require service.
Rating the solution is highly appriciated...Good Luck
Mar 01, 2010 | Optics
Memory Card Error after Formating memory card
instead of quick format, use the full format.  Then put back in your camera and format again with the camera.
Oct 26, 2008 | Pentax Optio S40 Digital Camera
Not reading memory card; keeps saying reinsert memory card, diplays error C 13
not reading memory card; keeps saying reinsert memory card, diplays error C 1
Aug 04, 2008 | Cameras
Canon power shot SD200
You can take out the memory card from camera and then download a memory card recovery software to recover photos from memory card, you can refer to this tutorial that helped me before
http://www.asoftech.com/articles/how-to-recover-lost-photos-from-memory-card.html
If needed, you may do a quick format of the memory card and then use asoftech data recovery to recover your files.
Dec 30, 2007 | Canon PowerShot SD200 / IXUS 30 Digital...
Canon PowerShot A590 IS Digital Camera Logo
232 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
