Question about Apple MacBook Pro Notebook
MagSafe power adapter
My MagSafe adpater for my Macbook Pro fell in the water when I was disconnecting it, and while it was still plugged into the wall power outlet. The little pegs look crudded with green/blue stuff...What do I do?
I would get some type of cloth and rub and rub and rub the connectors until they are golden again and give it a try.  Most people will probably tell you to get a new one, but since I like to tinker, that's what I'd be doing with mine.
Posted on May 14, 2008
Macbook pro power supply
Openand look at power supply board for capacitors which are "balooning" or deformed in any way. These look like cylindars on the board. These tend to dry out and make what you are describing occur. Replacing them usually fixes about 80% of the problem you are describing. Those parts run about $0.25 to $0.75 each.. well worth trying, right?
Jan 25, 2014 | Computers & Internet
MacBook Pro is slow when disconnected with electric charging.
First step would be to Reset Your Mac's SMC
The method for resetting your Mac's SMC depends on the type of Mac you have. All SMC reset instructions require shutting down your Mac first. If your Mac fails to shut down, try pressing and holding the power button until the Mac shuts down, which usually takes 10 seconds or so.
Mac portables with user-removable batteries (MacBook and most MacBook Pros):
1.Shut down your Mac.
2.Disconnect your Mac portable from its MagSafe connector.
3.Remove the battery.
4.Press and hold the power button for at least 5 seconds.
5.Release the power button.
6.Re-install the battery.
7.Reconnect the MagSafe connector.
8.Turn your Mac on.
Mac portables with non-user-removable batteries (MacBook Air and some late 2009 MacBook Pro models):
2.Connect the MagSafe power adapter to your Mac and to a power outlet.
3.On the built-in keyboard (this will not work from an external keyboard), simultaneously press and hold the left shift, control, and option keys while you press the power button. Release all keys at the same time.
4.Press the power button to start your Mac.
Mac desktops (Mac Pro, iMac, Mac mini):
2.Unplug your Mac's power cord.
3.Press and hold the Mac's power button for 15 seconds.
4.Release the power button.
5.Reconnect your Mac's power cord.
6.Wait five seconds.
7.Start your Mac by pressing the power button.
Alternative SMC reset for Mac Pro:
If you have a Mac Pro that isn't responding to the normal SMC reset as described above, you can force a manual SMC reset by using the SMC reset button located on the Mac Pro's motherboard.
2.Unplug the Mac's power cord.
3.Open the Mac Pro's side access panel.
4.Just below the Drive 4 sled and adjacent to the top PCI-e slot is a small button labeled SMC. Press and hold this button for 10 seconds.
5.Close the Mac Pro's side door.
6.Reconnect your Mac's power cord.
7.Wait five seconds.
8.Start your Mac by pressing the power button.
Now that you have reset the SMC on your Mac, it should be back to operating as you expect. If the SMC reset didn't fix your problems, you can try combining it with a PRAM reset. Although the PRAM works differently than the SMC, it can, depending on your Mac model, store a few bits of information that the SMC uses.
Jan 23, 2013 | Computers & Internet
Computer will not turn on even with power cord
1. Disconnect any devices connected to the computer including printers, hubs, and third-party keyboards or mice, and test the computer again by trying to turn it on.
2. Find out whether the battery on your Apple portable has power. Press the small button on the side or bottom of the computer, depending on the model. Lights should indicate the battery's level of charge. A single blinking light means the battery needs to be recharged. Connect the adapter to recharge the battery.
3. Unplug the power adapter from the electrical outlet and from the MacBook Pro. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the power adapter LED should light up green or amber. If the light does not come on or the computer continues to not power on, proceed to step four.
4. Inspect your MagSafe power adapter. See Apple Portables: Troubleshooting MagSafe adapters for instructions on cleaning the adapter and more details for these steps:
  • Check the MagSafe connector on the adapter for any bent or damaged pins, debris, or alignment issues with the connector.
  • Check the MagSafe connector on the computer for any debris, damaged pins, or alignment issues.
  • Check the MagSafe adapters cabling for any wear or cable issues.
5. Make sure you are using the adapter that was designed for your computer. If you aren't sure or if you need a different adapter, learn which adapter is appropriate for your computer.
6. Review the steps for resetting the SMC (System Management Controller) on your Apple portable computer.
7. If you recently installed additional memory or a hard drive not made by Apple, make sure it is installed correctly and is compatible with your computer.
8. If you are still unable to start up your computer after trying each of these steps, schedule a service appointment with an Apple Retail Store or an Apple Authorized Service Provider.
Nov 20, 2012 | Apple MacBook Pro Laptop Computer with...
IMac 27inch won't boot up
Power issues After ruling out display issues, and if your computer won't turn on, try each of these steps.
  1. Verify you have a good connection from your Mac to the wall outlet by confirming the power cord and adapter are securely connected and plugged in. To check if the wall outlet is working, plug in a lamp or other electrical device
  2. If the wall outlet is working and you continue to have no power, try another power cord or adapter if available. If it works you may need a replacement cord or adapter. If you're using a Mac notebook, see Apple Portables: Troubleshooting MagSafe adapters for further troubleshooting with MagSafe adapters.
  3. Disconnect all accessories that are plugged in to your computer. This includes things like printers, USB hubs, or mobile devices.
  4. Hold down the power button for ten seconds. Then, press the power button again to see if the computer turns on.
  5. Reset the SMC.
  6. If you recently installed memory or a drive in your Mac, make sure it's compatible, supported, and installed correctly. If possible, reinstall the original memory or drive to see if the issue persists afterwards.
  7. If you're still unable to start up your computer after trying each of these steps, visit an Apple Store or Apple Authorized Service Provider (AASP) for further diagnosis. If you plan to visit an Apple Retail Store, make a reservation at the Genius Bar using http://www.apple.com/retail/geniusbar/ (available in some countries only).
Sep 22, 2012 | Computers & Internet
Macbook adapter A1184 stopped charging
Things break. Get a replacement on ebay. eBayeBay
Jul 28, 2012 | Apple MacBook Pro Notebook
Macbook pro says not charging
3 options..
--your charger is broken ? does it light when you plug in to power outlet ?
--Charger cable is broken ?
-- Your notebook's battery charging circuit malfunctions.(hope not)
Try with another Apple charger from your friend...
Hope this helps! Take care and please Remember to rate/vote and give me
4 Thumbs Up for me to continue for Helping out the Community :)
Thanks
Jul 21, 2011 | Apple MacBook Pro Laptop Computer with...
Lap top won't come on
Follow the steps below and it should solve your mac problem..
  2. If you're using a MacBook or MacBook Pro, check the battery level. Press the small button on the battery or on the side of the computer. You should see lights indicating the battery's level of charge. If you see just one light blinking, the battery needs to be recharged. Use the fluorescent pen computer with the adapter connected to recharge the battery.
  3. Unplug the power adapter from the electrical outlet and from the MacBook, MacBook Air, or MacBook Pro. Wait one minute. Plug it back into the wall first, then to the computer. Make sure the electrical outlet is working by plugging in another device (such as a lamp). When you plug the adapter back into the computer, the PowerBook G4 Battery 15" power adapter LEDs should light up green or amber.
  4. Inspect the MagSafe port on the computer for debris, such as metal stuck to the magnet in the port, which might prevent the connector from seating properly. On the adapter side, look at the DC connector for dust or other debris and check whether pins are missing, bent, or stuck down. If you find any of these to be true, see Apple Portables: Troubleshooting MagSafe adapters for instructions on cleaning the adapter.
  5. Make sure you are using the adapter that was designed for your computer. If you aren't sure or if you need a new adapter,learn which adapter is appropriate for your computer.
  6. Press the control key, the command key, and the sony vgp-bps13a/b battery power button simultaneously and hold for three seconds to try to restart the computer.
  7. Reset the PRAM. After pressing the power button, hold down these keys simultaneously: Command-Option-P-R, until you hear the startup chime at least one additional time after the initial startup chime.
  8. Reset the SMC for the MacBook And MacBook Pro by removing the AC power, removing the sony vgp-bps13 battery and then holding down the power button for five seconds. On the MacBook Air, press (left) Shift-Control-Option along with the power button once. Note: You must use the keys on the left side of the MacBook Air keyboard.
  9. If you recently installed additional memory, make sure it is correctly installed and is compatible with your computer. Remove the new memory to see if the computer starts up properly without it.
  10. If you are still unable to start up your computer after trying each of these steps, schedule a service appointment with either an Apple Retail Store or an Apple Authorized Service Provider.
Regards,
Ron
Jun 02, 2011 | Apple 13" MacBook Notebook Computer ...
No power at all
You may need to perform a SMC reset on your Macbook Pro.
Directions for doing a SMC reset are available on the Apple Web site (Click Here).
The part that is of most interest on this web page is:
  • Shut down the computer.
  • Disconnect the MagSafe power adapter from the computer, if it's connected.
  • Remove the battery.
  • Press and hold the power button for 5 seconds.
  • Release the power button.
  • Reconnect the battery and MagSafe power adapter.
  • Press the power button to turn on the computer.
  • Dec 30, 2010 | Apple MacBook Pro Notebook
    It shows message as "turn on camera" while try to
    Assuming your computer has a built-in iSight camera - which should be all Macs made since 2006 except for the Mac Mini and Mac Pro (not MacBOOK Pro!) - your camera
    a) May not be being seen by the computer. Check Apple Menu > About This Mac > More Info > USB and see if "built-in iSight" is listed in the USB Device Tree. If it is, then it may be being used by another application that uses a webcam, like Skype, iChat, or what have you. If it IS NOT detected:
    b) Try resetting your SMC:
    Resetting the SMC on Mac portables with a battery you can remove
    Note: Learn about removing the battery on MacBook and MacBook Pro.
    1. Shut down the computer.
    2. Disconnect the MagSafe power adapter from the computer, if it's connected.
    3. Remove the battery.
    4. Press and hold the power button for 5 seconds.
    5. Release the power button.
    6. Reconnect the battery and MagSafe power adapter.
    7. Press the power button to turn on the computer.
    Resetting the SMC on portables with a battery you should not remove on your own
    Note: Portable computers that have a battery you should not remove on your own include MacBook Pro (Early 2009) and later, all models of MacBook Air, and MacBook (Late 2009).
    2. Plug in the MagSafe power adapter to a power source, connecting it to the Mac if its not already connected.
    3. On the built-in keyboard, press the (left side) Shift-Control-Option keys and the power button at the same time.
    4. Release all the keys and the power button at the same time.
    5. Press the power button to turn on the computer.
      Note
      : The LED on the MagSafe power adapter may change states or temporarily turn off when you reset the SMC.
    Resetting the SMC for Mac Pro, Intel-based iMac, Intel-based Mac mini, or Intel-based Xserve
    2. Unplug the computer's power cord.
    3. Wait fifteen seconds.
    4. Attach the computer's power cord.
    5. Wait five seconds, then press the power button to turn on the computer.
    Dec 20, 2010 | Computers & Internet
    Macbook a1181 works for a couple days and then does not want to start again for another couple days. please advise
    Your best bet is to reset the System Management Controller;
    (I'm not sure if your model has a removable battery or not, so I'm providing both methods)
      Note
    ...and then reset the Parameter RAM:
    2. Locate the following keys on the keyboard: Command, Option, P, and R. You will need to hold these keys down simultaneously in step 4.
    3. Turn on the computer.
    4. Press and hold the Command-Option-P-R keys. You must press this key combination before the gray screen appears.
    5. Hold the keys down until the computer restarts and you hear the startup sound for the second time.
    6. Release the keys.
    Nov 17, 2010 | Apple 13-inch MacBook - Intel 2.0GHz Intel...
    Apple MacBook Pro Notebook Logo
    120 people viewed this question
    Top Apple Computers & Internet Experts
    Paul Carew
    Martin Buck
    Martin Buck
    Paul Bade
    Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
