Question about Olympus FE-200 Digital Camera
The battery ran out and I was not able to recharge for a couple of days .The camera never shut down the lens still stayed out of camera body even when the battery was taken out. After recharging battery and reinserting it in the camera the camera will not function. When the power button is pushed the light goes on and the camera makes attempts to close lens but then it buzzes and makes beeping sounds and then goes off.
  • 10,515 Answers
Unfortunately, this is a common problem on this model. Yet, no resolution other than getting it repaired.
There are a number of things you can try:
1. Ensure batteries are fully charged
2. Look carefully between the lens and the camera body for any sand or other dirt etc
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 2 minutes and refit
If no luck then we have to try some things that could possibly result in damaging your camera so should only be tried if happy to take that risk...
5. Try thumping the camera into your other hand, by thumping into your hand you are trying to jar the mechanism loose, by using your hand you will hopefully not do it too hard or it will hurt. You may need to do this a dozen or so times in different places to work. I have found the flat of the camera bottom into the flat of your hand best..
6. If the lens is stuck in the out position then remove the batteries and try twisting the lens first one way then the other, do not apply excessive force when doing this or you can break gears, you are trying to reposition not force... Likewise if the lens looks like it is crooked you can try pushing it back into position. This has a higher chance of doing more harm than the thump so please be careful...
7. Dismantle the camera, not for the faint hearted, you need to dismantle the lens assembly into the main body of the camera
If no luck then only other option is a serviceman I'm afraid, be sure to get a quotes as camera repairs can be uneconomical
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 30, 2010
My casio EX-S10 lens stuck out and wont turn on even with battery recharged
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them.
And here's a 16 minute video summary of the info shown in the link. But note that the article link above goes into even greater detail than this video:
utube.png You-Tube video "AkEfnF6zVxc" placeholder (do not delete) utube.png
Nov 14, 2011 | Casio Exilim Ex-z300 Z450 Z9 Z80 S10
My camera has a "lens error". It will not contract back and stays out in zoom...it beeps and gives me this message to start, but doesn't do anything.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended.
1.Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
2.
Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera.
Thank you !!
Jun 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I have the sd1000 power shot canon. i was taking a picture the camera took the picture as normal but when trying taking another shot i got an lens error restart camera.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
One thing, you mentioned that the lens error occurred after you wer able to take a good picture. This really sounds like your battery ran down during shooting, and did not have sufficient power to properly shutdown the camera. Focus on your battery as the potential cause first. Note that if the battery is older than a couple years, it may be time for a new one. Rechargeable are not meant to last indefinitely.
Jan 23, 2009 | Canon PowerShot SD1000 Digital Camera
Camera ran out of battery,whilst zoom lense out.Replaced with new batteries but now when i turn the camera on it bleeps for about 3 seconds and then goes off.I cant even get it to stay on long enough to...
Some batteries (especially the lower mAh rechargables) don't seem to have enough power. Try putting in a couple of brand-new (non-rechargeable) Duracells, and see if that helps.
Nov 24, 2008 | Rollei Cameras
Nikon coolpix 2100 camera won't stay on
I've been having problems with the batteries and the camera refusing to start even with fresh batteries. I bought loads of new rechargable batteries and have finally found some that work. Duracell rechargables. Theyr'e brilliant and keep their charge for ages despite continuous use of the camera! Last summer I managed to take 975 photos before the batteries finally decided to give up!
Jan 27, 2008 | Nikon Coolpix 2100 Digital Camera
Camera will not stay on.....
the 3 beeping sound means that the camera has low battery capacity. the lens is stuck out because there is incorrect battery connection. there is an option on the camera setting for the battery type. try this one:
-turn the camera on
-click on Menu button
-select options using left/right, up/down button
-select Set up 2
-Select Battery type
-Select Alkaline for non-rechargable
or Ni-MH for rechargable
-click OK button
this setting should be done when using camera for the first time and whenever you are switching battery types, from rechargable to non-rechargable and vice versa.
Dec 04, 2007 | Samsung Digimax S500 Digital Camera
Canon A95 operability issue
Defective mechanism, a stucked mechanism is present. camcorder are smart it can detects error and shuts down itself for safety. earlier models dominoes the defect if the user is not quick enough to react when something goes wrong with the camera. You need professional service to fix it.
Sep 30, 2007 | Canon PowerShot A95 Digital Camera
My camera keeps switching itself off!
I ordered some new batteries for it before posting my problem ,a dn after using the new batteries, the problem no longer exists. It seems that my batteries were so run-down that they just couldn't power the lens anymore or the flash at times
Sep 05, 2007 | Sony Cyber-Shot DSC-P73 Digital Camera
Battery problem
It probably lacked the power to retract the lens. I'd start with recharging the battery and see if that corrects the problem.
Sep 19, 2005 | Nikon Coolpix 5400 Digital Camera
Olympus FE-200 Digital Camera Logo
37 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
