Question about Ovens
Whirlpool double oven
I have a whirlpool double oven stainless steel 5 years old were working fine until yesterday when my maids left after cleaning ,the display panel was showing this message EO F2 have tried turning the power off and no results still same display
    Genius:
  • 1,224 Answers
Water or over spray in the panel let dry for couple days and turn back on see what happens
Posted on May 09, 2008
Whirlpool double oven display reads E6 F2
I have a Whirlpool RBD275PRT00 that showed the same codes. it would allow me to cancel and work for a few more days until the display finally went blank and after a few days of being blank displayed the codes again. I ordered a New Electronic control board from Sears W10340941 for 189 dollars just recently, when I just looked for this part for your model it's that same number but now listed for 254. There are services that will repair your board for a little less but it will not be a new board. it's still much cheaper that a new oven.
Dec 02, 2013 | Whirlpool GBD307PRS Stainless Steel...
Electronic touch panel unresponsive. Clock blinks, but no other commands produce any activity. Model#:JMW8330DAS Serial #:13679516JN Jenn-Air oven. About 2 years old.
Unplug and let sit for 5 min. Replug and set clock time first. Then see if the other buttons work. Electronics sometime need to reboot if it freezes like your computer does sometimes.
Apr 29, 2009 | Jenn-Air JMW8330DAS Stainless Steel...
Display panel
Dim display indicates a "failing" electronic oven control. It will continue to get dimmer and dimmer until it fails completely. You need to replace the "clock" (sometimes called the ERC <---Electronic Oven Control)
This is a tricky repair. Be sure you have the power off (at the breaker box) before attempting this.
Tracy
Oct 28, 2008 | Jenn-Air WW27430P Stainless Steel Electric...
Know display anel getting EXTREMELY hot
Laura_kucari
I think you are feeling the heat coming from the oven vent. The fan still runs as it tries to cool down the temp in the compartment housing the electronics.
Regards
Aug 31, 2008 | GE Monogram ZET3058SHSS Stainless Steel...
GE monogram double oven display getting extremely hot
Usually the knob type controls uses the bulb for temperature regulation. There is usually only one adjustment available - otherwise the thermostat has to be replaced. - that dial with the temperature graduations on it. the whole unit - the bulb in the oven is connected to it.
Bottom oven not working
It is quite possible the control electronics have failed. There are separate relays for the upper and lower ovens. Ours recently failed the upper oven with the same symptoms and it was the electronic control. The other part is the overheat thermal sensor for the oven may be out.
Aug 01, 2008 | Whirlpool GBD307PRS Stainless Steel...
Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Dec 06, 2007 | Whirlpool RBD245PRS Stainless Steel Oven
Ovens Logo
261 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
