Question about Gateway 2520915 Keyboard
Cannot get a question mark keep getting ÉÉÉÉÉÉ
Could someone help me find out what tubes are used in the AF section of my Crosley XJ radio?
I found this little bit of info for a 5-tube model... hope it helps:
Card says use uv-201 A or C-301 A tubes. or any equivalent tube that use 1/4 amp at 5 volts
Also:
http://www.crosleyradios.com/battery-sets/battery-sets.html
May 19, 2014 | Radio Communications
I keep getting a paper jam 201 every time I print. Then I have to open it up and take out the cartridge. What is causing the paper to jam?
A 201 paper jam error indicates the paper did not reach the fuser sensor within the proper time period. This usually indicates the fuser has a problem and needs to be replaced. The part number for the fuser is 56P1333 and it is user installable. You can get one from many places online such as Amazon.com
Aug 20, 2012 | Lexmark T630 Laser Printer
Cannot type question mark sign it keeps typing the é or É
ensure the correct language is being used.
check in settings to see that the language is correct for the keyboard, eg english us and not english uk etc.
i hope this was useful
Jan 24, 2011 | Acer NSK8458AN Keyboard
How do I change which symbol comes up when I hit shift...for example, I am trying t o make a question mark but it wont stop giving me a ÉÉÉ
You most likely have the incorrect language set for your keyboard.
There are a number of ways to change this.
1) There may be a "EN" button on the task bar in the bottom right near the clock. Click on this and there may be an option to change between "English US" and "English UK" for example
2)Click Start > Control Panel > Keyboards and change the language in there
Dec 16, 2010 | Gateway LT2021u Netbook
Just bought an acer computer and keyboard.. had no instructions for keyboard ...when i press for question mark i get this É how do i get the question mark
You have to configure the keyboard language.
Go to control panel/clock language and region.
Go to keyboard and select location(win7).set it for your country.
Aug 06, 2010 | Acer Computers & Internet
I need help with my notebooks keyboard If I try to input a question mark I getÉÉÉÉ how do I fix this
Hold ALT car or Alt Gr then press question mark let me know if it does not work , do have different alternative.
Jun 30, 2010 | Acer Aspire One PC Notebook
As one example; when I push shift question mark I get É instead. What botton do I need to change it back É
You need to go back into CTRL Panel and set keyboard to ENGLISH US
Please rate my help++++Thanks for using FIXYA
Jun 10, 2010 | Acer NSK8458AN Keyboard
My keyboard shows this symbol, É, instead of
Control panel>keyboard>settings. Double check that it is set to your country/language. Hope this helps!
Feb 02, 2010 | Acer Aspire 5500 5570-2609 Laptop
Keeping turning off
Yes, they know about the problem, I would either get another one or try to get a refund. the issue is water vapor at the control board.
Dec 13, 2017 | Rival FSD201 4-Cup Rice Cooker
Gateway 2520915 Keyboard Logo
49 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
