Question about Tag Heuer 2000 CN1110.BA0337 Wristwatch
I cannot re-set the red hand back to 12 oclock.
Clock Manuals
leave it running when it gets to 12 oclock it wiil reset itself
May 02, 2013 | Watches
I have the Nautica A40008 watch and I can not reset the big second hand to 12 oclock. It stops always at 11
pull the crown out to second position then press start till it gets to 12 then push crown back in
Apr 09, 2013 | Watches
I have an eco drive and recently in trying to set the clock back to regular time, I must have done something wrong. The time is correct but the date, and day are one day forward. How do I correct this?
the crown of the watch has two clicks, pull it gently once and you can set the date and day, pull it gently again a second time and you can set the time. The proper way to set the time and date is to set first the day,date late at the actual date, then move the hands around the clock until the date change at 12 oclock this is evening, then moving the hands around until you reach the actual time. By doing so you will set the day, date and time in syn to 24 hrs change.
example: you want to change it to sat 12th 11am
set the day and date to fri 11th
then move the hands around clockwise until the day and date change at 12 oclock continue moving the hands until you reach 11am
Dec 13, 2010 | Citizen Eco-Drive watch
How do I get the numbers to align properly with the hours
If you are refering to the chronograph part then you can set the centre hand by pulling out the winder fully and pressing the top right button (or could be the bottom right button) You should be able to press and hold it until it gets to the 12 oclock position then push the winder back in and test it.
Sep 20, 2010 | Bulova Marine Star 96B11 Wrist Watch
Kaiser clock model kc-2. The cuckoo doesn't go off on the hour and I want to know how to set it so the cuckoo will go off on the hour.
remove the batheries and then advance the mintue hand slowly until you hear a clicking noice then remove both the hour and minute hand and place both at 12 oclock high postion advance the minute hand again to confirm you hear the click noise when the minute hand is at 12 and the hour hand is at 1. then replace batteries and the clock should cuckoo properly on each hour,,,,,best regards
kaiser clock
Aug 04, 2010 | Watches
Can't set Seiko Yacht Timer Sports 150
Turn knob to set on "Match" Pull out crown knob. Press both buttons for 3 seconds. When you release both buttons it will beep and both hands start moving. Press either button to stop movement. Then press the top button to set the minute hand to 12 oclock. Press the bottom button to set hours to 12. Press in crown and turn to "Time" Pull out crown and set time the same way.
Mar 01, 2009 | Seiko Le Grand Sport SDWF73 Wrist Watch
Crane and Viceroy ladies RC watch
Hi, Klik and Crane & Viceroy are excellent and robust watches, but due to the radio control batteries need to be changed more often than ordinary watches. Instructions for resetting the time on a Klik or Crane & Viceroy watch. With the watch face upwards and the buttons on the right assume the buttons to be; top button - "A", middle button "B" For setting the watch to GMT all hands need to point to 12 oclock exactly. To achieve this press Button A until the hands start spinning. Stop the spinning when the time reaches a couple of minutes before 12 oclock by repressing A. Inch the time forward by repressing Button A until all hands are at 12 oclock.(EXACTLY). Press Button B within 10 seconds and the time will advance 1 hour and stop. The radio signal will be picked up automatically and time will set itself in a few minutes. Notes: If you have radio dead spots avoid these when resetting the watch and do it away from magnetic or large metal objects. i.e. trays etc. If you are refitting a new battery and have a battery that isn't quite dead, do the advancement of time with the old battery and fit the new one near to 12 oclock to get the best life out of the new battery. If for any reason you want the watch to be in radio mode but read a time other than GMT ( no adjustment is needed for BST ), then instead of stopping the watch at 12 oclock stop it at the time in relation to 12 oclock. i.e. if you wanted the watch to read 30 minutes fast then stop the watch at 12.30. if you want any other info my email is; Charles@adept.fsbusiness.co.uk
Jul 15, 2008 | Watches
Klik r c watch.
problem solved.
regards.
Matt.
Apr 17, 2008 | Watches
Set date
hello..this is not abig problem..just a sincronization one...ususlly I set the date around the 12 oclock in the night..the 0 hour..its easier...if you dont want to do this...well..then just count the hours ..remember you have the 24 hours /day..and remember the date is changing in the night around 12 oclock..
for instance...lets say..now you want to set the date..you count the hours until tonight at 12...you put it lets say...with 12 hours back..and wait the change in the midnight..
the easier way is to set it at midnight
oh...by the way..I saw watches which change the date around 2 oclock in the night..but this is a very small %...99% are set to do it at 12..
good luck
Feb 03, 2008 | Seiko SNA553 Alarm Chronograph
Tag Heuer 2000 CN1110.BA0337 Wristwatch Logo
15 people viewed this question
Top Tag Heuer Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Tag Heuer Watch Expert? Answer questions, earn points and help others
