Question about Refrigerators
When cooler goes 2 start sounds like a harley and wont start
  • 21 Answers
Damaged compresser will need to be replaced. Costly
Posted on Sep 01, 2010
I can hear a lot of valve train noise, carried it back at 1000 miles. HD said bike sounded good, but sure they would. 09 evo 1200.
Hi Anonymous, find a friend who also has a fairly late model XL 1200 and swap bikes and go for a ride for an hour or so, then you will know for sure and so will the guy/gal riding your bike. Also you can try running SYN 3 Harley oil it runs cooler than non-syn also run an oil cooler. Engine oil temp should be around 180 to 220. The cooler the engine the quieter the moving parts to a point. Good luck
Aug 03, 2013 | 2009 Harley Davidson XL 1200L Sportster...
97 fatboy, goes in gear but wont move.
Hi Anonymous, you could have a clutch or transmission issue try a clutch adjustment first then call, take a ride or trailer your bike over to your local dealers service/parts department, I'm sure they will be happy to take your Harley Davidson for a test ride if necessary/possible and offer professional advice and assistance concerning your issue. Good luck have a nice day. How To Properly Adjust The Clutch Clutch Cable Harley Davidson
Apr 20, 2012 | Cars & Trucks
Does anyone have a diagram for how the oil lines run on a 1970 ironhead sportster with an oil cooler?
You '70 model has the "long" style oil pump on it. It has a inlet and an outlet. Of course, the hose from the bottom of the oil tank goes to the inlet. From the outlet of the pump, route your oil line to the oil cooler. Then from the oil cooler back the top of the oil tank where the cap goes on. The oil filter is inside the tank under the cap. There is also a vent hose that comes from just in front of the front chain sprocket that goes to the small nipple on the oil tank. This is the way most people run the oil lines.
Ride Safe
Steve
Apr 12, 2011 | Harley Davidson XLH 1000 Sportster...
1999 sportster. lose spark while riding. cranks but won't start. let it set for 10 or 15 minutes and it fires up. one time i ride 3 miles, next time i might ride 20 miles. next time i may ride for 2 or 3...
It sounds like you may have a problem with your electronic ignition system or the crank position sensor. Here's a way to find out which it is. Stop by an electronic supply shop like Radio Shack or somewhere like that. Purchase a small can of "Component Cooler" and put it in your saddlebag or tool kit bag. The next time your bike suddenly quits on you, check for spark. If you have none, shoot a bit of the "component cooler" on the electronic ignition box and try to start the bike. Try this two or three times. If that doesn't help, try the same thing with the cam position sensor. If it does no good, then your problem is not temperature related.
Good Luck
Steve
Feb 20, 2011 | 2000 Harley Davidson XL 1200 C Sportster...
Bike wont start
It sounds like you damaged the TSSM (Turn Signal Security Module). It also contains a bank angle sensor that shuts the bike down if it is dropped. It should have reset but it might have been damaged.
Jan 09, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Heat !! 08- 96ci stange 1 reinharts t/d - k&n af - been dyno'd what about an oil cooler?
If it's running way too hot, there is something wrong. Usually timing or air/fuel ratio. Adding an oil cooler will only mask the problem. If it's within normal operating temperature, an oil cooler sure wont hurt, especially if you live in a hot climate.
Oct 13, 2009 | 2008 Harley Davidson FLHX Street Glide
How do i install oil cooler on a 1989 sporster? harley davidson
unlike the big twins which have exposed oil lines , if i recall you need a fitting that goes under the oil filter , which like on later sporters like this is located where the generator used to be on the old sportsters
Jun 13, 2009 | 1979 Harley Davidson XLH 1000 Sportster
Need oil routing diagram for 1989 harley davidson sportster hugger to install oil cooler. how to install oil cooler?
Little tip -The only time the oil cooler will cool is when the bike is moving and when the bike is moving you don't need the oil cooler. This is from a factory harley tech.
Jun 13, 2009 | 1993 Harley Davidson XLH Sportster 883...
D915GAG problem
this cant have anything to do with only replacing a cooler, unless when fitting it you have caused some sort of stress damage to the motherboard. Check all seatings of ram, graphics card and power connections in case they have been dislodged. I assume you have tried resetting the cmos settings in case there is a corrupt bios for some reason. The only other check is to see if the cooler is starting up straight away, as the processor may be shutting down if there is no fan running, or the motherboard is reading the temperatures incorrectly and not enabling you to boot.
May 09, 2007 | Intel D915GAG Motherboard
Refrigerators Logo
27 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
