Question about HP Compaq Presario S5200NX (DM173A#ABA) PC Desktop
On and off constantly, without entering into windows xp. Disconnect all drivers, and does the same
I cant find a ethernet driver for windows 7 home premium for my acer aspire t120c after updating from windows xp home 32 bit
Get onlineand got to www.google.com In the google search box type: "AcerSupport" (without the quotes). Look for downloads and drivers. Enter your model number and operating system when requested. Download andinstall the drivers.If you don't see windows 7 drivers, maybe the vista drivers will work. Give it a try.
Mar 30, 2012 | Computers & Internet
On my Windows XP laptop I cannot get the wireless to work. All it says is "limited or no connectivity" when it connects. I have tried a million things, and nothing works! What can I do?
Disconnect your laptop wireless connection from the wireless acess connection. (Reboot your laptop if necessary). Then reconnect your laptop wireless connection, if your wireless network is a secured wireless network, your laptop will prompt for a network key ie your wireless network SSID password. Make sure the network key correctly entered ie.("Most wireless password keys are Upper or Lower case sensitive")
If the problem persist, then use the "Command Prompt"
Start ->"Run" ->Type "CMD" ->The command prompt will appear, then type ie without the quotes,
1. "ipconfig /release" -> enter
2. "ipconfig /renew" -> enter
3. "ipconfig /flushdns" -> enter
Hope it helps.
Nov 17, 2010 | Microsoft Windows XP Professional
I want to reformay my Dell Latitude D505 laptop. I have the reinstall disc with system software, device drivers, diagnostics and utilities as well as the windows XP Disc. Is this all I need ?
HI there,
It looks like you're good to go except you should, during rebuilding your system, go to the Dell Support Drivers & Downloads site (which they recommend), enter the service tag# for your laptop, and download and install most of your drivers from there as they will be the most recent.
Since you're using XP, you'll want to start with the XP disc and reformat and install XP first, then use your Dell Dsic that has drivers on it to install the LAN and WLAN (wired and wireless internet connection) drivers to get on the net and go to the Dell site.
I usually make a folder on the desktop and name it Drivers, then while at the Dell site dowload each driver, BIOS update, application, etc. to that folder so I can work directly from the driver files without constantly reconnecting to the Dell site every time I have to restart after a driver install that requires it.
Good Luck
Aug 29, 2010 | Dell Latitude D505 Notebook
No sound after Windows XP (SP3) Black install
go to device manager remove check if no yellow sigh audio device of pci device. remove that and refresh allow new hardware search and install driver manually.
Mar 29, 2010 | Microsoft Windows XP Professional With...
Printer does not print
Did you install the proper drivers ?
Sep 13, 2009 | HP DeskJet 3820 InkJet Printer
I can not install windows XP on Toshiba Satellite U300, windows
You must have latest Windows Xp CD .
Latest Motherboard chipset does not recognise hard disk without proper sata raid or sata driver. So you can install sata driver if u have USB floppy drive by downloading latest Sata raid to floppy. At the time of installation you will see a message press f6 to if u need to install raid driver.then press f6 asking for floppy drive and floppy insert press enter to continue.
Jun 27, 2009 | Microsoft Windows XP Professional With...
How to install usb
After you install Microsoft Windows XP Service Pack 2 on a computer that is running Microsoft Windows XP, the universal serial bus (USB) drivers do not appear to update. CAUSE After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers... loadTOCNode(1, 'cause'); After you upgrade from Windows XP to Windows XP Service Pack 2, the USB drivers appear with the earlier version numbers, even though the files have been updated. uparrow.gifBack to the top RESOLUTION To resolve this problem, install Windows XP SP2, and then update the drivers for... loadTOCNode(1, 'resolution'); To resolve this problem, install Windows XP SP2, and then update the drivers for the USB devices that are connected to your computer. To update these drivers, follow these steps:
  1. Click Start, click Run, type devmgmt.msc, and then click OK.
  2. Double-click the type of device that you want to update.
  3. Double-click the specific device that you want to update.
  4. Click the Driver tab, and then click Update Driver.
  5. Follow the instructions in the Hardware Update Wizard.
  6. Repeat steps 2 through 5 for each USB device.
Note You can also install Windows XP SP2, and then disconnect and reconnect the USB devices that are connected to your computer. By doing this, you start the Plug and Play utility. The Plug and Play utility updates the version numbers for the drivers.
May 08, 2009 | Microsoft Windows XP Home Edition
How to install windows xp
Enter BIOS Set CD rom drive to first bootInsert your CD reboot
folow the on screen instructions be patient, it may take up to an hour,  and then two houers to install drivers,
-> if you want me to find the drivers for you, plz state your computer name and model.
regards /Teis
Jan 11, 2009 | Microsoft Streets and Trips 2008 for PC
How to install xp on hp 530
Press F10 to enter BIOS setup...
find and disable the SATA native support
Now save and exit then when you reboot and attempt to install XP you will have no problem.
Download the drivers you need from here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swEnvOID=1093&taskId=135&swLang=8
Mar 11, 2008 | HP Pavilion dv6000z Notebook
Lg ku250 modem driver
Download LG KU250 modem driver herehttp://www.ziddu.com/download.php?uid=ZaqblpymZbOZnJSlsKyZlJyiYq2WlZyt2
Oct 21, 2007 | Microsoft Windows Vista Ultimate Edition
HP Compaq Presario S5200NX (DM173A#ABA) PC Desktop Logo
23 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
