Question about Husqvarna Garden
My husqvarna chainsaws bar is 20 inches long, what size chain do i need?
    President:
  • 2,220 Answers
Oregon Bar & Chain Selector
http://www.oregonchain.com/pro/lookups/selguide.aspx?BusId=OCS&SellReg=USA&LangId=ENG
Count the drive links and be careful if there are multiple pitches or gauges.
A local saw seller/mechanic can make a duplicate in a few minutes given your old chain as a sample. All new chains stretch. Please keep a careful eye on the tension.
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Aug 30, 2010
  • 490 Answers
Howdy, that would depend on the model you have. Here is the link to Husqvarna, so you can get the info that pertains to your specific model:
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Happy sawing:)
Farmerbear
What Size File for a Husqvarna 240 Chain?
The 240 runs standard a 3/8 " pitch H36 low profile chain. The proper size file is 5/32" (4.0 mm)
Jun 09, 2014 | Husqvarna Chain Saw 20" Bar
Chain wont tighten up
Jeff:
Loosen the two nuts on the right side cover of the saw (1/2 inch socket) turn them out 2 turns. Use a flat blade screwdriver on the screw at the right side front of the housing (near where the bar comes out of the saw). Turn the screw right until the chain can only be pulled up 1/8 of an inch at the top center of the bar. tighten the two 1/2 inch nuts. The two nuts clamp the bar so it won't move. If the chain tensioner still won't work, remove the right side housing by removing the two 1/2 inch nuts and look at the tensioner assembly and how it fits into the chain bar. The problem will be obvious. If you need to replace the tensioner assembly, a new one can be ordered through http://www.husqvarna.com.
Aug 16, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Filing angle for Husqvarna chainsaw 450 --20 ' bar chain 72 links?
On .325 pitch chain the top plate angle should be 25 degrees, there is normaly a match mark on top of each cutter, the depth gauge should be set at 25 thousands of an inch.
Apr 02, 2013 | Husqvarna 450 Chain Saw 18 Inch Bar...
Loose chain
if you have atleast 1/8" of teeth still on chain .take a link or 2 off good to go saved you beer money.
Feb 18, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Need to know the degree to set my electric chain saw sharpener for husqvarna chain. This is a 20 inch chain.
A 20" bar unfortunately does not narrow it down. Fortunately both the .325 pitch chain and the 3/8 pitch chain sharpen at 25 degrees and you should have one of these chains. Hope this helps.
Mar 01, 2011 | Husqvarna Chain Saw 20" Bar
How interchangeable are replacement chain bars for older Husqvarna chainsaws? I've never replaced one before and was considering buying one from Sherril on-line which is on sale, a 14 inch Husqvarna Intenz...
Your question can't be answered as aked.
If your saw requires an Intenz 14" Bar it's Oregon pns 140SDET041 or 140GPET041. Part number 140SDEA041 if not Intenz.
Plug in your requirements here:
http://www.oregonchain.com/commonpgm/Selguide_Selctmfg.asp?BusId=OCS&SellReg=USA&LangId=ENG&ShowRem=Y&ShowAnsi=Y&ShowQuality=Y&ShowCombo=Y&usertype=OCC
Once you get a part number it can easily be converted to other manufacturers numbers. HTH
Lou
Nov 03, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Need true chain/bar size for my husqvarna Model 254 chainsaw
Maximum bar size of 20" but would recommend 18", if it is running sluggish, check compression, if low replace the piston, if it is 135psi or more then make sure the airfilter is clean and then tune the carb and make sure you get good revs and throttle response throughout the rev range, use the typical carb adjustments from the owners manual from the Husky web site. This is a 5hp saw and is capable of cutting some big lumps of hardwood so no excuses on the power front
Feb 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
HUSQVARNA MODEL 50 BAR AND CHAIN UPGRADE
I have a nearly worn out 42 cc Husquvarna that uses a 20 inch bar very successfully. With proper filing of the chain you should be able to run a 22 inch bar very well. Ensure that the roller nose on your new bar matches the pitch of the clutch sprocket that you are using at present. If not, have your chain saw shop change them so they match.
I would advise that you change the bar and sprocket to use a .375 chain as this will be easier to sharpen successfully than the .325 pitch chain you might be presently using.
I am six feet tall and short bars are murder on my back so this is why I use no shorter than 20 inch bars on my saws.
Jan 25, 2009 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Bar size
According to Husqvarna a 3hp saw will allow bar sizes 13"-20"
Sep 06, 2008 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
Garden Logo
133 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
